Question about Amana RC17 Microwave Oven
CS Code Got a CS code, checked things out and found the upper magnatron was bad, burned a hole in the air duct. Replaced the magnatron, still get a CS code after 5 secs or so. I tested and checked the lower magnatron and it seems to work fine. Not sure why its cutting off after a few secs. Any thoughts work be great. Thanks, Frank Monteleone 914.646.8105 after 4 seconds of running a cs code pops up
  • acmservice Aug 17, 2017
    CS is current sensing, it is drawing the wrong amperage or is being sensed wrong by the Hi volt board. Check For proper amp draw on each mag system. Possible bad mag, rectifier, connections, Hi volt board.
    Brigadier General:
  • 3,614 Answers
Failure of any one or more of the following components: HV board (see next step), HV diode (High Voltage Diode Test), HV capacitor (see next step), interlock switch, triac , HV transformer
CAREFULLY OBSERVE
Inspect foil side of HV board for burned tracks (foil) toward lower side of board. If burned, check HV capacitors and HV transformers for a short. Otherwise test other components as outlined above.
Posted on Oct 16, 2008
    Sergeant:
    Champion:
  • 334 Answers
Cheak door hindge mechnizem
Posted on Oct 08, 2008
How CAN i TEST MY MICROWAVE?
Most common cause of an F7 code on these models is a bad inverter or magnetron. Generally it is best to replace both the magnetron and the 1100 watt inverter board at the same time, since a bad magnetron is usually what burns out the inverter board.
Jul 24, 2014 | Whirlpool Gold GH5184XPS 1.8 Cu. Ft. Over...
CS Code
Inspect foil side of HV board for burned tracks toward lower side of board. If burned, check HV capacitors (High Voltage Capacitor Test Procedure) and HV transformers (High Voltage Transformer Test) for a short. Otherwise test other components as outlined above.
Solution: Replace defective components as necessary. If applicable, repair foil trace on HV board.
Hope that helps.........
Aug 29, 2008 | Amana RC17 Microwave Oven
Error code F81
A short somewhere and bad if it blows instantly--a shop repair as could be control problem or bad inverter(power for the unit) or even a bad magnatron---someone who knows their way around in this type of unit would have to make some tests---both the inverter board and the magnatron are over 100 each parts.
Jun 16, 2012 | Panasonic NE2157 - Pro I Microwave Oven,...
My microwave magnets keep cracking
Have you checked out your waveguide and stirrer? Also ensure you have good connections & earths.
Feb 04, 2010 | Kenmore 62622 Microwave Oven
The magnatron quit - is it worth getting fixed?
Magnatrons rarely go bad.
Check your door safety interlock switches. Do you open the door while the oven is operating?
If yes, you have burned the contacts of the little micro switches to the point that they are not functioning.
When this happens, the oven doesnt know the door is closed and will not turn the magnatron on.
Remove the cover, DONT TOUCH THE SILVER CAN, check the switches for contunity.
The other possibility is the silver can is bad - dont touch it unless and until you undersstand withat it is and what it does. It can be very dangerous.
Replacement parts locally or www.repairclinic.com
If you need more help, let me know.
a
Oct 18, 2009 | Microwave Ovens
Jenn Air Microwave Error Code
Hello Hec1152,
I have found the manufacturer contact information for you, but could not find information about the error code. If everything works fine, but the microwave is not heating your food, then the problem is most likely the magnatron or one of it's components, which sadly to say is the most expensive part to replace. Please feel free to contact the manufacturer via phone or live chat to get more details as to what the error code means.
If you would not mind, could you please rate my help. I would greatly appreciate it.
Nov 29, 2008 | Jenn-Air JMC7000 Microwave Oven
Microwave Arcing inside
Found the online service manual and did the troubleshooting necessary to determine it was the magnatron. I have one ordered.
Nov 03, 2008 | Sharp Microwave Ovens
GE spacemaker xl1800 and Pop tarts bad mix
it sound to me as if the high voltage diode is shorted. It could be inside the capacitor or out board the cap. The capactor could also be short but this is a rarity. Diodes are a cheep item . repace it and if it don't work its probably the magnatro. good luck.
May 13, 2008 | Microwave Ovens
Lightning inside microwave oven
You better be carefull my friend or you will start glowing in the dark!! LOL Just kidding. But I wont kid about how dangerous that metal cylinder can be with the holes in the top. Thats the magnatron. It has very high voltage going to it and you should never ever touch any wires going to it even if its unplugged as theres a capacitor in there that holds a charge for a time. f the oven is over several years old, Im sure the magnatron will cost more then a new oven, after you add labor and such. It just migfht be time to upgrade to a new microwave?? Good Luck
Aug 11, 2006 | Goldstar MW-1420 1200 Watts Microwave Oven
Amana RC17 Microwave Oven Logo
280 people viewed this question
Top Amana Microwave Ovens Experts
William Miller
William Miller
Shehu Pro
Shehu Pro
Are you an Amana Microwave Oven Expert? Answer questions, earn points and help others
