Toshiba Satellite P25-S5092-display problems
My screen on the left has a bright pink color all the time-approx. 2 inches wide. Could you tell me what causes this and can it be fixed? My laptop is almost 5 years old. Also, at certain times my fan on the bottom is very loud and I have to shake or move the laptop around to get it to stop, any suggestions on how to fix this.
Thank you,
Victoria
  • Terry L. Freeman
    Terry L. Freeman May 11, 2010
    It is possible that the display and the fan are going out. 5 years for a laptop is very good!
    The display properties need to be checked to see if a portion of a theme could be causing the problem, but it is most likely that the display needs to bve replaced. Sometimes a deguassing can fix this problem.
    Now, the fan making noise may be the bearing is dry of lubricant & very easy to replace, also.
    You need to go to a certified technician to fix these problems.
Modem problem
Posted on Oct 20, 2008
    Problem Solver:
  • 12 Answers
What you need to do is replace the backlight to solve the display prob and as far as the fan and being that old you should replace the fan
Posted on Oct 13, 2008
The monitor on my Toshiba P25-S5093 does not have any display of any kind; all black. I have display using external monitor.
Does the display show anything before you enter windows? If yes, then press the key to transfer video back to your original screen once you enter windows. It should be the function key "Fn" + F5 - F8. looks for the icon which shows a monitor or says "CRT/LCD".
If it doesn't show anything before you enter windows I'm afraid your screen needs to be replaced. Good luck.
Mar 08, 2011 | Toshiba Satellite P25-S5093 Notebook
I recently installed windows seven and now it doesnt give me the option to connect to the internet via wifi,i also looked in device manager as it is not listed.
Hi, the problem here is that your pc was not designed for windows seven. You can try downloading the latest driver for your device, or you may need to use a plug in to usb, to get wifi. Also for windows 7 you will need a minimum of 2Gig of memory.
Aug 29, 2010 | Toshiba Satellite P25-S5092: P25-S5092...
Own a Toshiba P25-S5092. Will not power up. Goes
Power problems may do this, also if the CPU's heatsink has been loosen or detached, the CPU may me getting to hot and will self shutdown.
Aug 07, 2009 | Toshiba (K000006610) for Satellite P25...
Toshiba p25-s609, is it dead pixel?
i can tell u the solution but u hav 2 giv me money
Apr 15, 2009 | Toshiba (K000006610) for Satellite P25...
I can't read my screen because it it too llght
You should have a Fn button on your laptop, and pressing that, combined with the button that has a sun on it should raise your screen brightness, if your screen only has one brightness setting, and it got much darker all of a sudden, your LCD lamp probably went out, in which case it is probably better to buy a new laptop, because those are expensive to replace.
Feb 26, 2009 | Toshiba Satellite P25-S507 Notebook
Media Test Failure?
go in to the bios and change ur boot order so the harddrrive is before the network or lan
Nov 23, 2008 | Toshiba Satellite A40 Notebook
Bluetooth, Driver
All the toshiba products are her >< just select you model and then the driver you want
Oct 04, 2008 | Toshiba (K000006610) for Satellite P25...
Toshiba Satellite P25-S5092/ Computer will come on, but screen will not work. Wondering if it is most likely the LCD screen itself, the backlight or something else.
If you have deduced that indeed the Toshiba Satellite P25-S5092 will boot and therefore operational except no display on the screen, you can always verify by connecting an external monitor. You of course would need to press Fn + F? (the F key with the small monitor icon).
As to the LCD screen having no display, often this could either be the CCF lamps (cold cathode florescent) and/or the inverter that powers it. One way to verify this is by shining a flashlight obliquely to the screen and a portion of your desktop would show albeit very very dark. Often, it is the inverter that fails. In some instances it could even just be a cold solder, loose connection or capacitors that have dried up, leaky or blistering.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
May 18, 2008 | Toshiba Computers & Internet
Toshiba satellite p25-s5263 black screen
i guess your laptop's display chip is not working.
check it with the other one..
thanks
Apr 04, 2008 | Toshiba Satellite P25-S5263 Notebook
Toshiba Satellite P25-S5263 monitor problem
It could be a driver problem perhaps. Does the post screen show at all or is there absolutely nothing?
Dec 29, 2007 | Toshiba Satellite P25-S5263 Notebook
Computers & Internet Logo
399 people viewed this question
David Payne
David Payne
