Question about Soyo P4X400 Dragon Ultra Motherboard
I need the diagram for the pwr sw leds reset sw
I change my motherboard to a new case and don,t have the diagram to plug in all the lead wires and can,t start up my pc please help gotta be using friends pc to go online HELP ME PLEASE!!!!!
  • 905 Answers
On the motherboard if there is the pin setup section that you plug them into it will indicate what each pin is for. it may not be the same as your old one but will be basicaly the same setup with + & - connections for the hard drive light ,power light , power on/off, speaker ect...
Posted on Oct 09, 2008
New motherboard will not power up. Power supply OK, No manuals or CD. Need pinout and label on Motherboard for motherboard to case connections for an ACER ECS EG31m V.1.0
[1 2 3 4 5 6 7]
[8 9 10 11 12 13 14]
[Orange White NU NU NU NU NU]
[Green White Blue White NU NH Green Orange]
NU = Not used/No wire
NH = No hole
1-2 HD
8-9 PWR LED
10-11 PWR SW
13-14 LAN
May 24, 2012 | Acer Computers & Internet
Problem with the MSI 7050 v2.0 (HP dx5150) Motherboard Front panel wiring colour diagram please.... PWR LED, HDD LED, PWR SW, AND RST SW
You should read manual of the moterboard, there is wiring diagram that you need. But however, i suggest to you - take it to the expert, if you don't know how to do it.
May 20, 2011 | Intel Motherboard
I need the wiring diagram for power,reset,lights
there is no need for the wiring diagram
if you check *********** board properly
you could find written in small font like
PWR SW for power switch
RST SW for rese switch
HDD LED , PWR LED etc
May 05, 2010 | Wintergreen Lindows Webstation (M810L11L)...
Need connecton diagram for ASUS P4S-LA motherboard.
if colours don,t match up. your main connectors hdd/pwr/reset remove the front panel on the computer. and check from the switches located on the front panel. or you could use a multimeter and test for continuity. if you have one.
you should have green/white red/white orange/white Or blue white.
Mike @ Compurepair.
Mar 15, 2009 | ASUS P4S800-MX Motherboard
New motherboard
You don't say what case you are using. If it is proprietary and the front panel header is all in one connector, you can carefully back the connector pins out of the block using precision screwdrivers. I keep a bunch of two pin connectors from junked machines so I can create individual connector sets when changing motherboards (eg, PWR SW, PWR LED, HDD LED and RESET). This also requires that you know the pinouts of both the old board and the new one so you can get everything connected properly.
Very doubtful you will ever find an adapter to change from one front panel block to another.
The 9-pin connector probably uses a spacer pin between the legs of the PWR LED, while it seems the 6-pin does not have RESET.
Dec 30, 2008 | Asrock P4i65G Motherboard
I have a e-machine. Model w3619 a friend sold to me. He unplugged the two power leads that lead from the power button on the front panel from the motherboard.Where do i reconnect them?
The correct wiring plan for this computer is as follows:
Pwr Led Pwr Sw N/C
X X X X O
X X X X X
HDD Rst N/C
Note : N/C = no connection, top row has no pin, bottom row has a pin but not connected.
when you plug in the Pwr Led and HDD connectors, a light should come on, if it doesn't , turn off the pc and turn the connector round on the pins, re -power on your pc.
Nov 30, 2008 | E-Machines (308714) Motherboard
Front panel connections
PWR > PWR (aka PWR SW), HDD LED > HDD LED, RST > RST (aka RST SW and Reset)
May 31, 2008 | Iwill XP333-R Motherboard
Reset/power/led etc..lead connections
on most motherboard it is possible to read there to set the wires.
hope this helped a little.
May 15, 2008 | Compaq Presario 5000 PC Desktop
hi bob i need to know the motherboard's serial number then shouldn't be a problem finding the service manual for it with all the information you require some motherboards got that information imprinted near the pins if you look close enough
Aug 05, 2007 | EliteGroup P4M800PRO-M Motherboard
Soyo P4X400 Dragon Ultra Motherboard Logo
362 people viewed this question
Top Soyo Computers & Internet Experts
Roy May
Are you a Soyo Computer and Internet Expert? Answer questions, earn points and help others
