Question about Dryers
Maytag Gas Dryer Model # LDG7304AAE can't find access into dyer
My Gas dryer doesn't heat but my first issue is I don't know how to find access to get inside of the unit see inspect gas valve etc. How do I get inside of the cabinet?
-Pat
  • 943 Answers
HI pat its easy to gain access . theres 2 screws at the bottom of the frontpanel. remove these screws pull front towards you . now you have access. thanks the appliance doc. please rate my answer.thanks
Posted on Oct 08, 2008
Dryer won't shut off.
Will the timer advance in the NO HEAT mode? If it does advance you would know it has something to do with the temp alright but if it don't advance in No Heat then the timer motor is bad in my opinion. And it can fail by more than one way. Open winding OR stripped motor gear.
Aug 30, 2012 | Maytag Dryers
My maytag gas dryer LDG7304AAE timer quit working runs forever no heat
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 10, 2011 | Dryers
Gas valve on dyer will not open
heatman101
Aug 01, 2011 | Maytag Dryers
Dryer is about 5 years old. Has begun to squeak loudly when clothes begin to spin
Are you comfortable taking the dyer apart? There are just a few simple screws to remove. It sounds like a bad blower wheel. If you follow the link you should be able to trouble shoot the issue.
http://sites.google.com/site/sublimeappliancerepair/washer-will-not-spin/agitator-woes/dryer-will-not-work/how-do-i-get-inside-my-dryer/gas-dryer-quits-heating/more-gas-dryer-enlightenment/gallery-of-dryer-parts-locations-and-diagrams/frigidaire-gibson-kelvanator-dryer-101/kenmore-whirlpool-englis-roper-dryer-notes/ge-dryer-repair/maytag-norge-amana-crosley-basic-repair-info
Mar 01, 2011 | Maytag Atlantis MDE6400AY Electric Dryer
No heat for my gas dryer. Maytag LDG7304aae
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Sep 20, 2010 | Maytag Dryers
Dyer is not heating maytag dryer D8000
heatman101
rtw
Sep 02, 2010 | Maytag Dryer Lint Filter Screen 33002970
Maytag-dryer\model number -- Ldg7304aae
This is the heating element. they are easy to replace by removing the back cover. UNPLUG it from the power source first!! The part is cheap to.
Apr 28, 2010 | Maytag HYE3657A Electric Dryer
My Maytag Gas Dryer model LDG7304AAE runs but won't heat. I have no idea what I'm doing but can follow directions well if anyone can help.
Hi
Things that could stop a gas dryer from heating:
- glow bar igniter, thermal fuse ( not all models ), coils on the gas valve, gas valve, thermostats, motor heat switch, timer, selector switch, sensor.
Please check all the above components.
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
Jun 17, 2009 | Dryers
Maytag Gas Dryer LDG7304AAE won't heat
Probably a high limit fuse. Check on the burner shroud for a 2 wire thermos. They should have little resistance. If so replace. If they are open, check for a restricted vent. Remove front panel and clean out area below filter.
Nov 12, 2007 | Dryers
Dryers Logo
293 people viewed this question
Top Dryers Experts
