Question about Bose LifeStyle 5 Series-III CD Shelf System
Can you tell me the fix?
Could you please let me know the fix? I have the same problem...audio drop...is this an op amp?
turns on no sound...what should I do?
    Genius:
  • 1,847 Answers
Please describe the issue in detail?
Posted on Oct 08, 2008
  • Legin Varghese
    Legin Varghese Oct 08, 2008
    Does the power LED come up?
    Did you try different source (input)
  • Bose Master
  • 19,396 Answers
Can you be more specific, tell me the model, and what is the problem.
  • Ginko
    Ginko Oct 08, 2008
    If there is no power at all, then check power cable and power outlet. Can be the fuse in the power board, inside, or the power board blown.
    If it starts, and if you have no sound at all, and you suddenly lost sound, maybe with a pop while amp was working, then you may have blown someting on the final amp section.
    Check also speakers and speakers cable, sure you did this already.
When I turn off the ignition on my 2001 Tahoe the amp continues to pull power. It does not turn off. In a couple of days it will drain the battery. To stop it I pulled the fuse. How do I properly fix it....
In order to answer this, it is necessary to know whether your Tahoe is equipped with the luxury sound system, the premium radio, or the sound system with rear seat audio.
Jul 14, 2017 | 2001 Chevrolet Tahoe
I have a Sony STR-V444ES receiver that is receiving what I believe to be a static discharge. When I turn on all components, I will receive a random loud popping sound that usually happens in the first 15...
The AVR have problem in its pre amplifier stage. Normally this type of cracking noise will hear because of faulty op amp (operational amplifier) ics. To repair such problems you should have through knowledge in electronics. And also need SMD rework stations Beacuse all the op amp ics are SMDs. If yo have such knowledge then i have added here the link to the service manula for your AVR.
Refer the page number page number 13 first. Its the Audio section blaock diagram of the AVR. you can see the the suspected ic in the top right corner marked as IC410. Which is the pre stage op amp for the frond left righ amplifier. You have to replace this ic( integrated circuit).
You can find the position of the ic by refering Page number 27. Its the input board . On the board you can see three ics with 8 legs(four in each side) On the left side. You have to replace the ic marke as IC410. You can find the schematic for the input board in page number 26. the The part number of the ic M5218AFP-T .
Refer the sevice manual to know how to carefully to remove the input baord.
http://sportsbil.com/sony/STR/STR-V/STR-V333ES_V444ES_V555ES_v1.2.pdf
If you need any more assistance feel free to conatct me through fixya.
Ajin
Feb 08, 2012 | Audio Players & Recorders
Hi Folks - I have a Roland Fantom G6 that produces no sound! Everything else seems to be fine - the display registers that I am hitting the keys & even the skip-back sampling feature produces a wav...
This probably is not a DIY repair... The audio comes out of the CODEC and is buffered by Op Amp used as filters and then goes through the volume controls, After that it goes to the jack board with buffer OP amps. First thoughts might be a damaged volume control, however, the "B" outputs don't go through volume controls...
About the only thing I would think you could do is to CAREFULLY open the unit and look for a loose cable involved with sending the audio to the volume control panel and then the cable that takes the audio to the jack board...
More than that you would probably need to take it to a shop equiped to troubleshoot.
Nov 23, 2010 | Roland FANTOMG8
What kenwood or any other EQ uses transistor or coils not op-amp
I can't speak to the circuit specifics under the hood of general purpose home audio equalizers, but they don't intentionally compress anything. Back in the day when audio magazines still reviewed such products they would have emphasized that anomaly if it existed.
As we all know, imaging is in the ear of the beholder. I would think a purist would shun EQ on principal.
I have no feelings either way but I have heard tube fanatics claim they are superior to solid state. Tomato / tomahto.
Apr 01, 2010 | Audio Players & Recorders
My amp turns on but the sound goes in an out
yes you have a internal fault of the amp. the circuit that puts it into safe mode is bad and that is a very small chip on the board know as a op amp. needs to be repaired.
Jan 25, 2010 | Alpine MRV-F345 Car Audio Amplifier
Amp will not put out sound The red light comes on
Dec 28, 2009 | Solid Audio Formula Series F2000 2-Channel...
Difference between audio amplifier & OPAMP
An audio amplifier is a general term that applies to any amplifier specifically designed to cover the audio spectrum, and usually referres to power amplifiers (of any power from micro headphone amps (like the headphone audio amplifier circuit in an ipod) . to power amps like the ones used at rock concerts that are several thousand watts).
An OP-AMP is an Operational Amplifier, which refers to a type of amplifier circuit. Op-Amps can amplify audio, but are not restricted to it. They are used in many things from audio circuitry to signal conditioning, and sensing from all kinds of equipment from seismometers, to light sensors, temp sensors, insturmentation amps, lab amps... RF amps etc...
There are many many different types of op-amps that are designed for many different applications. Mostly the parameters are frequency response, gain, and input/output impedance.
Op-amps usually come in an IC package of some sort. The most common are 8 pin DIP package types.
Op-amps do NOT handle power. (although there are some hybrid power op-amps available, they are specialty devices) The term op-amp refers to the ability of the amplifier to be manipulated mathematically by external values. (i.e. resistors set up to add, subtract, or multiply the value of the input signal) Hence the term OPERATIONAL amp, because it is performing mathematical operations on the signal. (They were first used in analog computers, allowing the voltages to be added, subtracted, and such, and displaying the resultt by directly reading the voltage value).
They handle only small signals, and require being followed by a POWER amp to do anything useful, such as drive a spleaker, or a relay, or a transducer.
For your question, most all audio amps consist of stages.
There is an input/pre-amp stage (this is usually where the eqalization, signal processing, and bass/trebel tone controls are implelented) and a power amp (output) stage that takes the signal fromthe pre-amp and raises the voltage and current to a sufficient level to drive speaker.
The input/pre-amp stage is most usually composed of a series of op-amps. Op amps also are responsible for the bass/trebel control, and the EQ.
There will most usually always be several Op-Amps in every Audio Amp.
Jun 12, 2009 | Audio Players & Recorders
Hi, Sorry does your question relate to a display problem or a sound problem? If it is a display problem let me know the colour of the perspex, strange question I know but it does help me identify the unit.
Dave
Jun 30, 2008 | Bose LifeStyle 5 Series-III CD Shelf...
SOUND CUTS OFF AT HIGH VOLUME AND POWER LIGHT FLASHED RED
You need to check the DC voltage across the power and ground terminals of the amp. If the voltage drops below ~11v when the amp shuts off, you need to check the power/ground wiring and fuses.
If the voltage remains above 11 volts, you may have a problem with the load on the amp (incorrect ohm load, shorted speaker, shorted speaker wires...).
Jun 13, 2008 | Pioneer GM-X542 Car Audio Amplifier
Bose LifeStyle 5 Series-III CD Shelf System Logo
55 people viewed this question
Top Bose Audio Players & Recorders Experts
Invebo
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
