Question about Digital Mind Corporation HD-500 MP3 Player
My Xclef HD-500 will not boot up.
I have a DMC XCLEF HD-500 80gb mp3 player. It will not boot all the way up. All it does is get to the screen: "Portable External Storage & Music Jukebox." It will not get past this screen. I can turn it off and on and that's it. I tried letting it stay on for a while but this didn't help. Do you have any troubleshooting steps I can try or can I send it in somewhere to get it worked on? Thanks!
  • Cathi
    Cathi Oct 16, 2008
    Yes - mine is the same. The initial screen appears and the progress bar gets slightly less than quarter of the way along but no further. I can switch it off, but other than that - nothing.
    Thanks for any help offered.
    Betti
  • Anonymous Apr 26, 2009
    I have the same problem, and I haven't been able to fix it following the instructions. Is there a way to restore the firmware to it's original state, I mean, the one installed from factory??
My OH finally solved this himself today! You need to update your firmware - just Google for Xclef HD500 Firmware and you'll find plenty of sites. He went to www.emmeau.com/xclef and downloaded firmware version 1.097 from the firmware section. This is an oldish version but I gather the latest ones can give some bother - and all I was wanting was my Xclef working again. You'll find full instructions there, too, but you'll need to download a couple of files - connect the XClef by the USB port and the power adapter (very importan!!!t)and then copy the two files into the "Firmware" folder of the Xclef. (If you go to My Computer you can see the connected Xclef there as another drive of your computer, and can look at all the folders and files, as you'll no doubt be aware). Do a USB safe removal in the system tray and unplug the USB cable, power on the Xclef - the firmware will update and it switches itself off automatically. Power on the Xclef again, press 'Menu' key for a couple of seconds, go to 'set-up', then 'system', then 'system initial' then 'OK' then switch off the Xclef and everything should be fine next time you use it. HOPE THIS HELPS!
Posted on Oct 18, 2008
My hard disk was bursted i changed it but after that it does not work can somebody tell me what are the folders inside the hard disk
Posted on Mar 25, 2011
Hello: I have a DMC Xclef and the on-disc software
My xclef 500 hard drive just died after about 45,000 hrs, 7yrs of use. I was just barely able to retrieve the syst files off the disc and transfered them to another hd. Had a 160gig hd, but had to format it to 100 gigs for the player to use it. I have copies of the file folders that I could post to a site, if it allowed me to. Too bad this site won't let me post files.
Apr 06, 2011 | Digital Mind Corporation HD-500 MP3 Player
My 80 gig Zune will not boot correctly and freezes at screen 3 "Please Wait" displayed in english, french and spanish. Also it will not reboot by holding the back button and pressing the center...
Hi if your player is getting stuck on the 3 p lease wait screen you have a HD or HD ribbon issue. The HD ribbon can be replaced sometimes to fix the issue and other times the HD is going bad or has a bad sector in it.
If you need any more help, parts or your player repaired you can contact me threw my repair service web page at firehouse7777.weebly.com thanks
Nov 26, 2010 | Microsoft Zune JS8-00001 Digital Media...
Hi does anyone know where i can get a replacement battery for this,thanks joyce.
I buy my replacements form China on eBay, the battery type is the very common 18650 lithium ion rechargeable. I've had less than great results using the unprotected battery so now I'm trying the protected version. Expect to spend 3-4 dollars for the battery and about 3 dollars for delivery which can take a few weeks. The battery connection is unique to the player so you'll have to solder it to the new battery. I love these players (xclef HD-500) and they're not available anymore. I have a couple of these and would love to find some for sale.
Apr 02, 2009 | Digital Mind Corporation HD-500 MP3 Player
Boot up issues will not boot up from HD
IDE and SATA do not mix unless setup properly.
I would use the SATA one as main hard drive and set the other up as an external one on USB
Try resetting the BIOS to boot from CD
on ter lower part of boot screen will tel you the key to press to access the BIOS setup
Usually one of these keys
F2 CTRL+ESC or DEL
when in BIOS check and set to boot from CD
Nov 07, 2008 | PC Chips PCChips A13G+ v3.0 Motherboard -...
I have a DMC Xclef HD 500 I accidently formatted now Now anytime I turn it on it says not formatted. I believe that I need the original programing
It would depend on how it was formatted. Did you remove it from the player and format it on a computer? The Xclef requires a FAT32 format / partition. I've upgraded the drive in mine on two occasions & found the easiest way to format the drive (there's no easy way though a windows OS) is to use this utility . . . "fat32format" . . . http://www.crapcontrol.com/e107_files/downloads/fat32format.zip
Good Luck
Oct 03, 2008 | Computers & Internet
TRYING TO INSTALL MY ZUNE MP3 80GB
You need to download the software from www.zune.com before connecting your zune. Follow the setup instructions. After installation you connect your zune to the PC and the software should automatically detect it and continue the setup and update process.
Oct 03, 2008 | Microsoft Zune JS8-00001 Digital Media...
Grrrrrrrrrr
I hope you tried the slide on the right side that say's hold
Oct 01, 2008 | Digital Mind Corporation HD-500 MP3 Player
My Zune 80GB MP3 DIGITAL PLAYER
try to restart it or whatever try clicking The arrow button then up on the keypad. make sure you downloaded the software. and updated.
May 17, 2008 | Microsoft Zune JS8-00001 Digital Media...
Problem with my Archos loading up
this wont help but snap mines doing the same
May 14, 2008 | Archos AV 500 Digital Media Player
Digital Mind Corporation HD-500 MP3 Player Logo
1,048 people viewed this question
Top Digital Mind Corporation Audio Players & Recorders Experts
Computer Links
Jonathan Poston
Are you a Digital Mind Corporation Audio Player and Recorder Expert? Answer questions, earn points and help others
