Question about Toshiba Satellite M55-S3512 Notebook
Wireless Error I get a an error in the ConfigFree Screen that says, "Another vendor's application is controlling the wireless adapter".
    Problem Solver:
  • 6 Answers
More than likely windows will be controlling the wireless adapter....go into control panel and find wireless network setup wizard...follow prompts
Posted on Oct 08, 2008
Can't make a wireless connection.
what's the error? if your getting the error Connected with limited connectivity try checking your network key in the router and the wireless settings on your computer if they are correct or just removed your security key, if your getting an error no networks in range or no network available check the router settings if the wireless signal is turned on the router, if you get an error windows could not connect to wireless networks try uninstalling and reinstalling the wireless card driver on your system and set the the router to defaults then try connecting with out changing any settings in the router to see if it will connect, if it connects, then there was/were settings in the router and possibly in the wireless settings in your laptop that was causing the computer and the router to have communication issues, also check for possible applications such as network magic that could cause a wireless signal to degrade or not allow connections at all if such application exists on your system uninstall it Microsoft or windows has its own wireless configuration software built into handle wireless connections in XP it is wireless zero configuration in vista and in win7 WLAN which can be set in network and sharing connection in the control panel window.....
Jun 03, 2010 | Intel Computers & Internet
Another application is controlling the wireless adapter
I believe you are using WINDOWS XP.
In case of windows XP, there might be 2 different wireless utilities can control your wireless adapter.
First utility is the manufacturer's utility. If you have Dell wireless adapter then you can use Dell utility to connect to the network.
Another utility is Window's utility. You are getting the error message in this utility because your computer is using another utility.
To use window's utility you will need to start the " wireless zero configuration ".
Click Here
for more information about wireless connection
Feb 22, 2010 | Linksys WRT54GX2 Wireless-G Broadband...
Having trouble with linksys wireless usb 54 gc. I
Linksys wireless card mosly gives this type of error and not work with its own driver. Try uninstalling the drivers completely , reboot your systems then plug in the Usb adapter so that it uses the windows default drivers. that will resolve your issue.
Sep 04, 2009 | Linksys Computers & Internet
Bcmwltry.exe error message
Hi there!
Bcmwltry.exe is most likely a process that starts during boot. It runs the Broadcom Wireless Tray icon.
Try disabling this process from your startup configuration. To do this:
Click Start>Right-click My Computer>Select Manage
Expand Services and Applications and then select Services.
Look for an entry belonging to Broadcom Wireless. If you find it, right-click on it and change the Startup type to Disabled.
Restart your machine and watch for the error. If it doesn't show and you still have a wireless connection, your problem is solved.
If you don't find an entry, try uninstalling the software associated with the wireless adapter. Then restart your machine and watch for the error once more. If the error message doesn't appear, you'll have solved the problem; however, you'll need to double-check your wireless connection and make sure it is still functional. If not, unplug the adapter, restart your machine and then plug in the adapter as if it was the first time. Maybe a reinstallation of the software will correct the issue.
I hope this helps! Feel free to reply if you have any further questions.
Aug 16, 2009 | D-Link 802.11g Wireless Router WBR-1310...
Error message
It seems that the adapter is not installed properly ..... uninstall the adapter from control panel >> Add & remove programs Reinstall the adapter again by using it on different port .....
thus says linksys...
May 08, 2009 | Linksys WUSB54GSC Compact Wireless-G USB...
NDSTray.exe Application Error
The process ConfigFree(TM) Tray or Network Device Switch (Tray) belongs to the software ConfigFree(TM) Tray or TOSHIBA ConfigFree or NDSTray.exe by TOSHIBA CORPORATION (
Description: File NDSTray.exe is located in a subfolder of "C:\Program Files" (common is C:\Program Files\Toshiba\ConfigFree\). Known file sizes on Windows XP are 892928 bytes (27% of all occurrence), 978944 bytes, 962560 bytes, 704512 bytes, 458752 bytes, 929792 bytes, 933888 bytes, 888832 bytes, 139264 bytes, 1372160 bytes, 974848 bytes.
There is an icon for this program on the taskbar next to the clock. The program has a visible window. It is not a Windows system file. NDSTray.exe is able to monitor applications. Therefore the technical security rating is 18% dangerous, however also read the users reviews.
External information from Paul Collins:
  • "NDSTray" can run at start up. ConfigFreeT Tray on a Toshiba laptop. Tray utility for their network switching application which permits switching network devices and settings with a click on the tray icon. While it is not required, for people who span multiple networks and want an easy way to go from wired to wireless and change addresses and other network settings, it's a must have
Important: Some malware camouflage themselves as NDSTray.exe, particularly if they are located in c:\windows or c:\windows\system32 folder. Thus check the NDSTray.exe process on your pc whether it is pest. We recommend Security Task Manager for verifying your computer's security. It is one of the Top Download Picks of 2005 of The Washington Post and PC World.
Feb 11, 2008 | Toshiba Satellite M55-S135 Notebook
Wireless connection
If this laptop has a wireless switch, make sure it's on.
Did you get the wireless hub?
Wireless is controlled by the wireless zero service, which should turn on automatically when your adapter is detected.
You can turn it on manually in Control Panel/Admin Tools/Services
Nov 03, 2007 | Acer Aspire 3000 Notebook
Toshiba Satellite M55-S3512 Notebook Logo
964 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
