I try to turn my oven on and all i get the F3
F3 code means "The
oven temperature sensor is open". Check
for open wire connection between EOC (Electronic Oven Control
- Clock) and the oven temperature sensor. Replace sensor
if no wiring problem.
If your not sure how to do this, I recommend calling a professional to get it fixed.
Hope that helps! Should you have any further questions,
please feel free to post them here.
P.S. - If you find that the solution/answer
I provided led you to, or resulted in a fix, please close the ticket with a FixYa!
rating. I would be very grateful for your show of appreciation.
Thank you for using FIXYA!
Cheers!
IrishDruid
Hi - Typically error code F3 indicates a faulty sensor probe or wiring harness between sensor probe and EOC. Try resetting the range by unplugging it or flipping the circuit breaker off for two minutes (this usually will clear most false error codes). Turn on the range and if resetting the unit proves to be ineffective, I would recommend contacting a professional to move forward accurately.
