Question about Ingersoll Rand - Rand Type - 30 Reciprocating Air Compressor - 7.5 Hp, 230 Volt 3 Phase, Model - 2475N7.5
Ingersoll Rand M # 10T3NL Trouble
We are experiencing trouble with the trap breather. It blows air continueously out the discharge tube. Please help. Thank you.
  • flash7777 Dec 03, 2008
    Thank you. I'll try that.
  • alboga64 Apr 22, 2009
    esta pasando acite por la admicion de la unidad
  • 65 Answers
Your problem seems to be that the non return valve is passing ,your local i/rand dealer can supply a new seal,there not expensive
Posted on Dec 03, 2008
What level does the coolant need to be in the sight glass?
About 31,000 results (0.83 seconds) Search Results
    [PDF]IRM-G-8780 2-25hp US - Ingersoll Rand Air Compressor
    www.ingersollrandproducts.com/...
    Ingersoll Rand Industrial TechnologiesIngersoll Rand compressors are not designed, intended or approved for breathing ...does not approve specialized equipment for breathing air applications and ... unmatched service to meet your needs. ... drain, and low-oil-level .... Oil Sight Glass ... Value Package (5, 7.5, 10 & 15hp) An economical choice in a dependable ...
    [PDF]Owner's Manual - Air Compressors Direct
    www.aircompressorsdirect.com/.../irmanual2340_2475_2545_7100_15t...
    installation, operation and maintenance of your Ingersoll-Rand air ... An air-cooled aftercooler, low oil level ... for Models 2340, 2475, 2545, 7100, 15T & 3000 ... Ifcooling of the discharge air is required, .... motor does not have this button and the unit does not have a ..... l Drain compressor oil and clean oil sight glass.
    [PDF]XF 7.5 - 15 EP 7.5 - 15 HP 7.5 - 15 XP 7.5 - 15
    diagramasde.com/.../Manual%20comp%20ingersollrand%20SSR-15.pdf
    EP 7.5 - 15. HP 7.5 - 15. XP 7.5 - 15 ... The Ingersoll-Rand Company Rotary Screw Air Compressor that has been filled prior to its ... after shall have its AIREND warranted for twenty four (24) months from the ... comes first, when using ULTRA COOLANT.Coolant ...... check coolant level in the sight glass on the separator tank.
    Ingersoll Rand Air Compressors - About Air Compressors
    www.about-air-compressors.com/Ingersoll-Rand-air-compressors.html
Feb 08, 2016 | Ingersoll Rand 15 Horsepower Rotary Screw...
Ingersol rand single phase t-30 compressor with twin cyl slow/ dragging
Quincy QT-5, with an 80 gallon tank. I was very patient and found this on CL. If you are flush with cash, do as you wish. If you are looking for the best bang for the buck, CL will produce!
X2 on the CL find....
Picked up a basically new Ingersoll Rand, T30 220v/2 stage for $500
Increase Engine Horse Power.
Jun 04, 2012 | Ingersoll Rand - Rand Type - 30...
When pressure switch is satisfied and turns off, air continuously blows out the side of the pressure switch
The check valve in the receiver tank is leaking. the check valve is located in the top of the tank where the copper discharge line from the compressor attaches. Shut off the power and bleed all the air from the receiver. Remove the copper line then remove the brass check valve. Once removed look in the check and make sure trash of some type is keeping it open. If trash is the problem clean and install. If not it will need to be replaced.
Dec 12, 2011 | Ingersoll Rand SS5L5 Ir Electric...
I have a IR5190 Grease Gun, I'm only on the second tube of grease since new & when I loaded it, it won't pump out, I already disconnected the tube to make sure it wasn't clogged. Am I doing...
there is air trapped in the gun. there is either a air bleed valve on the top you need to press in and press the trigger a few times or you need to pull back the ram and unscrew the tube. then rescrew it back in a few turns. then press the trigger untill grease begins to come out and then screw in in the rest of the way.
Aug 17, 2011 | Ingersoll Rand IR5190 Ultra Duty Grease...
My ssl5l compressor builds pressure real slow now. Rings or Valves? it did get a little warm while sandblasting lately....
Very rare to have problems with rings. Blow-by would produce high pulsating pressure in the crankcase causing oil to blow out the oil filler plug/ dipstick. If normal crank pressure, suspect problem with valves or gaskets. Remove air filter cover and check for air blowing out of intake or very hot head or air discharge tube. Leaking valves or blown gasket will cause low volume/ low pressure and hot discharge air. Remove the in-tank checkvalve and look for carbon deposits /debris build-up. If the checkvalve and the interior or discharge hose are coated with oil deposits /carbon, most likely problem is valve plate/ gaskets /head. Good luck with your repair.
May 03, 2011 | Ingersoll Rand SS5L5 Ir Electric...
Hi,I got a Ingersoll Rand type 30 model 234 compressor.It looks good but it has no motor.I'm thinking like 120v,3horses?,but not sure about rpm.any help would be nice.thanks
According to the information you provided your looking at a 10 HP motor at three phase. Do you have three phase at your location? If not I would look into getting a single phase compressor. If you do want to get it going I would notify your local IR dealer so they can get you the right Model number, RPM, Pulley and Motor Frame Size to match your unit.
Please read below....Jim...if this helped you please send me a positive response...Thanks!
Ingersoll-Rand Type-30 Electric-Driven Two Stage Horizontal Air Compressor - 120 Gallon - Fully Packaged IR 2545E10VFP
  • Designed for heavy shop or industrial use, Ingersoll-Rand Two-Stage electric air compressors provide the quality and performance that are ideal for most applications and users, including: automotive service and body shops; fleet maintenance; machine shops; production and manufacturing lines; construction; wood working shops; dry cleaners; car washes; maintenance/repair shops and farms.
  • Durable cast-iron, two-stage design offers extended pump life for years of trouble-free service 175 PSI maximum operating pressure
  • 100% continuous duty for tough applications
  • Automatic start/stop control/pressure switch operation
  • Includes motor starter, oil sight glass (10-15 HP only), manual drain and ASME tank
  • 10HP, 3 Phase 200, 230 or 460 Volts
  • 120 gal, horizontal tank
  • 35 ACFM @ 175 PSI
Feb 14, 2011 | Ingersoll Rand Type 30 Electric Driven Two...
Bleeding air from fitting on side of pressure switch, fitting has 1/4 tubing running to it. This pressure switch is new out of the box.
The fitting on the side of the pressure switch is an unloader and should bleed air when the compressor shuts off, if it continues for more than 30 seconds then the tank check valve on the pump discharge line where it enters the tank is not closing off and needs to be checked or replaced
May 04, 2010 | Electric Eyeware Ingersoll Rand 5HP...
Ingersoll Rand - Rand Type - 30 Reciprocating Air Compressor - 7.5 Hp, 230 Volt 3 Phase, Model - 2475N7.5 Logo
497 people viewed this question
Top Ingersoll Air Tools & Compressors Experts
elunsford
John Trevino
Joe Garcia
Joe Garcia
Are you an Ingersoll Air Tool and Compressor Expert? Answer questions, earn points and help others
