Question about Apple iPod mini M9160LL/A MP3 Player
Stopped working Hi I just connected my new Ipod nano and now ive disconnected it and its frozen all it says is connected -eject before disconnecting....what should do
  • Anonymous Jan 27, 2009
    My 60gb iPod video (two years old) today (1/26/09) stays lit up and says "Do not disconnect." My iTunes won't recognize it. Earlier today my iTunes wouldn't pop up but it would randomly play music.
  • 342 Answers
Last Modified: January 28, 2009 Article: HT1320 Old Article: 61705 Summary Learn how to reset or restart iPod following a freeze.
Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.) Press and hold the Menu and Center (Select) buttons simultaneously until the Apple logo appears, about 6 to 8 seconds. You may need to repeat this step. Tip: If you are having difficulty resetting your iPod, set it on a flat surface. Make sure the finger pressing the Select button is not touching any part of the click wheel. Also make sure that you are pressing the Menu button toward the outside of the click wheel, and not near the center.
If the above steps did not work, try connecting iPod to a power adapter and plug the power adapter into an electrical outlet, or connect iPod to your computer. Make sure the computer is turned on and isn't set to go to sleep.
If you are still unable to reset your iPod, use only one finger from one hand to press the Center (Select) button, and one finger from the other hand to press the Menu button.
When you reset iPod all your music and files are saved, but some customized settings may be lost. Date and time are preserved (unless the iPod reset itself because it had no power and then was reconnected to power). Other customized settings, such as Bookmarks, On-The-Go Playlists, Shuffle, Backlight timer, and so forth are preserved from the last time the hard drive turned on
Posted on May 19, 2009
I gb nano frozen in connected eject before disconnecting stage. windows does not recognize the usb port
Try reseting it, It worked for me. Hold down the "Menu" button and the middle button for about 7-10 seconds.
Hope this helps.
Dec 21, 2009 | Apple iPod nano
My ipod is frozen. "Connected eject before disconnected."
Hello, if it's still frozen try holding the power button and the center of the scroll wheel, or the power button and the top of the scroll wheel until it restarts, then try re-connecting it again.
Nov 30, 2009 | Apple iPod nano
My nano 8gb has frozen and shows connected eject
You just need to reset it, hold down the middle button and the "Menu" button for about 7-8 seconds or until you see the Apple logo.
Hope this helps!
Nov 25, 2009 | Apple iPod nano 3rd Generation
16 gig ipod nano screen has frozen screen
Try doing this: Toggle the hold switch and put it back in the off position. Then press and hold the center button and the menu button simultaneously for ten seconds and the apple symbol should come up on the screen. Then it should work like normal. Hope this helps!
Jul 08, 2009 | Apple iPod nano MP3 Player
Failed to eject before rebooting computer, now USB port says it doesnt recognize the ipod and my ipod is frozen on "Connected-eject before disconnecting"
Actually this issue shouldn't really be that difficult to resolve. :) A simple reset should take care of it being frozen on the connected screen. Below I have posted a step by step on resetting an iPod.
As soon as you see the apple icon appear disconnect the iPod from your computer. After the iPod completely loads. reconnect it to make sure it is connecting and loading correctly. If this does not resolve your issue for any reason please do let me know. I have a few other options we could attempt. :) and the feed back is always good. It lets me know if I am actually helping people with they're issue's or not.
May 16, 2009 | Apple iPod nano
Ipod nano 8GB 3rd generation FROZEN!
Try resetting the ipod while its connected to the computer by holding both the menu and center button at the same time for 6-10 seconds until you see an apple appear on the screen. You may need to repeat the reset. If this fails your looking at a hardware issue most likely. Good Luck.
Apr 19, 2009 | Apple iPod nano MP3 Player
Hi. I plugged in my iPod nano 4th generation to charge it. It opened iTunes as it usually does and I could see my iPod in my device list. I left it to charge as normal. I came back a while later and my...
Mar 22, 2009 | Apple iPod nano
3rd gen nano 4gb
try a reset
To reset your iPod:
  • 1. Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.)
  • 2. Press and hold the Menu and Select buttons until the Apple logo appears, about 6 to 10 seconds. You may need to repeat this step.
read more here
http://www.fixya.com/support/r561901-ipod_problems_start_5_solutions
Jun 01, 2008 | Apple iPod nano
Ipod Problem (Ipod Nano) moel NO A1199
i fix this problem just the ipod need to reboot
hold ok key and then hold menu key it will be restarted and the it will be connected to your PC
Thanks
Dec 02, 2007 | Apple iPod Photo MP3 Player
Apple iPod mini M9160LL/A MP3 Player Logo
80 people viewed this question
Top Apple Audio Players & Recorders Experts
TO Lady
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
