Question about Coleman Powermate Premium Plus 6250W Portable Generator
Motors fine, but no electricity - coleman 6250
This genorator was bought for hurricane Rita. Ran for 3 hours and was put away. Engine runs perfectly fine. Went to use it for hurricane Ike and all I could get was 3 volts out of either receptical. Tried a suggestion of "reenergizing" the stator with a battery(no changes). This genorator is out of warranty and I cannot get through to anyone at Coleman. Does anyone have any suggestions?
    Problem Solver:
  • 8 Answers
Pramac bought them out i just order parts today oct-15-08 call1-800-445-1805 took me awhile to get a hold of someone but she seemed to know what was going on. my guess is that the printed curciut board in the back of the generater head is bad i have had to change alot of these out.
Posted on Oct 15, 2008
Power cord does not retract immediately
Coleman Powermate Generator 5000 Watts / 6250 Watts ...
? 3:27
https://www.youtube.com/watch?v=IROa5QfPqkU
Nov 8, 2012 - Uploaded by Carlos Roman
This 5000 watt generator is great for backup power at home or forpower ... Coleman Powermate Generator 5000 Watts / 6250 Watts ... This feature is not available right now. ... folding handle, 1 quart, of oil, and 25ft generator convenience cord. ... How to convert a generator recoil starter to an electric starter!
pull cord won t retract Power Generators Questions ... - Fixya
www.fixya.com > Forum > Tags > pull cord won t retract
Power Generators pull cord won t retract questions and answers. Ask your pull cordwon t ... Question about Powermate Powermate 5000W Generator. 2 Answers · I was running my coleman powermate 6250 gen power ... cord 6250 trips out ... The pullcord does not rewind onto the pulley when pulled. At first I thought it was ...
Best Portable Generator Reviews
Feb 03, 2016 | Coleman Powermate Powermate 5000W...
Power mate 6250. Starts and runs fine until I take the choke off, then why does it die?
Coleman engine starts runs short time quits Power ... - Fixya
www.fixya.com > ... > Power Generators
Coleman Powermate 6250 only runs with choke closed/air restricted ...starts and runswith full choke, but dies with choke off. ... some gas in the cilinder through the plug hole)and start the engine until it runs constantly. bestregards ... Ad ... I use a fuel stabilizer ... ...engine runs fine but produces no power at all to the breaker.
Coleman car starts but will not stay running Power ... - Fixya
Question about Powermate Premium Plus 6250W Portable Generator ... squirt a little gas in the carb it will run until gas is gone doesnt seem to get gas from . ... ...starts and runs fine for about a minute, then dies as though starved for fuel. ... load up on fullchoke and stay running around 3/4 choke HI, Turn off the gas and take ...
Generator runs then shuts off - YouTube
? 8:17
https://www.youtube.com/watch?v=6esHkPyygWw
Sep 6, 2011 - Uploaded by mainblind
How to make Generac generator run bypassing the low oil sensor and ... Remove all; Disconnect .... My ...
Jan 13, 2016 | Coleman Electrical Supplies
We just bought a coleman powermate 5,000-6250 gen and it runs great but will not produce electricity. i hooked a 75 watt bulb up to each plug in and it would just barely come on the fade out. but would...
Your generator produces proper voltage and 60 cycles at 3600 rpm. Use meter to adjust voltage/engine rpm. If after adjusting rpm setting and gen. does not have proper power, remove cover to generator and examine brushes and commutator rings for wear and voltage regulator/rectifier for burned components swolen or leaking capacitor and replace parts as necessary. Parts are available www.jackssmallengine.com Good luck
Sep 09, 2010 | Coleman Powermate Powermate 5000W...
My family and i have ran off genorators for 2
some generators honda springs to mind have a thermal cutout usually connected to the on / off switch wiring for the ignition they usually come in the form of a little bolt on part. trace the wiring and see what you can find.
beware though your machine could be overheating and the cut out working correctly.
make sure that the cooling fan on the engine is ok there are no blockages / restrictions and is your machine in a suitable place to get plenty of cool air ?
Apr 27, 2010 | Coleman Powermate Premium Plus 6250W...
Coleman 6250 ,no power generated
check your AVR card...if the brushes are fine...
Aug 16, 2009 | Coleman Powermate Premium Plus 6250W...
Engine runs but won't generate any electricity
Sometimes the generator loses the magnetic field that allows it to produce power. Do a Google search on "flashing a generator field". There are many ways to do it, but I would recommend doing some reading before trying it. Your "dead" generator could produce hazardous voltage once it comes back to life.
Also, before trying any of this, make sure the circuit breakers on the generator (if equipped) are not tripped.
Good luck and be careful!
Jan 19, 2009 | Coleman 10' X 10' Sundome Tent 9160K101
Not a 6250W but a 6500W Coleman Powermate Black Max.
Call Pramac Co. at 770-218-5430. I get parts from them every week. A service center left holding the bag when Coleman/Powermate went out. Ken's Repair
Sep 15, 2008 | Coleman Powermate Premium Plus 6250W...
Need operating manual for 6250
Their should be a twist value on the bottom of the gas tank.( were the fuel hose attaches.
Sep 13, 2008 | Coleman Powermate Premium Plus 6250W...
Coleman Powermate Premium Plus 6250W Portable Generator Logo
320 people viewed this question
Top Coleman Electrical Supplies Experts
John Trevino
Phil Walker
Phil Walker
Tim Garcia
Tim Garcia
Are you a Coleman Electrical Supply Expert? Answer questions, earn points and help others
