Installation failure thanks for your help and suggestions after change and do some Attempts for the cable for Ide and the mode of DMA in the bios, the installation for windows XP pack2 continued To the final phase but at 15mn of the end of the installation the bleu screen with the message of errors appears for answers of your questions: 1) I try to install the whole system of windows XP pack2 ( it run correctly in others PC ) 2) Effectively I see something like 0x000000?? (0x00000......) but I don't take all details for this error code. my windows xp sp2 copy is a good copy. the same problem with others systems operating ( Windows Me and Windows 98 ) I can't install it in the PC differents messages of errors appears. for windows98 the installation is total but the drivers for periphericals can't to install and the message halted protection windows appear and no attempt can resolve the problem. I think probably if the CPU run correctly. Greetings
  • 781 Answers
I have already started to answer on the original thread!, let's keep the conversation in one place.
Posted on Oct 10, 2008
Cmos beep codes
do you know which bios your computer is running ?
AMI BIOS beep codes 1 beep - DRAM refresh failure
2 beeps - Parity Circuit Failure
3 beeps - Base 64K RAM failure
4 beeps - System Timer Failure
5 beeps - Processor Failure
6 beeps - Keyboard Controller / Gate A20 Failure
7 beeps - Virtual Mode Exception Error
8 beeps - Display Memory Read/Write Failure
9 beeps - ROM BIOS Checksum Failure
10 beeps - CMOS Shutdown Register Read/Write Error
Phoenix BIOS BEEP codes. 1-1-3 CMOS write/read failure.
1-1-4 BIOS ROM checksum error.
1-2-1 System timer failure. (Programmable Interval Timer PIT)
1-2-2 DMA (direct Memory Access) failure.
1-2-3 DMA page register failure.
1-3-1 RAM refresh failure.
1-3-3 64K RAM chip or data line failure.
1-3-4 64K RAM odd/even logic failure.
1-4-1 64K RAM address line failure.
1-4-2 64K RAM parity error.
2-?-? Any beep series starting with 2 beeps indicates a 64K RAM chip or data line error.
3-1-1 Master DMA register test.
3-1-2 Mslave DMA register failure.
3-1-3 Master interrupt mask register failure.
3-1-4 Slave interrupt mask register failure.
3-2-4 Keyboard controller failure.
3-3-4 Screen (video) memory failure.
3-4-1 Screen initialization failure.
3-4-2 Screen retrace failure.
4-2-1 Timer tick interrupt test failure.
4-2-2 Shutdown test failure.
4-2-4 Unexpected interrupt in protected mode.
4-3-1 RAM test failure above address 0FFFFh (64K +)
4-3-3 Interval timer channel 2 test failure.
4-3-4 Time of day clock failure.
4-4-1 Serial port test failure.
4-4-2 Parallel port test failure.
4-4-3 Math Co-processor failure.
BEEP codes may vary dependent upon the revision of BIOS. This list is for reference only
hope this helps
Oct 10, 2012 | Intel Mother Board S5520HCR (988889365963)...
Tip
If your older PC has lost some zip -- An easy thing to check & fix.
After a while, usually several years, your hard disks wear. As this happens the disks will have errors. Windows keeps track of these errors and if they grow too numerous Widows will take actions designed to reduce the possibility of a catastrophic event. One thing it will do is change the method it uses to access the hard disk. It will change from DMA mode to PIO mode and slow you way down. This tip will restore DMA mode so you can get a little more use out of your aging system. You won't need any disks or special software, but you will have to reboot twice.
In Windows get to Device Manager.
One way to get there is click Start, right click My Computer, select Properties, click Hardware tab, click Device Manager button.
In Device Manager, press the + next to IDE ATA/ATAPI controllers.
It should look something like this:
Double click Primary IDE Channel. Click the Advanced Settings tab. If there is no Advanced Settings tab then this tip will not help you, but check the other possibilities (Secondary IDE Channel, other controllers) the same way.
Check to see if the Current Transfer Mode says PIO. PIO stands for Programmed Input Output. It is the slowest mode of disk access. If the Current Transfer Mode is something with DMA (Direct Memory Access), then this tip will not help you as this is the preferred mode.
Check to see if the DMA if available is selected in the Transfer Mode box. If not, select it.
At this point you have determined that you are using PIO mode for one or some of the IDE Controllers and that you have selected DMA in the Transfer Mode. The next thing is to make Windows load the correct DMA driver.
Click the Driver tab.
Click the Uninstall button. Click the OK button. Do this for all IDE Controllers that show PIO mode.
Windows will ask if you want to reboot. Let it happen. Windows will reboot, load the DMA drivers, and tell you it has to reboot again. Let it happen.
Now the DMA drivers should have been installed and some of the snap should return to your PC.
Eventually, Windows will revert back to PIO mode. Your disk is wearing out. Get a new one!
on Sep 21, 2010 | Computers & Internet
DMA
You can download a software fix for it:
http://winhlp.com/node/10
It's called resetdma.vbs ,download it and then install it.
The site also has some tips if the software doesn't help you.
May 14, 2009 | Compaq Presario Notebook
Need to move HD from Primary to Secondary IDE Controller
its so easy man.....dont have to upgrade the Bios...open the tower CPU..check the HDD data cable ...find the socket on the mb whr it is connected to,,u will find a similar socket next to it....unplug from the 1st one and plug into the other one and its done
May 11, 2009 | Compaq Presario 2199us PC Notebook
Still needed solution of problem
Go to Control Panel - click on System - Click on Hardware - Click on Device Manager - click on IDE ATA/ATAPI Controller.
Then right click on Primary IDE Chanel - then click on Properties - Then Advance Settings - For the Device 0 in Transfer Mode select DMA if available. Then Click OK.
You can also select DMA for Device 1 too
Feb 09, 2009 | Compaq Presario Notebook
Need Solution of a problem
try this. go to BIOS, from your main page choice sata1 and press enter then press DMA MODE and chanege to UDMA5 press enter F10 save and exit
Feb 07, 2009 | Compaq Presario Notebook
Micro star mainboard ms-6163
Hi
MS-6163 Pro Systemboard IDE controller utilises Intel 82371EB PCI Chipset and supports up to Ultra DMA 33 operation mode.
MS-6163 Pro - http://www.msicomputer.co.uk/index.php?func=proddesc&prod_no=340&maincat_no=1
**** Other MS-6163 ****
MS-6163FC Systemboard IDE controller utilises Intel 82371EB PCI Chipset and supports Ultra DMA DMA 33/66 operation modes.
MS-6163FC - http://www.msicomputer.co.uk/index.php?func=proddesc&prod_no=341&maincat_no=1
MS-6163VA - Systemboard IDE controller utilises VIA VT82C596B Chipset and supports Ultra DMA DMA 33/66 operation modes.
MS-6163VA - http://www.msicomputer.co.uk/index.php?func=proddesc&prod_no=342&maincat_no=1
MS-BX Master Systemboard IDE controller utilises Intel 82371EB PCI Chipset and supports Ultra DMA DMA 33/66 operation modes.
MS-BX Master - http://www.msicomputer.co.uk/index.php?func=proddesc&prod_no=319&maincat_no=1
Regards
Mike
Mar 27, 2008 | MSI MS-6163 Pro Motherboard
Problem with LITE-ON DVDRW SHW-160P6S ATA Device
There is a whole bunch of helpful stuff at http://www.tomshardware.com/forum/196090-32-lite-dvdrw-160p6s-burning-problems
Seems that the drive may overheat, and will need replacement if in warranty. Some advice given: get another type drive. Also, check the device manager and make sure it's running in DMA mode and not PIO mode. If you have an nForceX mobo and using the SW IDE driver, reinstall with the normal IDE driver and try again. In device manager, check under IDE ATA/ATAPI controllers. Right-click and select properties on the IDE Channel your DVD recorder is attached to. Transfer mode should be set to "DMA if available". Current transfer mode should be "Ultra DMA Mode 4". If it says Mode 2: Your drive may be experiencing problems which are causing windows to drop its speed. There is a support article with a fix. To surmize:
After the Windows IDE/ATAPI Port driver (Atapi.sys) receives a cumulative total of six time-out or cyclical redundancy check (CRC) errors, the driver reduces the communications speed (the transfer mode) from the highest Direct Memory Access (DMA) mode to lower DMA modes in steps. If the driver continues to receive time-out or CRC errors, the driver eventually reduces the transfer mode to the slowest mode (PIO mode).
If you have dropped from DMA mode 4 to DMA mode 2, and you have a spare ribbon cable, you may want to try swapping it out. Also, if there is another device on the same channel as the DVD drive, try disconnecting it.
Mar 12, 2008 | Computers & Internet
DMA drive error.
Its a problem with the windows dma seting for drives. In "device manager", open properties for ur drive and your interface like IDE/ATA controller. There, you can check and change DMA Settings.
Allow max DMA. Do not disable DMA.
U can also check DMA setting on BIOS if ur bios supports it.
Feb 19, 2008 | Computers & Internet
Compaq D510 sff Dma problem
Those might have been your specs but if you have updated windows some of your drivers autamatically change. Try rolling back the drivers or updating them again. The drivers change frequently when windows hot fixes are dowenn loaded your setting that you had and are trying to set it at are the ones when the system was new.
Dec 17, 2007 | Compaq Business d530 (PB185US) PC Desktop
Computers & Internet Logo
251 people viewed this question
David Payne
David Payne
