Question about GE Kitchen Ranges
Problem with my GE Kitchenrange (Model J35CMW-1)
I have an error message on my dispaly : SE:-0!
I've read somewhere that it could be a faulty sensor. Is that right? If so, how can I repair it?
Thanks!
  • 3 more comments
  • Ker0Z3n Oct 09, 2008
    Thanks for the solution, but......
    I did it twice... and still have that error code.
    The range itself is approximatly 15 or 16 years old. I also changed the electronic controtl module 2 times and the upper heating element once (5 years ago).
    Model number is GE J35CMW-1
  • Ker0Z3n Oct 17, 2008
    Model number is right! The label is on the front lower right side of the range frame, just behind the drawer.
    Maybe it's a canadian model? (I live in Canada).
    Anyway, I was told that it would cost around 50$ to get a new sensor. Maybe I'll try that first.
    Thanks again!
    OK thanks anyway...
    I'll go shopping for a new one this weekend! BTW your answer made my wife very happy ;-)
    Thanks!
  • Ker0Z3n Oct 21, 2008
    Hi....
    I found out that the problem was the temperature sensor. I tested it with an electrical tester (Ohm) and I got a null reading.
    So I went on to buy a new sensor. Found one at 50$cnd. Took me about 10 minutes to change it....
    OK I know, I should have tought about buying a new one.... but I still hope that it could work for another one to two years.....
    Hi....
    I did replace the sensor and know it's working. Took me about 10 minutes to complete the repair!
  • 750 Answers
Keroz3n,
Welcome to Fixya,
You said, you have an error message on my display : SE:-0! I've read somewhere that it could be a faulty sensor. Is that right? If so, how can I repair it? Thanks!
How old is the range?
And the model number?
Usually this will cure and an error code.
This can reset the system.
Turn the breaker off to cut the power for 5 minutes.
Then restart the breaker and try the range.
It's like rebooting your computer when its acting strange!
Usually it corrects some error problems if they are not serious.
Or they are sometimes just a glitch.
Let me know how it works out.
Huuum,
Please remember to leave a rating
Posted on Oct 09, 2008
  • 2 more comments
  • Neil Golan
    Neil Golan Oct 09, 2008
    Here is an interesting report I just read!
    Repair or replace?
    When to pull the plug on your old range
    Typically, you'll also find a troubleshooting section for more-serious problems
    in the owner's manual.
    Should you pay for a repair or buy a new model?
    The answer depends mostly on the age of your range,
    how much you bought it for,and the cost of the repair.
    Follow these guidelines:
    When a repair makes sense.
    If your range is under warranty or less than four years old ,
    paying for a repair makes sense.
    Note that ranges under warranty might require service from a factory-authorized technician;
    readers have found them on a par with independent repairers.
    When a repair might be a wise choice.
    If your ranger is out of warranty and is four to seven years old,
    it might make sense to pay for a repair. Customers generally pay $100 to $200 for a repair.
    But you might want to buy a new model even at this stage,
    given that today's models have added features.
    Higher energy efficiency is another plus: Energy Star-qualified models made after April 28, 2008,
    are 43 percent more efficient than conventional models built before 2001 and 56 percent
    more efficient than those built before 1993.
    When it pays to replace.
    The repair costs more than half the price of a comparable new range.
    Data also shows that it doesn't pay to fix a less-expensive range
    eight or more years old.
    Thanks to better recycling programs, less than 10 percent
    of ranges you replace are likely to end up in a landfill.
    Thanks for giving me the opportunity to help!
    Please do not for get to give a rating before you sign off!
    Thank You, HUUUM
  • Neil Golan
    This model number is not listed!
    Did you get it off the label in the range it self?
    There is a label sometimes metal label if it's real old in the door jam of the range.
    Or when you pull out the storage drawer in the free standing ranges!
    Or in a slide in range you need to remove the bottom panel if in=t is removable like mine!
    Ask me advice if you can not find it!
    On the cover of the user guide is not the model number but the series #.
    In the user guides they tell you where to find your model number!
    Waiting your answer.
    Huuum
  • Neil Golan
    Neil Golan Oct 17, 2008
    Keroz3n,
    The range itself is approximately 15 or 16 years old.
    You also changed the
    electronic control module 2 times
    (5 years ago).
    I'm sorry to tell you that it's time to save your money!
    You are putting good money into bad!
    Get a new range and lower your utility bills!
    The new one will pay for itself in a few years and you can do what you enjoy rather than spending
    endless money on your appliances.
    I under stand you!
    I keep cars for 10 to 18 years!
    but this is a waste of your good hard earned money.
    Now that you told me what you have, my advice to you is step back a moment
    and think what you are doing???????
    This is not good or good for you to dwell on!
    Sincerely, Huuum
    This range is not listed in any repair manuals or parts houses that I searched for you!
  • Neil Golan
    Neil Golan Oct 21, 2008
    Keroz3n,
    Hello, Ker0Z3n
    I have been looking high and low for your model in all the Canadian repair manuals sites and us too!
    Unfortunately I can not find the model J35CMW-1.
    I do recognize that the code SE, is sensor. The SE:0 is ancient in the appliance error codes and I did not find it. I really tried hard to find a copy of your manual online. But not one reference available. Unless the number is read wrong by one digit??
    You need to remember that most people will not spend any more than
    $200-$250 MAX . in the life time of their range and that's new or old!
    So this means there is no market for parts that old, unless they are similar to, or can be used for other models too!
    This makes it very hard for people like you and I to keep fixing our home appliances.
    In cars I have found almost any parts for my more than 20 year old cars!
    But in appliances it's sometimes better to replace.
    And save on utility bills.
    Most new appliances will pay for them selves in only a few years.
    I'll keep looking till it exhausts me, cause I do not like being beaten by any Adamant object.
    Only flesh and blood can beat me!
    Huuum
    I'll let you know if I come up with anything
    Huuum
    Please remember to leave a rating!
-SE- error message
Sensor Error , qualified Tech can help you , could be anything from a fan to a faulty switch
Dec 03, 2013 | Samsung Microwave Ovens
How to unlock a phillips flat panel tv
The Factory code number is 0 0 0 0 If the code has been changed, You can select to reset it using the Setup Code either under the channel blocking or setup code section.
Once there, Press 0 7 1 1
You will be given a message "INCORRECT ACCESS CODE" Press 0 7 1 1 on the remote again
Next, "enter your new access code" shows on screen.
Now you can enter a new 4 digit code. (write it down somewhere)
Read more: http://wiki.answers.com/Q/How_do_you_unlock_a_Phillips_TV_using_the_on-screen_menu#ixzz1eP9NktX3
Nov 22, 2011 | Philips Televison & Video
My lg intello wd 8074fhb washer will be in the middle of wash cycle and an error message comes up se ..Can you tell me what this error message means..
LG's 'SE' means 'sensor error'. Sorry but you will need a repair visit I fear ;-0(
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C.
Jun 12, 2011 | Washing Machines
I have made a folder to store some messages in my phone and now i have forgotten the password to unlock it. What should I do?
Hi!Did you change the default password of your phone?If not,try to enter or type the default password (0000) or (000000) to unlock your folder.If ever the default password is not working,you may try this other secret codes for motorola.
Motorola
c350 english languge
menu
setting
1 1 5 2 6
(T190, T191, T205) master code
- 19980722
- 20010903
P2K test menu:
*#06#, menu, menu, 048263*
Test comands:
32*116*1*0*0 - read phone code
32*118*1*0*0 - read security code
18*0 - factory reset, phone code off
18*1 - master reset
54*18*1 - full phone reset
10*0*6 - select 900/1800
32*279*1*0*8 - model
32*383*1*0*0 - flex version
Hard reset MPX200, MPX220 - blue button + power on
Feb 25, 2011 | Motorola Mobility ROKR E6 Smartphone
I,ve a LG VM-1433IFD model and I,ve had it unblocked and now its coming up on screen as OE fault help
The LG error code OE simply means “the pump is blocked”. Presumably the water isn’t being emptied properly.
Causes
A pump, or filter blockage is the most common cause but it could be caused by other faults such as a faulty pump, or even a blockage in the drain hose or somewhere else in the system.
Thank You
Sep 08, 2010 | Washing Machines
The wiring has snapped from the mic to the xlr socket on the microphone is there somewhere i can get a diagram to fix it? the mic is a se electronic z3300a
It uses a standard balanced XLR wiring which is 1= ground/shield, 2= (+ve) hot and 3 is (-ve) cold. Do not bridge pins 1 and 3 as this mike uses phantom power. Please let me know if this helps.
Nov 18, 2009 | SE Electronics Z3300a Professional...
KONICA 7020 GIVES ERROR MESSAGE F-35-1O WHAT IS WRONG
hi
error f 35 is fixing error,try to reset on 25 mode
Jan 08, 2009 | Toshiba E-Studio 3511 Color Copier
Error code
found sensor inside oven no continuity am ordering new sensor should fix problem
Jan 08, 2009 | Ovens
Kitchen Ranges Logo
183 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
