Question about Delta JT160 Shopmaster 10 Amp 6 Inch Benchtop Jointer
Delta shopmaster saw blade stuck down and won't go back up
I am using a borrowed saw that I am using to cut interior trim. The saw arm is stuck down and won't go back up. Any suggestions? I have looked all over it to see if it has a switch or something.
  • Anonymous Jan 10, 2009
    How do I load the blade?
Sounds silly, but on the right side there is a blue knob.Push down on the saw handle and pull out the blue knob. That should release the saw arm.
Posted on Nov 25, 2008
I need a owners manual for a delta shopmaster radial arm saw
with out a model #, here is what I found for you...hope it helps.
Jan 15, 2012 | Delta Radial Arm Saw
Why does the saw cut at an angle?
The table is not perpendicular to the blade travel. Use a small level to make sure the machine is vertical , then set the table. Make sure the blade control guide is working.
Jun 22, 2010 | Delta BS100 Shopmaster 9 Inch Bench Top...
Blade does not make straight cut and turns.
it may be the blade is worn out and has lost its edge on one side or it could be its too lose, on the other hand if your pushing the wood through to fast not letting the blade cut it first it wont cut straight
Mar 27, 2010 | Delta BS100 Shopmaster 9 Inch Bench Top...
My blade on my Delta BS100 Shopmaster 9 inch bench top band saw wanders. It is impossible for me to cut a straight line even with a fence. I have adjusted the blade guides several times as well as the...
Check and see if one of the guides is out of alignment or if the blade is worn. Either one can cause the problem since you already checked the tension and guides. If the guides are worn they won't hold the blade true.
Dec 30, 2009 | Delta BS100 Shopmaster 9 Inch Bench Top...
Problems with my band saw bs100
Look for any gouges in the metal surface that have metal projecting above the milled surface. Also, file or grind away any sharp edges along the miter gauge track. If the cut surface is very irregular, the blade may have overly coarse teeth, or the blade guide rollers may not be holding the blade firmly allowing the blade to wander while cutting. Hope this helps.
Jun 27, 2009 | Delta BS100 Shopmaster 9 Inch Bench Top...
Delta bs100 runs backwards
It's wired wrong. You'll have to change the wiring at the motor to correct this.
If it's a new saw, I'd exchange it for one that was put together right.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take a moment to kindly rate this post....thanks!
Apr 06, 2009 | Delta BS100 Shopmaster 9 Inch Bench Top...
Where can I purchase blades for the Delta BS100 bandsaw?
You have a couple options, you can buy direct from Delta by going to Dewaltservicenet.com and clicking on the Delta icon on the top or easier go to Ereplacementparts.com and down at the bottom of the site you will find accessories click on the saw blades and pick what you want. Let me know if you need more info.
Mar 20, 2009 | Delta BS100 Shopmaster 9 Inch Bench Top...
Delta shopmaster bs 100 band saw
Hi, This Delta saw uses a 59 1/2 inch blade ( 1511mm).
Good Luck, this should Fixya!
Mar 06, 2009 | Delta BS100 Shopmaster 9 Inch Bench Top...
Delta JT160 Shopmaster 10 Amp 6 Inch Benchtop Jointer Logo
639 people viewed this question
Top Delta Saws Experts
Jim London
Jim London
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Delta Saw Expert? Answer questions, earn points and help others
