Question about Western Digital My Book Essential Edition (WDG1U5000N) 500 GB Hard Drive
80 gb wd passport
My portable hard drive no longer is recognized in xp pro everytime i connect it shows a external hdd has been connected and is ready to use and it also shows up in device manager but i cannot access the drive the light is on but it is not spinning
  • 67 Answers
Maybe it might be that the hard drive is dead , you can test if it works by connecting it to another computer or device (ps3) if it works (reads/writes) you might want to try this http://www.aeonity.com/trialerror .You can burn a live cd (Operating system on cd) and this might detect your drive if its a usb driver problem (used to  detect USB devices).
Posted on Oct 14, 2008
WD external HDD my passport 500 Gb . It's not correctly installed into my PC - PC can't find driver. System Windows XP
Maybe it's a power issue. Try a shorter usb cord or try a different usb port. If you are using an usb hub, try to connect the hard disk straight to the pc.
Feb 28, 2011 | Western Digital My Passport Essential SE...
How can I install the driver for My Passport WD External HDD 500GB online?
It is a "plug-and-play" device, and Windows XP/Vista/7 are "plug-and-play-aware" systems.
So, just connect it, and Windows should recognize it.
Are you getting any error-messages?
What is happening?
What is not happening?
Nov 11, 2010 | Western Digital My Passport Essential SE...
My home XP Pro computer keeps beeping trying to find the WD Passport 150GB drive
If you get no joy using the Troubleshooting Guide then try this...
You will need to check You Tube to find a Dismantle on your product and follow the step guide on here, the procedure should be similar.
Check 1st that your External HDD has an P.C. internal HDD inside, from You Tube, before dismantle of your External HDD. Connections for an Internal Laptop HDD may have same connections as P.C. not sure though.
Once your happy that it has continue reading and follow the step guide on the link below.
My neighbour has the Seagate FreeAgent Desk 500GB, and in under 2 weeks it started to beep and was not recognized by any Laptop or P.C. if this is the same for you with any FreeAgent Desk series ( not GO series, different procedure for GO products). You maybe in luck click this link, you may have to register in the forums to view thread.... http://www.yo-lid.co.uk/forum/viewtopic.php?f=32&t=84 Thread can be found in 'Technical' under 'General Technical Issues',
Only attempt this option if you have important information saved in it, you will find that you will be charged by your product makers for retrieval of any information saved on your product.
Thumbs up please if it's any use to you Thank you.
Aug 28, 2010 | Western Digital WD Passport 250GB Portable...
My computer is not recognizing my Western Digital passport elite what do I do?
Have to check it in the Device Manager that the new device have been detected or not. It may happen that when the external HDD connects to the computer for the first time computer cannot detect it as it is not properly formatted in proper file-system. Open Computer Management and click on Disk Management and format the device correctly to operate.
Jun 21, 2010 | Western Digital WD Passport 250GB Portable...
MY PASSPORT ESSENTIAL WD1600ME-00 is not recognized by plug-and-play in either of my HP Desktop Windows computers (One with XP, one with VISTA). Power light comes on when attached to any USB port. Device...
You run MS Windows Update to download and install the latest OS updates. Your WD external HDD should be detected after OS update.
For non updates system, try to connect WD to the USB Port where it worked before. If you have 4 USB ports for instance, try to connect it to these ports one try at a time. Windows XP might have assigned one USB port for your device before when it was working just fine.
Feb 02, 2010 | Western Digital WD Passport 250GB Portable...
My western digital Passport 320Gb usb drive is not detected
hi ,
looks like u primary hard drive is inside the laptop and so should be displayed as c : drive ,
and the reason , the external hard drive is not displayed seperately is csue ., the external HD  may be added as slave to the internal HD .,
can u tell me ,make a right click on c:/ drive and choose properties : and tell the totalsize dispalyed
Jul 23, 2009 | Western Digital Passport WDXML800UE...
WD Passport (External Hardrive) Not being read by computer at all
If the usb hub is not recognizing the external drive it means you may need to install the hub drivers for your pc. Especially if you're running XP since xp finds the drivers own its own. Go to control panel, click on add hardware. Make sure the device is connected to the pc. Go to Device Manager, scroll down till you see yellow symbols or question marks. Highlight the yellow ?'s click next and Voila it will tell you what is missing. Hope this helps.
Good Luck =)
May 30, 2009 | Western Digital Passport WDXML800UE...
Getting an old Dell Dimension to recognize a WD Passport
In the end, I assigned a different drive letter to the device and it worked.
There's a lot of info out there on how to assign a letter. Here's one link:
http://lifehacker.com/software/windows/change-windows-drive-letters-167525.php
Feb 17, 2009 | Western Digital WD Passport 250GB Portable...
My wd2500 is no longer recognized by my xp pro notebook. I have used 5 different USB cables. Te power light keeps pulsing. I did get one error message with one cable that said "te usb device attached...
I assume you did reboot your computer and plugged the external HDD to other USB port but still has this issue.
I can only suggest to recover your external HDD to different computer dont rush it, sometimes it takes time to load.
Jan 04, 2018 | Western Digital Passport WDXML800UE...
Western Digital My Book Essential Edition (WDG1U5000N) 500 GB Hard Drive Logo
186 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Marcin
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
