Question about Samsung Audio Players & Recorders
Samsung av-r610 av receiver. noisy cooling fan. can it be replaced with a quieter/more efficient one?
Hi i have same unit. If you keep the volume anywhere below 31 the fan is not intrusive (you can hear a quiet hum but not a bother) I also give it plent of ventilation ie 1 foot at back and a little less to the sides. The problem is the unit is so slim the fan has to work harder to dissipate the heat build up.
Posted on Feb 17, 2009
I have a noisy fan, it gets quieter when the frost setting is turned down
your fan motor touching the ice formation when occur..adjust your fan motor blade,or your fan motor .to avoid making noisy all the time.
Jul 11, 2011 | Refrigerators
Hi. I have a HP Pavillion dv7 Laptop. I've had it for approx. 2 & 1/2 years. For the first year I really didn't use it at all. I was working too many hours and working in a call centre, the...
The problem very likely may be dirt. Dust and dirt accumulate in the air passages and heat sinks in laptops often causing them to overheat. You say that the laptop was serviced by a technician recently.
He should have cleaned it's cooling system but he may not have. I have found that if the machine is not completely dismantled the dust and dirt blocking the free flow of air may not be visible.
Another possibility is that your cooling fans are waring out. These can be replaced. Also you can purchase high performance fans that are quieter, more efficient and last longed than the standard fans that laptops are supplied with.
Being as you have so much invested in this machine it makes sense to check to see if you have these issues.
Hope that helps.
Jul 06, 2011 | HP Pavilion dv7-1245dx Notebook
Constant noisey fan. However when it is in sleep mode and you take it from sleep mode the fan is quieter. Any solutions and possible cost to fix. Im using a packard bell desktop 2626 modfel i think. this...
Try opening the chassis and clean the inside of the pc. You can use a blower to remove dusts inside the pc. Usually this is the culprit. Excessive dust will make your cooling system ineffective so the fan will run very fast to cool it down. If your pc is clean, check if there are wires touching the blades of the fan. Also check if there are broken blades in the fan. If everything is fine and still fan is noisy, you have to replace it.
Apr 22, 2011 | Packard Bell iMedia 6826 (P481000502) PC...
I have a problem on fan can you solve? It's a noisy fan
Most of the problems with cooling fans in equipment is due to loss of lubrication. What anybody would do in this case is take out the cover of the receiver and replace the noisy fan, or, in case you are able to do so, repair the fan.
In fans with ball bearings, you can do nothing but disasembling the fan and replace the tiny BB, in fans with sleeves bearings, you may disassemble it, clean it well, and put some oil or light grease in it before reasembling it.
Dec 09, 2010 | Audio Players & Recorders
The fan that comes with this is extremely noisy. Regular P4 heat sinks have a different footprint so they do not fit. How would I get a quieter cooler that fits?
Search the internet for a cooler for that model motherboard, or a cooling fan designed for that motherboard that can provide add'l cooling for your system.
Feb 12, 2010 | Intel Server Board S875WP1-E Motherboard
The fan is horribly loud on an HP Pavilion dv6449us laptop and the drivers are up to date. How do I replace the fan?
First attempt to clean out the fan with some compressed air and clean the fan intakes as well as clean the exhaust areas.
Nov 26, 2009 | HP Pavilion DV6449US Notebook
Dell XPS 210 very noisy what can I do to quiet it
Hi, The noise from any computer is due to the fan. It is really the only thing that makes noise on a computer - unless you havce a bad drive. If you can hear a drive outside of the case, then it's about to fail. You can buy a quieter fan for your laptop. That will take a bit of investigation on your part, as far as getting the dimensions and wattage of the fan from your manufacturer's web site or the instruction manual that came with your computer. You would do best to go to a reliable and competent computer shop and have a quieter fan installed, rather than doing it yourself if possible. This mod is very simple, and can make your computer run better, provided you get a better fan that can cool your machine better.
Jun 09, 2009 | Dell Inspiron 1150 Latitude D600 14.1 LCD...
Noise
That noise is due to your Power-Supply-Unit, Hard-Drive, Optical Drives, other spinning devices, and ventilation fans. You can reduce some of it but not all of it.
For example, your hard-drive could be rather old and producing a lot of noise when it spins up, reads, or writes data. You could replace it with a newer hard-drive which barely makes any noise. The same with your Power Supply Unit (PSU). It could be old and rather noisy. You could buy yourself a newer one such as the ones made by PC Power & Cooling which gets you a quieter product. However that's about it as you DO NOT want to reduce the amount of fans in your system.
Sorry if this was not the solution you were after. However most noise from a computer stems from ventilation fans which can be replaced but should not be removed.
Feb 02, 2009 | Abit NF7-S V2 Motherboard
Need quiet repl. fan (Sunon 50x50x15mm)
HEY BUDDY...............
U DONT HAVE ANY PROBLEM...IF U R CPU IS PROPERLY  U NEED NOT TO BURRY.ITS OK
AND FAN NOICE DOESNOT MATTER MAN.....MY PC  ALSO HAVE 3 FANS AND CREAT SO MUCH SOUND..............
dont forget to tell me u r problem solved or not
best regards & best of luck..
Oct 25, 2007 | Sunon 50x50x15mm DC 12V Magnetic...
853 people viewed this question
Top Samsung Audio Players & Recorders Experts
Electro Med Services...
sonic boom...
sonic boom...
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
