Question about GE Washing Machines
GE Washer does not reach full spin speed...stops abruptly
I have a GE model WWSE3160AOWW washer machine which I bought in 2000. Recently we noticed that our clothes were coming out extremely wet. The spin cycle appears to start normally (water pump is running and tub begins to spin). At first it looks like the spin cycle is normal and when it should go to the faster speed, the spin stops abruptly, however the pump continues to run. Not sure if this is a problem with the motor itself, the clutch or the transmission. Any help would be greatly appreciated!
  • jodijoec Oct 09, 2008
    Hi...thanks for your suggestion, however the problem happens without any water in the tub.
    I just tried it again and I noticed a "burning" odor coming from the motor. My gut is telling me the motor is shot...any thoughts?
  • 943 Answers
HI thanks for your question. the G E washer has to get rid of all the water before it starts to spin. check to see if you have a good water flow on pump out. if not clean the pump . thanks the appliance doc. please rate my answer. thanks
Posted on Oct 09, 2008
Maytag top load washing machine 2 years old
This could be partly the clutch/break assy. You need to be able to run this with the lid open in the spin position. Activte the lid switch with a pencil or something. Reach in and hold the spin basket and then turn the washer on in spin. Hold this basket for 1-2 minutes then release it and let it reach full speed then stop the washer by turning the timer off or releasing the lid switch. See if the hard breaking/noise is better. Keep doing this untill it comes to a smooth stop and the noise is gone at the stop. Not sure this will cure the noise in the spin starting up problem or not, but start here. the clutch gets rust on the pads and this burnishes the break pads, removing this rust that makes it grab.
Goodluck..
Apr 05, 2008 | Washing Machines
My GE Model # WBB4500E1WW washer not spinning
the washer is on but not spining and the machine is about 6 month old
Dec 19, 2009 | GE WBB4500EWW Top Load Washer
Maytag neptune frot load will not reach full spin speed.
It will not spin while washing, it's more of a rocking back and forth. As far as the spin cycle. If it's not reaching full speed I bet you'll notice that it's not doing the full cycle because the load is bouncing around and cause the washer to shut off. take some of the clothes out and watch it spin the water out.
Mar 26, 2009 | Maytag Neptune MAH5500B Front Load Washer
the motor does run right. the belt could be worn. or the clutch at the bottom of the motor check that.
Oct 09, 2008 | Washing Machines
Beach towels sopping wet after machine done spinning
The washer will not proceed into high speed spin with just two large beach towels in the basket. The washer is detecting a out of balance condition, and remains in low speed spin. Solution? Try adding more items into the basket. With only two towels, there is not enough mass to balance the washer. With more clothing or towels, there is more items for the machine to balance, and reach full speed spin.
The only other thing that could cause this, would be if the water in the tub is not completely draining in the time allowed. This washe does not have a cleanout, and checking for an obtruction in the pump is difficult. I would go with the more clothes first, then see.
Sep 25, 2008 | GE WSXH208A Front Load Washer
GE washer, does not spin
You probably broke the 4 black snubber straps on the top of the tub lid and it is cousing your washer to always be off balance and not reach a full speed spin
Oct 30, 2007 | GE WBSR3140DW Top Load Washer
Front load washer
Only possibilty is that the is still a blockage in the filter area, sump hose or you are using the delicate spin programme. Regards Advisor
Sep 01, 2007 | GE WBVH6240F Front Load Washer
Washer will not spin
Could be a bad clutch or transmission. I would either call a tech or get a new washer (these newer GE models don't seem to be very reliable, go for a Whirlpool/Kenmore model next time). Here are breakdown diagrams for your washer: http://www.appliancepartspros.com/partsearch/model.aspx?model_id=230151 Hope this helps, APP Tech
Aug 07, 2006 | GE WJSR2070B Top Load Washer
Washing Machines Logo
241 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
