Question about Whirlpool GHW9400 Front Load Washer
Whirlpool 9400 Front Loader Washer Control Button Locked
Can't get my Control Button to Unlock.
Washer Won't Start or do nothing.
Unplugged and Plugged back in and pushed cancel>Nothing works.
Please Help
  • 2 more comments
  • shelby135 Oct 09, 2008
    Wonderful,
    You Fixed My Problem, Thank You So Much,
    Held the End of Cycle Signal Button for 3 seconds and it worked!!!!
    Thank You So Very Much, Your Very Helpful
    Will Recommend you to my Friends.
    Thanks Again
  • Anonymous Feb 12, 2009
    This fixed it right away! Who would think the instructions would be right there on the washer for none of us to find??
    Thank You
    Mine is the GHW9300 front load
  • gtclll Apr 17, 2009
    Why does this light- "control locked" come on in the first place?
  • Anonymous Mar 25, 2014
    washer will not start or cancel
    Genius:
  • 1,028 Answers
Find button with lock emblem beside it hold 3-5 secs
Posted on Oct 09, 2008
There it was, the directions printed right there on the front of the washer. So simple, who would have looked?? Thanks for you help. mine is the GHW9300P
Posted on Feb 12, 2009
  • Whirlpool Master
  • 19,396 Answers
Hi.
Please read the Fixya article below explaining how to fix the problems related to control lock on Whirlpool.
The front light lit on my Whirlpool dryer...
Regards..
Posted on Feb 22, 2010
The clean button blinks, yet it won't start?
I had the same flashing light problem first the normal wash flashing light then the others. I tried shuting of the breakers but nothing. I tried resetting the panel by pushing normal wash and heated dry simultaneously and nothing. So I took the six screws holding the front panel out and unplugged the ribbon type wires and plug and unplugged it several times to help make a better contact and I was able to get it to work right away. This may not work for all but I worked for me. It is very easy to do and it's worth a try if you're having the same problem. It took me less then 10 minutes. I had the problem for several days and could not use the dishwasher not mater what tried until I did what I described above. Now I have to see how long it lasts.
Jul 24, 2012 | Kenmore 24 in. 15689 Built-in Dishwasher
The machine's "Control Locked" light is on.
Did you try to push and hold the 'CYCLE END SIGNAL' button for 3 seconds?
May 02, 2010 | KitchenAid KHWS02R Front Load Washer
Door won't unlock
try the cancel button it will drain the water and release the lock
May 30, 2009 | Maytag Neptune MAH9700 Front Load Washer
WCVH6260HWW GE front load washer won't start - press the On button, then press Start/Pasue button and it goes beep beep, and keeps blinking, and washer does not start; the washer pump strainer has been...
no power to control panel checked outlet with another appliance it worked drained water from pump filter still nothing door locked and nothing on control panel
Feb 23, 2009 | GE WSXH208A Front Load Washer
Control lock light will not go off.
Do you have any error codes?
Does water remain in the washer after the final spin?
If water remains in the washer after the final spin, then the door will not unlock. Drain/Spin or Spin Only to remove any remaining water from the washer. The door should unlock at the end of the cycle.
Is the door locked and the Add A Garment light on?
If the Add A Garment light is on, then the washer door will unlock after the Pause/Cancel button is pressed once. Pressing the Start button will restart the washer at the same point where it left off in the cycle.
Is the door locked and the Add A Garment light off?
If the Add A Garment light is off, then the washer door will unlock after the Pause/Cancel button is pressed twice. The door will not immediately unlock while the cycle is running due to a possible high-water level in the washer, high-water temperature, tumbling or spinning. It may take up to five minutes for the washer to stop spinning and draining before the door will unlock. You will hear the door click when it unlocks.
If Pause/Cancel does not work:
  1. Unplug washer or disconnect power for one minute.
  2. Plug in washer or reconnect power.
  3. Re-select the cycle and press Start.
NOTE: If the error remains on the display, call for service.
Dec 19, 2008 | Whirlpool Duet GHW9150P Front Load Washer
''Control Lock'' won't ''unlock''
Press and hold the "End of Cycle Signal" button to lock or unlock the control panel. The instructions should be printed directly below this button. I hope this helps you.
Nov 14, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Control lock light on-door opens-won't start
Press 'control' + 'pause:lock' +
'temperature' for 5 seconds
OR
'end of cycle' for 5 seconds. Tell me which worked & rate me pl.
Apr 16, 2008 | Whirlpool GHW9150 Front Load Washer
Control Locked
you have to push a button on right side which tells you to hold down this button for control lock
Sep 14, 2007 | Whirlpool GHW9400 Front Load Washer
Whirlpool GHW9400 Front Load Washer Logo
1,091 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
