I hav a RCA model D52W25 its 52" it has convergence problems dont know how to setup the color things can u help??
  • 5 more comments
  • krispytorres Oct 09, 2008
    i dont know how to get the convergence setup on my menu i hav a RCA 52 inch tv
    the model number is D52W25 or a D52W23 im not sure
    can u help??
    cant i just do it with the controller??
    cuz im not very good at taking parts apart then putting them back together
    i heard that on other tv's u can make a cross appear with the controller and then u could rearange the colors can i do this for this tv??
    also their is a curve on the top and bottom of my tv....how can i fix this??
    i was playing video games then a couple minutes later the tv got like some wierd shadows of green blue and red. and this one guy came and he said it has to do with the convergence, how do i get to the convergence with my controller??
  • krispytorres Oct 11, 2008
    can u tell me wat to do step by step??
    please i need an answer its urgent!!!
  • krispytorres Oct 12, 2008
    when i go to the menu i cant find nothing that says convergence
  • 2,071 Answers
The problem you have is the convergence STK chips IC i have a picture guide an a testimony how they solve the convergence problem;
Just click below for picture guide a do-it-yourself guide;
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
or
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
or
http://www.repairfaq.org/sam/tvfaq.htm#tvtvrep
Hope it may help you;
Regards,
VOTIT
Posted on Oct 12, 2008
  • 10,594 Answers
O please dont go to service mode for convergence adjustment as its highly technical job for an expert only. You cant make it mate until you are qualified to do so.
Your tv needs to replace THIS board only to work fine again, thats all.
Need further info, let me know.
Posted on Oct 09, 2008
  • Shahid Electronics
    Shahid Electronics Oct 09, 2008
    I forgot to write, TV has convergence IC failure problem.
    Shahid Electronics Oct 10, 2008
    hope you received solution email.
    President:
  • 1,263 Answers
Using the remote controller go into your set up menu. there it will list options for the convergance this you can either select auto adjust or manual adjust selet manual adjust wihich will give you 2 options either vertical or horizontal adjust ment in each option just adjust the cross hairs till you only see white on the cross hair this is proper adjustment.. please rate this
    Genius:
  • 1,269 Answers
You can try the Auto Convergence feature of your TV. Your TV’s picture tubes might have been disturbed during delivery or after you moved the TV, causing the color in your TV to be out of alignment. The colors adjust by starting auto convergence.
The Auto convergence feature automatically adjusts the TV’s tubes (this may take several minutes, after which you can make fine adjustments to the convergence settings); Red convergence displays the Red convergence screen, allowing you to use the arrow buttons to align the red and green images; Blue convergence displays the Blue convergence screen, allowing you to use the
arrow buttons to align the blue and green images.
IMPORTANT: Auto convergence works best once the TV has warmed up for
at least an hour. If you've just unpacked your TV, it's a good idea to repeat
the Auto convergence function when the TV's been running for at least an
hour.
1. Press OK to begin auto convergence.
2. When the auto convergence is complete, the Red center convergence menu
appears. The cross in the middle of the screen should be yellow. If it is not,
use the arrow buttons to move the red cross to overlap the green cross. Press
OK when adjustments are complete.
3. The Blue center convergence menu appears with a cyan cross in the middle
of the screen. If it is not, use the arrow buttons to move the blue cross to
overlap the green cross. Press OK (the TV tunes to the last selected/available
channel in the channel list).
    Master:
  • 505 Answers
Click on the following link :
http://www.riddledtv.com/repair/RCA.html. Go to the following section
(2) (3) (4)
(5) Stretched Image at top and bottom edge very distorted. Reheat all the surface mount solder points on the Small Signal Board. Then realign the set including convergence menu. To enter service mode: power off the set for 10 sec, then hold down Vol- and Ch- buttons for 10 sec. See this link: Alignment Procedure (pdf)
Also download the Alignment procedure pdf file. Hope this will help you. Please let me know if the information was of any help to you or you need further assistance.
Thanks
  • Indrajit Roy
    Indrajit Roy Oct 09, 2008
    Please go though this website. It answers different kind of problem with HDTV
    http://www.popularmechanics.com/technolo...
  • Indrajit Roy
    Indrajit Roy Oct 12, 2008
    To go to the convergence option follow this steps :
    Service Mode
    Most of the alignments for this chassis are software-driven.
    Most of the alignments must be accessed and modified
    through the front panel service mode.
    Entering the TV Service Mode Using the Front Panel
    Controls
    1. Press and release the POWER button to turn the
    instrument off.
    2. Wait 10 seconds before trying to enter the Field Service
    Mode.
    3. Press and hold the VOLUME DOWN and CHANNEL
    DOWN
    buttons for at least 8 seconds.
    4. The instrument will switch on and come up with the field
    service main menu on the screen. LED will illuminate
    before the picture comes up.
    The instrument should display the following menu:
    Soft-Ver. ITC222_V100-0 000046:37
    DVD Soft-Ver. 3.12
    Config. W - - V - - -P - Serial-No. AMN456789
    QUIT
    TUBE
    CHASSIS SETUP
    FEATURE SETUP
    GEOMETRY
    VIDEO
    EVENT HISTORY
    SOUND
    MISCELLANEOUS
    CONVERGENCE
    DVD
    UP DOWN SELECT
    Main Menu
    The CH /\ and CH \/ buttons on the front panel are used
    to navigate up or down in the menu.
    The VOL + and VOL - buttons on the FPA are used to
    select a menu item or decrease or increase a value in a
    selection list.
    NOTE:
    Before the Field Service Mode is exited; you must
    check STORE or all changes to alignments will be lost
    I hope this information will help you
    Scholar:
  • 116 Answers
Please check out for this two links as they will guide you step by step the first link will help you to locate the convergence settings and the second link will show you how to do it manually after you cannot adjust the settings.you just have to click this link and the page will open on your screen just follow the instructions.
for pictures on where is the convergence settings.
http://www.somelifeblog.com/2007/06/sony-projection-tv-red-line-repair.html
for alignment problem how to do it manually
this will definately help you but still for further help feel free for further assistance.
we will help you.
please rate the solution if you r helped by it.
thanks.
    Genius:
  • 1,847 Answers
Go through this link it will help you with your issue..
http://www.ehow.com/how_2034880_perform-convergence--tv.html
Posted on Oct 08, 2008
My television's color and picture is off it looks like there are 3 different pictures of the same thing on my tv all at once and each is a different color how do i fix this problem and is there a reset...
That can be caused by several items. First you will need to press menu on the remote then scroll down to setup and then enter setup and see if the auto convergence and manual convergence options are still listed under the set up menu or have they disappeared. Then just respond to this same post and let me know if the options are listed there still or not and I can then let you know the best way to repair the issue.
Jul 12, 2011 | RCA R52WH73 Projection Television
Help with RCA projection TV P46812BL (chasis ptk195AA)
You have probably blown one of the convergence ICs. Effectively the easiest thing to do is replacing the whole convergence board, so that no soldering is involved.
Here you can buy a replacement convergence board, just select your model.
Let me know if you need further help.
Sep 13, 2008 | RCA P52930BL 52" Rear Projection...
Were is the convergence board located on my tv
The convergence is split between 4 different boards on the rca itc222 model. depending on the symptoms of the picture will determine which one is at fault. What does your picture look like? is it bowed in at top and bottom? Is the picture 3d can you see red blue and geen? When you go into customer setup menu do you see the convergence options. if you see these what effect do they have. Let me know and i will help you isolate the problem....DOnt know but it could be the common fl231 fuse problem. read this to see if you do and let me know how i can help http://www.fixya.com/support/r1062030-fl231_problem_convergence_not_in
Feb 03, 2011 | RCA D52W20 52" Rear Projection HDTV-Ready...
My Zenith tv picture on the screen looks like a bowtie red green and blue are seperated on screen
The tv have a problems known as a convergence problems,it dead.The tv colors lines R,G,B mis alignments,have colors shadow pictures or 3D pictures look alike?The tv convergence board have dead 2 STK convergence ICS and some or all of it resistors too.These parts on the tv convergence board,must be replaced to solved the tv pictures convergence problems.The shop,will cost u like $300-350 for parts and labors.
Nov 24, 2010 | RCA D52W23 52" HDTV CRT TV
Turns on with sound but the picture is running colors mostly see red and blue also double vision. 3 colored lines show up on screeen when first turn on
do you have the convergence option in the customer setup menu? is the picture convcave bowed in at top and bottom. if you dont have the convergence option you might have the fl231 fuse problem. or something simular. first read this to determine if you do. if you dont you might have still have a convegence issue http://www.fixya.com/support/r1062030-fl231_problem_convergence_not_in let me know i am here to help.
Nov 07, 2010 | RCA HD52W66 Projection Television
My screen shows 3 colors what do i do?
you haveing convergence issues. first question. in your customer menu under setup. do you have the conergence option if you dont i suspect the f231 fuse problem.. read this... http://www.fixya.com/support/r1062030-fl231_problem_convergence_not_in if this dont apply you may have to replace some faulty components in the convergence curcitry. let me know how it goes
Oct 22, 2010 | RCA R52WM24 52" HDTV Projection Television
I need to know what convergence board I need and part number. TV is RCA Model HD52W59YX36. Symptom is see 3 d like shadows. When I go to do the covergence adjustment from the setup menu....nothing appears...
You dont need a convergence board. The convergence option missing from the setup menu is a easy cheap repair. www.tvrepairworld.com has the kit called ITC222 & 222A convergence option missing repair kit. It also has the CD with instructions along with the three components that repair that problem.
Mar 27, 2010 | RCA HD52W59 HDTV Projection Television
R52WH74 WONT CONVERGE
first question is the picture also bowed in on top and bottom. if so you may have the common fl231 fuse problem if you do consult the fl231 problem under the tips and tricks section. if you dont then you defently hav a convergence issue. the thing to look for is under setup do you have the autoconvegence option if you dont then you have that problem.
Jan 17, 2009 | RCA HD52W59 HDTV Projection Television
Rca p56927 colors out of line
This is a convergence oroblem. First question is do you have the convergence option in under setup in the customer main menu?... if you dont you may have the very common fl231 fuse problem; i have wrote a article on this under the tips and tricks section. this is a very simple inexpesive repair. If you do have the "convergence option" then you may have to replace one of three cuircit boards
Oct 25, 2008 | RCA R56WH76 Projection Television
Rca 52inch hdtv
Please replace STK392-110 quantity 02 in your tv to fix convergence problem.
Above said part is available here.
Regards,
Sep 27, 2008 | RCA HD52W59 HDTV Projection Television
Televison & Video Logo
480 people viewed this question
Top Televison & Video Experts
Electro Med Services...
