Digital Radio Digitor by Sangean PR-D3L The LCD display has slowly been failing and is now 95%failed. Is there a spare part or other magical solution available
  • Anonymous Nov 25, 2008
    I cannot tune my radio manually and the station memory select buttons are all set on the same station and can't be moved
I have fixed the display on a Sangean PR-D3L that had faded to less than 30%. It was a bit involved and required pulling the radio apart and desoldering a metal sheild off the back of the display board to reveal the "zebra strip" connector for the display. I used a bit of heat and pressure on the connector strip where it contacts the circuit board - presto 100% display. Don't know how long it will last tho'.
Posted on Jul 14, 2009
How do I delete a station?
Just "insert" another station into the spot.
Your tuner does not like "blank spots: in the station line-up.
Mar 07, 2015 | Sangean PR-D9W Radio Tuner
I have a 3 band
try the hard reset method ,that is, remove the battery and then insert the battery and switch the radio on ,it will help you.Otherwise try to tune the radio to required frequency by changing in the settings and try...
Jul 07, 2008 | Audio Players & Recorders
Why did the ac power quit working on my pr-d7? the dc still works fine.
there is a diode D301 must be opened, replace it should be ok, but have to check your AC adaptor in advance.
Nov 17, 2014 | Sangean PR-D7 Digital Rechargeable AM/FM...
Sangean ATS-909X Volume control has failed (no longer trims volume). A little pressure on the control will sometimes restore its function. Sounds like a bad solder joint or a cracked board. Any th
A similar problem with SANGEAN ATS-909x I have too.
When you touch the volume control ever hear the full volume.
Tap volume control side, the sound is normal.
Suppose a poor connection on the control volume.
Correction here in Slovakia is not guaranteed.
Receiver has a serial No: 0C000451 is under warranty, purchased through E-Bay from Taiwan, made 1/2011 and purchased in 2012.
It seems that I remains only a decoration.
Milan
Translation by GOOGLE
May 11, 2012 | Sangean ATS-909X Professional Multi-Band...
Sangean PR-D3L AM-FM Radio RF gain intermittantly dropping. Would like circiut Diagram
The most common cause is a dirty rf controller, buy some electronic contact cleaner and take the unit apart and spray the compound into the pod and rotate control back and forth, repeat two or three times for maxium benifit.
Mar 02, 2012 | Sangean Audio Players & Recorders
I HAVE A PR-D3L, CAN I SET THE CLOCK TO 12 HOUR MODE? IF SO, HOW DO I GO ABOUT IT? THANKS....JOHN.
  • If you have any comments you can feel free to leave them here.\
  • Hope this helps and thank you for using FixYa.
Regards, Tony
Aug 18, 2011 | Sangean ATS 505 AM/FM/SW Radio
We have a client with the Sangean PR-D8, the problem are that its keeps corrupting the file on the SD card when recording using the Timer setting it show that its record but when complete the MP3 file...
I have similar problem with this set - recordings are corrupted. Every few seconds a fraction of a second is cut off. Probably it's a problem with SD card. Someone reported this problem in amazon.com customer review for Kingston 4 GB Class 4 SDHC Flash Memory Card SD4/4GBET
Feb 09, 2011 | Sangean PRD8 AMFM Radio
Sangean PR-D3L - How do I change between 12 and 24
Archer, I have read the entire PR-3DL manual and there appears no mention of a 12/24 hr setting, unlike certain other Sangean radios. The instructions for setting the alarm do not mention 'a.m.' or 'p.m.' .
Apparently, the clock is a 24:XX:XX display only.
Apr 05, 2010 | Sangean ATS 505 AM/FM/SW Radio
Sangean ATS 803A
Don't be mis-led by the working display. I had the "no power" problem with a working display too. I measured the voltage of the two AA batteries. One was 1.33 volts and the other was only 0.76 volts. Replaced the weak AA and everything worked. I suspect the 'enable' circuitry fails around/below 2.1v.
Sep 27, 2008 | Sangean ATS 808A AM/FM/SW Radio
LCD display has gradually disappeared, now I have nothing. I have had this problem with other sangean products. Is there something that can be repaired? If so where can I send it for repair? Please...
This is a defect in the radio. Reportedly this issue was resolved in later vamps of production, but it still seemed to persist. We discontinued this model due to this exact reason. At this time there is no other solution and the factory can not tell us what the problem was and simply pointed to the LCD.
Feb 20, 2008 | Sangean PRD2 AM/FM/TV Radio
640 people viewed this question
 Grubhead
Grubhead
