Question about Dryers
Washer overflows washerover flows. water valve is ok also checked pressure switch. its ok
  • john gagnon
    john gagnon Oct 08, 2008
    hi just 4 year old G E run of the mill
  • 750 Answers
Hello docjhon174
Welcome to fizya,
You said, you washer over flows. water valve is ok also checked pressure switch. its ok
Can you send your brand ,model number and the year or age of your washer?
Waiting for this important info!
Huuum
Posted on Oct 08, 2008
  • Neil Golan
    Neil Golan Oct 09, 2008
    I need the model # which you can find on any top loader under the the bottom of the washer door when its in the open position and on the
    door jam of the tub, if you squat down with you eyes level to the top of the front end of the washer you will see the label with the model and serial #.
    then I can under stand the mechanics of your washer. Waiting your response!
    Huuum
Water won't shut off. Over flowes
usually a result of bad coils in ur water inlet valve u can check it with amulti meter for ohms and for proper voltage, it seems ur valve is not opening up as it suppose to when it reaches the correct water level and its possible it can give a good meter reading electrically yet still be defective manually mechanically0 would also check the water pressure switch as well if the tube is damaged or disconnected u can have over flow issues also
Washer fills with water and overflows:
The water pressure level switch is a pressure activated switch that is used to determine the correct water level in the tub. This part is normally located behind the control panel and will have a hose or air dome tube that connects it to the tub. On washers that use an electronic control, this switch may be located at the sump area below the tub. As the water fills in the tub it will compress the air in the tube and push against a diaphragm inside the switch. The switch will control the water inlet valve and turn the valve off at the correct water level. If the tube has a leak, not enough pressure may be created to activate the switch and the washer may overfill. If the switch is defective it may also cause the machine to overfill. To determine if the switch is bad, you should first eliminate the air dome hose as a problem. Look for signs of cracks or worn areas on the hose. Remove the hose and submerge in water. Seal one end and blow air into the other end and look for bubbles. Check for an obstruction in the hose as well. If the air dome hose appears to be ok, then the water level switch may be defective.
You can test it with a meter and with a manual test? ( first locate it in the panel, it has a plastic clear tube hose going into it, remove that tube from its connection, now put another small tube or hose into the slot where it was and have the machine set to wash cycle with water in it. Blow into the other end of the tube.
If the machine starts to wash. the pressure switch is more than likely good
( No wash- then THE DIAPHRAGM IS BAD AND SWITCH HAS TO BE REPLACED).
The other item to check would be your water inlet valve. Check it for continuity with a multi meter it should show Ohms or a closed circuit. To test it when water is overflowing unplug the unit and see if it still overflows or continues to fill. If it stops when unplugged. Then it is not a water inlet problem but an electrical signal problem going to ur water inlet valve. Possibly from the panel or board. You can also do a live volt test to see if it is getting the full 120 current, but be sure to unplug unit before testing as this is a live test.
Also another trick to check the water valve, is to first cut the water off and remove the hoses off the back of the washer. Then one at a time point the hoses inside the washer tub and turn the water back on. If you don't have good water pressure, turn the water back off and remove the strainer that should be in one end of the hose. Inspect the strainer to see if it is stopped up, clean it and reinstall it. Now repeat this test. If you have good water pressure now, reinstall hose and your problem is fixed
By the way my advice is free cuz God is good!
WATER PRESSURE SWITCH: This switch keeps your washer from overflowing. It is responsible for shutting off the power to the fill valve and redirects the power to the timer to start the washing machine running once the correct water level has been reached. Meter check ur water pressure switch?
( No wash starts - then THE DIAPHRAGM IS BAD AND SWITCH HAS TO BE REPLACED) another test u can do is Remove the hose and submerge in water. Seal one end and blow air into the other end and look for bubbles. Check for an obstruction in the hose
Jun 15, 2015 | Washing Machines
Washer overflows
Feb 13, 2014 | Frigidaire FGZ831A Top Load Stacked Washer...
Servis m9503 washer dryer continuously fills with water,pressure switch and tube are ok,pressure chamber cleaned out and drain hose right height
if u checked the pressure switch aand its ok then look at your water inlet valve?
Nov 20, 2013 | Equator EZ 3612 CEE Front Load...
Water will not turn off
see this causes and fix it. God bless you
Water Inlet Valve If the washer is overflowing and power is shut off to the washer, the water inlet valve has failed. Replace it.
Pressure Switch If the washer is overflowing the pressure switch might be defective. The pressure switch is attached to a small tube which is attached to the outer wash tub. As the water level rises the air pressure in the tube increases, once the set water level is reached the pressure switch turns off power to the water inlet valve. Check to be sure the air tube to the pressure switch is clear before replacing the switch.
Low Water Pressure from House Supply If the washer is overflowing the water pressure to the water inlet valve might be too low. The water inlet valve requires a minimum of 20 psi to shut off properly. If the pressure is lower, the valve may not close fully when the power is shut off. This results in the valve leaking water into the washer and causing it to overflow.
Oct 16, 2012 | Maytag Washing Machines
Washer overflowed after moving Load Capacity Switch from Super to reset and then to Large load?
On this model of washer you have 4 separate components that could cause overflowing. The water valve, pressure switch, pressure switch hose & the air dome. If you have to turn the water off to prevent overflowing, I would recommend replacing the water valve. If you can turn the timer off & the water stops overflowing, I would recommend checking the pressure switch, hose & air dome.
Jan 16, 2011 | GE Washing Machines
Myn washer always overflowes as it filling it wont
This is usually the pressure switch. Also you could check the water inlet valve if water is still flowing in the machine after it stops. There are free videos on testing these components at www.appliancehelponline.com/servicemanual.html
You can also punch in your model # for diagrams
Mar 18, 2010 | GE Washing Machines
FH has shown up on my whirlpool duet washer GH9150, water was shut off and now it is stuck in cycle and will not stop
FH = (No water detected entering machine or pressure switch trip not detected)
If after 30 seconds the control does not detect water entering machine, the valves will be turned off and the error code will be displayed.
OR
If the control has turned the water valves on, and after 8 minutes, the flow sensor has detected 10.5 gallons of water passing through it, but has not detected the pressure switch trip, the valves will be turned off, and the error code will flash.
Press PAUSE/CANCEL twice to clear the display.
Possible Causes / Procedure
• If there is no water in the unit:
- Make sure that both valves at the water source(s) are turned on all the way.
- Check for plugged or kinked inlet hoses or plugged screens in the inlet valves.
- Verify inlet valve operation.
• If there is water in the unit:
- Verify drain pump operation.
- Verify that the pressure switch hose is in good condition and properly connected to tub
and pressure switch.
1. Verify there is not a siphon problem.
2. Unplug washer or disconnect power.
3. Verify wire harness connections to inlet valves, pressure switch, drain pump, flow meter,
and Central Control Unit (CCU).
4. Check all hoses for possible leaks.
5. Plug in washer or reconnect power.
6. Verify pressure switch operation.
7. Verify flow meter operation by blowing air through the part and measuring the resistance.
8. Verify CCU operation by running a Diagnostic test or any cycle.
Replace failed component.(Which will be the pressure switch if all checks out ok, above)
Nov 02, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Washer overflows after taking it apart
You may have missed something when putting it together. Take it apart again then check and properly install the following:
  1. Water inlet valve. It may not be able to shut completely when the electricity has been turned off. The valve may leak and drip water into the clothes tub. Water may accumulate substantially and overflow.
  2. Water level switch. This switch senses the water level in the clothes tub. It is usually a diaphragm device with a small clear tube attached between the switch and the bottom of the washer's outer tub. As the water level in the tub increases, the air pressure in the tube increases and activates the switch when the water reaches a certain level. When the switch is obstructed, it cannot tell the water to shut off and the machine overflows.Clear it from any obstruction.
Aug 23, 2009 | Kenmore Washing Machines
GE Washer WHDRR418E1WW overflows the tube. Yikes.
A washer that over flows in the fill cycle sounds like a faulty pressure switch. Part # WH12X10069 and 10 on this diagram. If it overfills the tub when the washer is off it's a faulty water valve. Best of luck Ryan
Feb 19, 2009 | GE WBSR3140DW Top Load Washer
Overflowing water
If the water comes out when filling, check your water valve by unplugging the washer when it is filling. If the water still runs, replace the valve. If the water stops, check the small tube that goes from the water pressure switch (in the consul) to the bottom of the tub. This must be connected without any holes or obstructions. If this is ok, replace the water pressure switch.
Jan 03, 2008 | GE WBSE3120B Top Load Washer
Dryers Logo
83 people viewed this question
Top Dryers Experts
