Home | Kirby | Ultimate G Bagged Upright Vacuum | Kirby sentria belt ins...
Kirby Ultimate G Bagged Upright Vacuum
Problem for Kirby Ultimate G Bagged Upright Vacuum
Kirby sentria belt install
By one2man on Oct 08, 2008
I have a hard time engaging the belt when i try to put it on the roller pin in the carpet attachment. it doesnt want to go in the drive shaft and work. when i turn it to theon position it is such tension on the belt that I give up,Whats the no hastle way of putting on a sentria belt?
Best Solution
posted on Oct 25, 2008
Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
Make sure to follow this sequence (starting from the nozzle off and green arrows on the knob and label matching):
1. Turn the knob all the way to match the red arrows (make sure that as you are doing so the hook inside of the nozzle hoes through the belt and stretches it - you will feel that knob is prettu hard to turn)
2. Put the nozzle on the unit and fix it in the place with the latch.
3. Turn the knob back to match green arrows
There are some more detailed instructions and pictures on goodvac.com
YOU'RE DONE
Solution #2
posted on Nov 21, 2008
Not Rated)
xxCeeCee741x
Rank: Apprentice
Rating: 0%, 0 votes
how do i put the belt back on carpet cleaning attachment took it off to clean it and cannot get it backtogether
Was this helpful?
Yes
No
Popular Solutions for Kirby Ultimate G Bagged
Questions and Unsolved Problems for Kirby Ultimate G Bagged
Do you recommend Kirby Ultimate G Bagged Upright Vacuum?
Answer
Answer
I trying to put the shampooer on the vac. This is my first time using the shampooer!
Answer
show me what part of the kirby is the attachment to shampoo my stairs.
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Kirby Ultimate G Bagged...:
Top Vacuum Experts
Rank: Guru Guru
Solutions: 632
Experience: im jack of all trades but a master of none! and being an old f*rt you get to learn a fair old bit
Ask Me
Find more Vacuum Experts
Top Vacuum Repair
(502) 348-4900
Authorized Dyson and Miele Service center. Work...
VACUUM SOLUTIONS
(877) 822-8227
When you browse our large selection by vacuum...
Vacuum Cleaner Shop
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
