Question about HP PSC 2210 All-In-One InkJet Printer
Scanner failure during the initalization/starts up.
When i turn on my Hp psc 2210, The initalization starts then i get the message as Scanner failure, Turn power OFF and then ON again.
Same problem repeated when turned ON again.
  • 1 more comment
  • lausl2000 Oct 21, 2008
    When I power on the printer, there is a rattling sound like some mechanism in the printer is stuck. It will rattle for a minute, then the display shows ' scanner failure, Turn power off then on again'. But it doesn't work even after I've taken the steps. Now my printer is totally not working . Am I suppose to bring it to a repair store? Has anyone sent to a repair store and got it solved. how much?
  • Anonymous Nov 21, 2008
    wtf throw away?
    stfu wtf are saying men?
  • Anonymous Dec 07, 2008
    The print and copy functions work good. Whenever I try to scan it tells me that the scanner is not operational. Naturally my warranty is long expired, and I bought it from Office Depot which is two strikes against me,
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 115 Answers
Sound as if your scanner is broken..
Could be something in there stopping it from moving, the motor could be bad.
It might have Home Positioning errors, causing this error.
To get it Fixed? The machine is about 140 dollars on Amazon?
The company I work for, the first hour is 125 (I do not know how much it cost to repair these)
Unfortunately these little ink jet printers are not designed to be repaired. They are considered throw away.
Sorry
Posted on Oct 25, 2008
SCANNER FAILURE
The issue is with hardware of the printer.
Scan feature is most expensive and sensitive part of the printer.
I suggest you to contact HP support. If the printer is under warranty you may get a replacement printer or else they may give you a better option.
If not on warranty you may try this workaround:
  1. With unit off, press the 'Cancel' (pink button) and 'Color' (green button).
  2. This will start the printer in a diagnostic mode. Press '1' to run the diagnostics.
  3. Press 'Enter' or other keys as directed by the display prompts. When you don't know what to press, the 'Enter' key usually works. Some of the keys called for (for example 'Plus' and 'Minus') are not on every psc 2210 keyboard. They are mapped to one of the "directional" keys just above the numeric keypad area next to the 'Enter' key. Keep trying keys till one works.
  4. After all the diagnostics, the display will either go blank or display 'Initializing...' . Wait 10-20 seconds to make sure it isn't doing anything else then press the 'On' key.
The printer should start without the scanner error and the grinding/chattering noise.
Leave the printer on because the next power cycle brings the chattering noise back.
But, when it does, the procedure above seems to fix it every time.
PSC 2210 scanner failure HP Enterprise Business Community
Feb 18, 2014 | HP PSC 2210 All-In-One InkJet Printer
(scanner failure) and flash top lighet
the printer can't saw the scanner driver that's why the motor that or servo make a sounds.. or your scanner driver corrupt..
you need to uninstall you current driver
and then restart your computer
...and then install again ..
May 20, 2009 | HP PSC 2210 All-In-One InkJet Printer
Hp psc 2210xi all in one
uninstall and reinstall printer driver maybe the scanner driver has been corrupt..
May 12, 2009 | HP PSC 2210 All-In-One InkJet Printer
Self-test issue with HP psc 2210 all-in-one
No fix, a new scanner will cost as much as a new machine IF you could find a new scanner assy
Feb 20, 2009 | HP PSC 2210 All-In-One InkJet Printer
Hp inkjet all in one model 2210 scanner failure
I'm havign a problem with my scanner to this product i bought before (hp psc 2210xi all in one printer). Before my computer is window XP when i bought this printer and its win XP too. Now im using Win Vista im having a problem with my printer. I can use or i can't use my scanner couse its not compalitble the both product.My question can u pls give me the drive or the down load to make this two (my computer and printer to be compatible in my vista.Is there a site or upgrade download site that i can found to Win VIsta printer for me to download?Pls its very kind if you can halp me .
Thanks a bunch,
Jhesscca
Aug 25, 2008 | HP PSC 2210xi All-In-One InkJet Printer
I can't scan
This document applies to the PSC 2210, PSC 2210v, and PSC 2210x. When you see the scanner failure message, turn off the PSC 2210. Wait a few seconds and then turn on the PSC 2210. If you see the message again, please contact HP Support. http://h10025.www1.hp.com/ewfrf/wc/contacthp?lc=en&cc=us&docname=c00055511&dlc=en&product=79499&rule=45570&lang=en
Dec 04, 2007 | HP PSC 2210 All-In-One InkJet Printer
Problems
Switch the unit. let it rest for half an hour. While it is resting check the manual for any 'faults' list. Look for a 'reset' command - may be mean pressing several buttons while the machine is off and then with the buttons still pressed switch on the machine[you may need two hands and a nose or three hands for this ;-)] If still out of luck go to places for further info HP technical support team or www,fixyourownprinter.com
Jul 05, 2007 | HP PSC 2210 All-In-One InkJet Printer
Have problem with hp psc 2210 scanner.
pls take the machine to a repairs center,it is thier job!save your worries for other troubles
Apr 02, 2007 | HP PSC 2210 All-In-One InkJet Printer
HP PSC 2210 All-In-One InkJet Printer Logo
513 people viewed this question
Seeker5211
Seeker5211
