Replaced K image drum,K toner had 68% left,now says replace K toner.
  • jminnick Mar 16, 2009
    I have an OKI C5500n and the Drum Life warning keep coming up. I know the drums are new so how can i reset them?
  • 4,338 Answers
There is probably toner spill near the sensor. Take out the K toner unit,careful it is 2 parts, toner resevoir and drum, Then clean the toner spill. The K sensor is located on the right inside wall acrooss from the k Drum. Try to clean the sensor with a cottom swab and alcohol. Hopefully this will clear it. If it does not, you need to have it serviced,Tthe sensor board is held in with 14 springs and it is a bear to deal with.
Good luck,
Joe
Please remember to rate Techs who assist you for free :)
Posted on Oct 09, 2008
Drum light is on
This usually means that you need to replace the drum on the printer. Most likely it's under 10%, because that's when the warning light comes on. Depending on the printer, you may have 50-150 pages before it completely fails. I would advise to get it replaced soon.
Reminder: A drum is NOT the toner. It's normally a device that may house the toner. Or a separate part.
Apr 02, 2011 | Brother Office Equipment & Supplies
Getting black lines on copies on Brother MCF 6490cw all-in-one printer/copier. How can I clean the rollers or internal mechanisms which are making the lines?
More likely than not, it's either the imaging drum or the toner causing these lines, and not left over toner on the rollers. Try replacing the toner and see if that works, if not, put the old toner back in and try replacing the imaging drum
Mar 04, 2011 | Brother Office Equipment & Supplies
Black lines down left side of paper
It's either bad toner or the imaging drum needs to be replaced. The imaging drum amy have scratches or be dirty.
Mar 04, 2011 | IBM Network Printer 12 Laser
Replace imaging unit
HI!
Replace imaging unit is the drum that needs to be replaced!Open the door and remove all the cartridges,take out the waste toner bottle on the left and then pull out the drum by its handle!Put in the new drum,out in the waste toner bottle and then the cartridges and close the door!
Enjoy!
Jan 13, 2011 | Samsung CLX-3175FN Color Laser All-in-One...
K image drum
The drum and toner cartridge are two separate items. You need to replace the drum.
May 26, 2010 | OKI C5150n Led Printer
Where is the toner overflow located? Is it part of the toner cartridge?
Residual toner image gather in imaging unit
Open the left cover.moves to the left, remove the entire unit. There is a white plastic cap on the drum unit. .separate unit cylinder - unit developing releasing the blue clips. You can now remove the toner residual.
This operation made if the print quality is good, otherwise it will be replaced drum unit.
Oct 10, 2009 | Canon imageRUNNER 1310 Printer
Replaced black toner..now printer won't print any
In this case, actually it is not the Black toner that got depleted. Here the message being displayed indicate that one of the color Toner supply need to be replaced as it got depleted and currently the printer is printing in Black and white using the Black toner cartridge.
in this case, to troubleshoot these issues please try performing the following and check for the results.
* 1. Check for the level of the toner cartridges:
a) Check from the HP Toolbox application. Here are the steps to be performed from your PC:
* Access the Toolbox software.
* Select the Status tab.
* Select the Device status option.
Here you can check for the supplies status in terms of the % remaining for each toner cartridges.
b) By checking the supplies status from the printer control panel display.
On the printer display when printer is in Ready mode the supplies status can be checked from the supplies level indicator. Each toner cartridge and the Imaging drum level will be indicated by a bar which varies according to the level of the supplies present.
c) Print the supplies status page from the printer.
* On the printer control panel menu, press Menu .
* Use the (Right Arrow) button to select Reports, and then press Enter .
* Use the (Right Arrow) button to select Supplies Status, and then press Enter .
If any of the color toner cartridges and the Imaging drum have a low supply level replace them with genuine HP print cartridges.
The part numbers of the consumables are as follows:
* Black print cartridge - Q3960A
* Cyan print cartridge - Q3971A
* Magenta print cartridge - Q3973A
* Yellow print cartridge - Q3972A
* Imaging Drum - Q3964A
Sep 23, 2009 | HP LaserJet 2840 Printer
Just replaced drum and toner and now faxes don'y
if your toner and drum have been at an angle , toner will only be on the left side.
here's the fix.  Remove drum cartridgewith toner in it and move it gently from extreme right to extreme left, do this three times and your image should be ok
Aug 13, 2009 | OKIFAX 2600 Fax
Oki 5150 color are not print right
You need to replace the magenta drum. Just because there is life left; it's possible it is scratched. Also, take a cotton ball dip in alcohol and wipe the LED's off when the cover is open; those black things that are hanging down from the cover. Also, make sure your drums are installed in the proper spots (magenta in magenta slot). If the toner "rubs off" after it prints... then the fuser is defective.
Jun 25, 2009 | OKI C5150n Led Printer
Replaced toner in a Canon image runner 2200 copy comes out blank
1) you do not dump toner into the drum! Juo dump it into the toner unit.
2) didi you after replacement put the blue toner handle (right from toner unit) into the left position?
May 27, 2009 | Canon (6981A002AA) for imagerunner 2200,...
591 people viewed this question
k24674
jasbo
jasbo
