Question about RCA DRC8335
DVD player completely locked up
We just keep getting "hello" on our DVD player's screen. The DVD tray will not open and we have a DVD stuck inside of it. We have unplugged the unit but it returns to its frozen state when we plug it in. We have pushed every button on the unit but nothing makes a difference.
  • 1 more comment
  • spalmer Oct 13, 2008
    We just keep getting "hello" on our DVD player's screen. The DVD tray will not open and we have a DVD stuck inside of it. We have unplugged the unit but it returns to its frozen state when we plug it in. I have pressed and held the on/stndby button and it clears, but as soon as you try to open the dvd tray it says "hello" again
  • chelot Oct 15, 2008
    I am having the same issue. Did you get it fixed?
  • Elaine Torkelson Oct 17, 2008
    I have the same problem! I will try calling RCA.
    Nothing in the manual helps.
    Problem Solver:
  • 5 Answers
I called RCA yesterday, and they said that they are recalling my model # because it is defective. I am sending it back in. It's under the warranty so I will get a new one. Hopefully, it won't be the same model--I couldn't understand the person on the phone very well. I'll have to call again one day about it to ask someone else that I can understand. So if you have the Hello problem, you need to write down the model & serial numbers and call RCA. They won't talk to you without those numbers.
Their phone number is 1-877-805-0519. They close at 7 p.m.
Posted on Oct 23, 2008
    Problem Solver:
  • 7 Answers
The cause of this problem appears to orginate in the units Power Supply board. The The 470uF 16 V capacitor in loaction C226 opens and causes the 5.1 Volt supply to drop down to about 3.6 Volts. I fixed one of these units back in early August of this year by replacing the capacitor with a new ESR type capacitor of the same value. The unit has been plugged in and operating for the past three months since the repair. So if you are handy with a soldering iron, the repair can be accomplished in less than an hour.
Posted on Oct 22, 2008
DVD tray is stuck
If your DVD tray is stuck, that simply means there is a problem with the mechanism that is controlling the tray from the inside part of the player.
For you to fix this, get the appropriate screwdriver,
open the back cover of the player.
you will see a mechanism by the side of the opening and closing of the tray.
Carefully examine the mechanism, and you will detect what is faulty on the mechanism.
You can replace the faulty mechanism or better still replace the whole mechanism.
Ensure the disc tray is properly seated.
yest it with a DVD disc before you couple it back together.
Take care
Jun 18, 2010 | Televison & Video
Dvd stuck in machine will not play or open to remove movie
there might be something hooking the disc tray that is prevent it from opening.
The solution to this problem now is to, get a screw driver, unscrew the screws on the player, open the player cover so that you can gain access to the disc stuck inside, remove the disc and check for what's preventing the player from ejecting.
Take care.
May 30, 2010 | Panasonic DVD-S35 DVD Player
Trey locked
There is a lock on this on the remote or end the menu system I do not remeber witch. You can unlock this software if not you need to unlock it hardware witch gets a little tedious.
May 24, 2009 | Sony DVP-NS700P DVD Player
Won't power up. Disk stuck inside. Can i open that tray to rescue my rental?
take a small flat head and pry the door open if not the only other way is to unscrew cover and manually push tray open
May 13, 2009 | Panasonic DVDS97S DVD Player
Sanyo dvw 6000 dvd/vcr player
DVD loading mechanism doesn't load completely that's why opens after attempt of loading.
You need to open top cover of unit and inspect loading belt might be lose, tray timing can be out of phase, some wire got stuck with tray while loading etc.
Oct 02, 2008 | Sanyo DVW-6100 DVD Player/VCR
Not closing
Hello, with mechanical problems with sophisticated systems of gears etc, the only way thate one can fix it is if you send me a digital picture yourself. To access the inside of the DVD player, you will have to get a handyman to open the DVD player up with a screwdriver, by undoing some screws which hold the cover to the player itself. Then, with the player's circuit boards (The Green/brown Boards with weird components on it) showing, take around 5-6 photo's of the loading tray and the playing tray.(Where the disc is when watching a movie)In the time being, open the layer's cover as instructed before, and look at the inside of the tray for any broken plastic, debris or anything stopping the tray from opening. Good luck!
Oct 05, 2007 | Sony DVP-NS305 DVD Player
Locked dvd tray.
To unlock, manually press and HOLD the open/close button & the stop button simultaneously, and HOLD them both down until the lock picture disappears.   The DVD will eject when you press the open/close button.
To lock the DVD inside the machine, repeat the same step, and it will lock it inside.
Apr 07, 2006 | Panasonic DVD-A110 DVD Player
RCA DRC8335 Logo
194 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
