Question about Garden
When I start my tractor up it spits and spudders, and sometimes stalls, after running about 5 minutes it runs good. Last year I redid the head and it ran like new. I have new spark plugs and wires on it. I had the distributor cap checked and it was ok. I am leaning toward a carburetor problem. I need some more input before I go down that road.
  • 163 Answers
Check the fuek lines for hole and leaks, check the fuel filter and clean if necessary. remove the carbuerator and inspect the gasket; it should be soft and flexible, if it seems hard or brittle replace it. clean the carb with carb cleaner sray (available at any local auto parts store) and compressed air. make sure you get inside the small fuel rail holes.
Posted on Nov 30, 2008
I have an international 460 tractor and i ma trying to find the serial number. All I have found for a number is 10865, but that doesnt fit into and of the serial number references that I have found. Does...
I have a International mid sixties 460 tractor. Have drained fuel, changed fuel line and filter. Carb has been taken off cleaned no issues. Will start and run for a few minutes sometimes longer than others. Seems like there may be an issue with the governer. Any ideas what to try next. Thanks
Jan 15, 2011 | Farmall IH Tractor 460, 560, 660, 2606...
Iam working on a 706 case IH gas. it hasent ran in many years. i draned all the old gas and rinsed the tank. and gas lines. new plugs points distributer, roter, plug wires. still nothing. i have spark....
carb is probably gummed up from the old gasoline. try squirting some gas into the carb where the air goes in to start it. probably won't keep running but sometimes it can shake something loose like a stuck FlOAT VALVE.
Aug 18, 2010 | Farmall IH Tractor 706, 756, 806, 856,...
We have an IH 460 Farmall. It ahs been running
check the carb out clean it and the lines also just to be sure check the sparkplugs
Oct 11, 2009 | Farmall IH Tractor 460, 560, 660, 2606...
1942 farmall tractor stalls after 10 - 15 minutes of bushhogging.
Hello, W/D here.
It might have to do with your temp or it could be a fuel issue. I had a model "B" (1947) and it sometimes pulled a slight vacuum on the tank, starving it for fuel, and it took about that long. If you have the glass sediment bowel on yours, you should be able to see evidence of this if it is happening, or if you have a vent in your filler cap, it might be plugged. I don't know how a model H tank is vented, but I'm sure that you do.
As to it being temp related; it could be. You can remove and test your thermostat by immersing it in hot boiling water and seeing if it opens. It probably has it's temperature rating printed on the thermostat. If you believe that this is the issue, a lower opening thermostat can be installed to see if this corrects the problem
Good luck, and best regards, --W/D--
Aug 15, 2009 | Farmall Tractor A-i,av,super A ,super Av...
Tractor stalls after approx. 15-20 of run time (1957 farmall cub)
try the 12volt coil. and remember the positive verses ground . you might have to order one from search that web site , i hope i spelled it right ,dang it sucks being 50 years old and cant remember things. but any ways check that website out okay .
Nov 26, 2008 | Farmall Toys
Garden Logo
226 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
