Question about GE (PSS26MSRSS) Side by Side Refrigerator
GE fridge, wheel locks
Lost my owner's manual. Are there locks on the wheels under the fridge? How does one find the release if there is? I have new kitchen flooring which is way too fragile and when a handyman came he tore it up. Flooring was repaired free by installer but I'm moving and need to move the fridge and don't want to tear up the flooring if I can avoid it.
  • Anonymous Nov 12, 2008
    the refridge is not level The wheel have to come down in the front to elevate. I can not get the wheels to move and change position
  • 120 Answers
If is a ge there are no locks on wheels just try to be care full it should move easier when emptied and buy a scratch plastic the you can use when moving unit that is what we use every time and i am a sears tech
Posted on Oct 12, 2008
Hello I have a 2000 saturn sl2 and steering wheel is locked. I can't even move the gear shift into nuetruel. Is there anything that i can do to fix yhis problem?
Can you turn the key? Some makes and models, if the steering wheel is causing tension on the key cylinder causing it not to turn, Sometimes you can pull ******* the steering wheel, one way or the other, to release tension on key cylinder in order to turn the key. Once you turn the key, steering wheel releases, hopefully.
If you can turn the key, turn to acc, set parking brake, step on the brake, hopefully then you can shift into neutral. That should bypass shift interlock. This info may be in your owners manual?
Mar 30, 2017 | Saturn Cars & Trucks
2009Element my cars ignition has locked steering wheel also ,my key wont turn it ,how do i reset the antithieft to unlock it
The anti-theft has nothing to do with the steering wheel and key not turning. Most commonly the steering wheel is under tension which puts extra force on the steering wheel lock mechanism that is released when the key is turned. Try turning the wheel both ways while trying to turn the key to see if it will release. If the wheel has a little bit of play while you turn it back and forth that it is probable the lock cylinder that has failed.
Jan 06, 2016 | Cars & Trucks
Seats dont work an now when u lock tha doors tha headlights come on an off
[PDF]2015 Chevy Malibu Owner's Manual - Chevrolet
https://www.chevrolet.com/.../northamerica/.../2015-malibu-owne... ChevroletApr 1, 2014 - manual and the page number where it can be ... you need to see your owner manual .... To lock or unlock the doors from the ... the seat. 2. Slide the seat tothe desired position and release the handle. 3. .... Do not adjust the steering wheel ....on or off. A white indicator comes on in the instrument cluster.
[PDF]2015 Chevy Spark Owner's Manual - Chevrolet
https://www.chevrolet.com/.../northamerica/.../2015-spark-owners... ChevroletNov 19, 2014 - Headlamp Aiming . .... you need to see your owner manual .... locks. Press K to unlock the driver door or all doors and the liftgate. ... the seat. 2. Slide the seat to the desired position and release the bar. 3. .... Do not adjust the steering wheel... OFF: Turns the rear wiper off. .... If the warning light comes on,.
[PDF]OWNER'S MANUAL - Mini
Dec 29, 2015 | Cars & Trucks
In a car what is the meaning of abs and what is purpose?
automatic braking system. stops skidding.
Mar 28, 2015 | Cars & Trucks
Locked ignition steering wheel locked
Some of these cars had a button under the steering column that you could push to release the locked wheel. Feel under the steering wheel and column going from the end of the wheel towards the dash and see if there is button on the underside that you can push.
Good luck.
Aug 14, 2013 | Ford Cars & Trucks
How do you install the fridge evenly in the alcove?
#1 is floor level?
#2 does it wobble?
#3 check owners manual-LEVELING THE UNIT there should be adjustable 'feet' that screw into the bottom frame of the unit.some have adjustable wheels at the front.remove the vent panel under the door and look under with a flashlight to see what you have.
Jan 22, 2013 | Fisher Refrigerators
Yamaha 250 back wheel locked up while riding
Hi, Anonymous for this scenario you will need your service/owners manual if you can't find the first and best tool you ever bought for your Yamaha, despair not, for a mere $0 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
http://mybikemanuals.com/yamaha/yamaha-yz-owners-manuals
OEM parts for Yamaha
YAMAHA YZ250 LC Owner Service Manual
Dirt Rider Magazine
Rear Wheel Lock up Diagnosis Kawasaki 2 Stroke
Nov 23, 2012 | 2007 Yamaha yZ 250
Emerg Brake is stuck and engaged, won't release -
ok then. the E-brake cable is not broken just stuck, the cables tend to get rusted and thgis happens all the time,What you can do is go under the truck and manualy pull the cables rear of the truck this should release the brake.
As for the four wheel drive the E-brake has nothing to do with it. on the transmissions transfer case there should be a switch or a manual lever that a cable hooks to this is most likly your four wheel drive problem unless you have locking hubs where you have to pysicly get out and lock the hubs at the wheel then the locking hubs may be worn broken or bad.
Feb 09, 2010 | 1989 Chevrolet K1500
Creaking Sound when Opening Door of GE Profile PTS22LHSCC Refrigerator
My GE creaks too, and it started after we pulled it out for cleaning. It is normally the door hinges. Spray them with Jigaloo which is a dry silicone lubricant.
Try this. Go to your local tire repair place. Ask them for an old inner tube. Cut a double thickness square with scissors and put it under the 4 corners under where the wheels are. It should help them to become self leveling and also sound insulating..
Mar 23, 2017 | GE Profile PTS22LHSCC 33" 21.7 Cu. Ft....
GE (PSS26MSRSS) Side by Side Refrigerator Logo
1,440 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
