Question about Compaq Presario 5000 PC Desktop
A diagram of the inside of my computer
My 15 yr old nephew stared messing with so wires in the tower of my computer and now he screwed it up so when i turn it on it starts to beep
  • Jeff Strader
    Jeff Strader May 11, 2010
    wires on the inside or outside?
    Master:
  • 538 Answers
Those cables only go to certain places..it is almost impossible to plug them in oddly..hopefully the computer did not go on at any time when mis wired,
Posted on Oct 09, 2008
    Problem Solver:
  • 7 Answers
He removed the RAM .... just plug it back in. its a chip and then you'll see three spots inside the computer on the mother board it looks like there r three colums or something.. plug the ram chip into ther push hard. and if its not the ram then somebody kicked the tower hard and the processor is damaged or out of place.
My screen on hp 1907 went blank, my 13 yr old nephew started punching all the buttons on the monitor over and over and hitting the on and off button. Now I am having a problem with my screen going black...
I think it's pretty clear he messed something up. Try checking the VGA cable (the blue one) that's hooked up to both you computer and monitor. Check if any pins are bent or broken. If not, make sure they're securely plugged in and try booting up. If it still doesn't work, then I'm afraid he may have knocked some connection in the motherboard out of whack. I hope it's just a slight VGA problem. Hope this helps!
Apr 16, 2011 | HP w1907 LCD Monitor
How to remove the pump from the motor on a Kenmore dish washer model 363.14572000
Steps:
1)Shut off power to the dishwasher at the circuit breaker and turn off the water line to the dishwasher by locating the shut-off valve, which is typically inside the cabinet beneath the kitchen sink.
2)Remove the four screws that hold the dishwasher kick plate in place.
3)Locate the motor,which is typically centered beneath the bottom spray arm.
4)Lower the dishwasher door and take out the bottom dish rack.
5)Remove the spray tower and spray arm assembly by unscrewing the bolt through its center.
6)Take out the filter immediately beneath the spray tower.
7)Disconnect the motor wires from the wiring harness,making a note of which wire connects to which terminal.
8)Disconnect the pump assembly and drain hose from the motor.
9)Remove the motor from the base of the dishwasher by unscrewing the four bolts holding it in place.
10)Repair or replace the motor and reinstall,taking care to reconnect the wires the same was as they were attached to the old motor.
11)Attach the pump and drain hose to the motor.
12)Replace the filter,spray tower and lower spray arm assembly.Reattach the center bolt in the spray tower.
13)Restore electrical power and turn on the water supply valve.
14)Run a test cycle to check for leaks underneath the appliance.
15)Replace the kick panel in front of the dishwasher.
Jul 31, 2010 | Kenmore Dishwashers
Where do i connect everything inside the pc?
Be calm, all wires only plug where they belong to and most times they're color coded.
1. Two cables connect to the monitor, one is a power cable and the other is a video cable, most of the times its VGA cable which end in a connector with 15 pins and a blue plastic cover, search for a blue rounded corner trapezoid in the computer tower, once you find it carefully instert the cable from the monitor and tight the screws that are at each side. image
2. If your keyboard and mouse are USB then connect them to any avaiable USB port (these are squared and the computer has many), It may be that your keyboard and mouse end in round conectors this are called ps/2 and look like this, purple is for keyboard and green for mouse.
3. This far you have connected most common input output, if you also have speakers connect its jack in the green audio socket.
Finally connect your computer to the power, this should be all.
May 13, 2010 | IBM NetVista A30p PC Desktop
System appears to come up, but the monitor is like it is not receiving a signal from the computer. Monitor works, tried on another system. have tried two different monitors on computer, same thing. also I...
see if one of the little wires inside the wire end from the monitor that goes into the tower is bent or messed up. If one of those are missing, the whole monitor is messed up. Also look on the back of the tower for the |O| picture. It should be blue.
Mar 20, 2010 | Acer Aspire M1641-U1521A PC Desktop
When computer sitting unused and then mouse is
The humming might came from the exhaust fan inside the power supply or the exhaust fan of the tower housing case of your desktop, there must be some loose screw, also check the Processor fan.
Jan 28, 2010 | HP Pavilion Elite d5000t ATX Customizable...
My monitor wont connect to my new dx4822 its a 6 yr old sharp flat screen ll t15a4-s lcd when i plug it in it says no signal put it back on my old tower its fine its a plug n play so i thought
If there are no issues on the cables that you are using then you should try to check if you have video card problems or you should try if it works on your on board VGA, tighten the screws when you plug it to your computer.
Jan 08, 2010 | Computers & Internet
Dorr locks keep clicking(sounds like relay)my aunts nephew messed with radio.now doors wont lock when she pushes the lock buttton. she has to manually lock the doors.
nothing like an amature fixing a stereo to screw up the electrical sys take the car to the stereo shop and have them fix the wires the kid hacked into
Dec 31, 2009 | 1995 Jeep Cherokee
15 yr old GE TBX18SA refrigerator. Not cooling.
Remove the screw , on the left side of the control panel , and pull the panel , from the left side , outward to the right . You should now see , slightly to the right , from the middle , a black screw , a hole with slot , and slightly higher to the right , a hole with a white piece , with a hole in it . Now , the hole with the slot , turn with a screwdriver , until you hear/feel a louder click . Turn this slowly . When you hit the right click , the refrig will shut off . Remove the inside rear freezer panel ( and ice maker if equiped ) , by removing 3 or 4 screws , pop off the grill piece , and may have to twist the ice maker receptical slightly , to remove . If you do not see the heater on ( red ) , below the coils , then the heater is most likely the problem . pt # WR51x464 . Your old one , has a glass tube , but the new one , is calrod . I believe 2 screws hold this heater on .. If the glass heater does come on , then the problem is the defrost timer ( the piece you turned with the screwdriver ) which is removed , by removing that black screw and bending the panel out slightly . Pt # WR9X520 .
Nov 03, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Compaq Presario 5000 PC Desktop Logo
569 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
