By paulrmc - usenet poster
I have owned this unit for about 8 months now and it has been great. Just
today though the player started displaying all of my region 1 dvd's in black
and white ( region 4 seems ok ). Also, there seems to a longer pause during
the "loading" phase when the dvd is first inserted. Anyone come across
something like this before or have any clues?
Thanks in advance
Solution #1
posted on Aug 07, 2005
herself - usenet poster
Rank:
Apprentice
Rating: 0%, 0 votes
Rating: 0%, 0 votes
hehe oops.
Yep that was it. Someone changed a setting on the tv so it was no longer
auto detecting pal/ntsc. Thanks for the suggestion :)
system (i.e. PAL and
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
Bouncy - usenet poster
Rank:
Apprentice
Rating: 0%, 0 votes
Rating: 0%, 0 votes
Well, on mine, it just stops playing if you set it to PAL and put in an NTSC disc. I guess it
might be for people who have PAL-only sets. Um.
Solution #3
Cato - usenet poster
Rank:
Apprentice
Rating: 0%, 0 votes
Rating: 0%, 0 votes
Sounds as though some setting has changed in the TV ? What you seem to be experiencing is
a NTSC picture displayed on a PAL only TV. I assume your TV is multi system (i.e. PAL and
NTSC) ? Does it have an AUTO setting, has this been disabled or set to PAL ? Try forcing
it to NTSC and if that is the case and see what happens.
No idea about the second bit
Trevor S
Trevor S
Solution #4
kioner - usenet poster
Rank:
Apprentice
Rating: 0%, 0 votes
Rating: 0%, 0 votes
The other thing it could be, is that you've done something like set
the DVD player to play PAL only. My SD2109 can be set to only produce a
PAL output - when you do this it just won't play the disc.
Yours is a later model, so maybe its put together so that when you
put in an NTSC disc while it's set to PAL it just puts out a PAL black
and white picture from the original NTSC. If this IS the problem, then
you can fix it in the SETUP menu by changing it to AUTO, just like if
it's the TV.
it's the TV.
Solution #5
Ranny - usenet poster
Rank:
Apprentice
Rating: 0%, 0 votes
Rating: 0%, 0 votes
Hmm I thought in the Tosh. this only affected the menu (ie the players menu is played back
in PAL or NTSC etc) NOT the playback of the DVD ?
Trevor S
Trevor S
Suggest a new solution for this problem
Post a New problem for Toshiba SD-1200 DVD Player
Email this problem
Email this problem
Can you Help with these DVD Players problems?
toshiba dvd player - SD-1200
When I put in cd, my player... Answer This...
No Sound from my DVD Player and...
I have been in the home a/v... Answer This...
Inability to play disc.
Whenever I load a disc into the... Answer This...
Repair Service
Find DVD Player Repairman Near You:
