Question about Arris SURFboard SB4220 Modem
Motorola SB4200E I have a 4200E that will not connect by ethernet.  It is definately the modem as I connect to another without any problems. Are there any known faults with the ethernet sockets or the soldering to the board going dry?
  • DW190 Oct 09, 2008
    I dont think the USB would help as I want to flash the modem with new firmware and dont thik this can be done via USB
    Problem Solver:
  • 11 Answers
I'm guessing that the unit is bad and may have taken a surge, if it's plugged into the wall directly, or a poorly grounded cable connection...things can happen...all my "stuff" is surge protected and or hooked up via UPS to keep the power clean. I have heard of no issues with this product...but it's not unheard of. cold solder joints usually show up right away for example if you wiggle the RJ connector does the network connection light go on and off as you wiggle...that is a sign of a bad connector or a cold solder joint...but the process of soldering the boards these days are all automated so chances are that the soldering is ok. have you tried via USB?...
Posted on Oct 09, 2008
I got a NETGEAR router and I have been trying to get my Motorola SURFboard to recognize it. I had the USB connection installed and the NETGEAR uses ethernet, so I tried to install the ethernet but my...
The Cable modem must be disconnected from the computer. You cannot use USB and Ethernet at the same time.
1. Turn off power to the Cable Modem and the Netgear Router. Do the same with the computer.
2. Connect an ethernet cable from the modem to the router's WAN (Internet) port.
3. Connect another ethernet cable from one of the remaining 4 LAN ports on the router to the computer's ethernet port.
4. Now power on the Cable Modem ONLY. Wait for the modem to sync up with your service provider
5. After about 2-5 minutes power up the router and wait about 1-2 minutes.
6. Now power on your PC.
Check and see if you have internet access. If not you may have to uninstall any cable modem software related to USB connection. if this is the case, then you may have to repeat steps 4-6.
Since most cable internet providers do not use proprietary connection settings, your internet connection should be up and running without changing any settings in the router or modem.
If this does not resolve your issues, we can continue to work with you.
Nov 29, 2010 | Arris SURFboard® SB5101 Cable Modem
Can I connect a Desktop PC without WIFI capability to the ethernet connection and at the same time connect a WIFI router via the USB connection?
yes 4 sure......i am currently using internet connection from Ethernet port...and i am broadcasting my internet connection to my friends using a router connected to my PC.
So you can connect both of them simultaneously...enjoy..!!
Sep 23, 2010 | Arris SURFboard SB4200 Modem
I'm trying to connect an xbox 360 to the ethernet using a cable modem. We're having trouble. Is this possible? We connected the modem to the cable hook-up and connected the ethernet cable from the modem to...
Make sure your modem or router is compatible with XBOX. I think Microsoft has a lost of working modems and routers. If this is all clear, connect the eth.cable to the modem/router. Power up the modem FIRST then the xbox. All this without any cd/dvd in the tray.
Usually as simple as that...
Jan 12, 2009 | Arris SBG1000 Wireless Cable Modem Gateway...
Multiple computers, 1 modem, ethernet
If I were you, I would definately go with a wireless network. If you purchased a good router (Linksys or Netgear) you shouldnt experience loss of speed or connection. (If everything is installed correctly) If you need help, you could call the company who provides the router, Internet service Provider, or Geeksquad.
Dec 28, 2008 | Computers & Internet
Help deciding about xbox live please
doing it the way ur talking bout u should not have any problems
Dec 18, 2008 | Belkin (F5D7230-4) Router (587009)
Motorola surfboard modem
try connecting it though the usb and installing the usb driver came on a cd with the modem.
Or connect to the ethernet and install its driver from the motherboard cd
Aug 29, 2008 | Arris SB5100 SURFboard DOCSIS 2.0 Cable...
Motorola SURFboard SBG900 loss ethernet connection
Please remove the program of your router and re install it again and it will work..
Good luck
Johnson
Jan 03, 2008 | Arris SURFboard SBG900 (49402201900) Modem
Arris SURFboard SB4220 Modem Logo
333 people viewed this question
Top Arris Computers & Internet Experts
Jerry
Jerry
bobkoure
Level 1 Expert
Are you an Arris Computer and Internet Expert? Answer questions, earn points and help others
