Question about Samsung SSC DVR Digital Video Recorder with 80 Gb Removable Hard Drive
SECURITY CAMERA SYSTEMI
I have a system installed,,the IP is 192.168.0.101, the port is 8,
I can view it thur my laptop, I have a d-link router .I view the cameras thru a web broser call ENVIEW
Remotely if I enter the IP of the DSL modem..which I get from Verizon..I can not view the cameras..
Is it my modem blocking me form viewing the cameras remotely..
Not a geek//
TY
Ed
rapconco@aol.com
Have you setup a Virtual Server within the D-Link router? This should be on the ADVANCED tab in the D-Links Admin Configuration interface. Upon setup, the router should allow pass through of your request to the network connected device.
You will need the following in this configuration:
Name of device: SSC21WEB (or whatever the name of your device is)
IP Address: 192.168.0.101
Protocol Type: TCP
Public/Private Port: 10000 - 65535
Schedule: Always
Good Luck...
Posted on Nov 01, 2008
Hi my box is saying no config
How to configure DVR, Computer, and Router for internet ...
? 8:51
https://www.youtube.com/watch?v=e4Ytmyg2Rs0
Sep 8, 2010 - Uploaded by David Norton
How to configure a DVR with the computer and router then view ... My security camera company was going to charge me big time to ... Hi David, thanks for the help. ... but he could not access mycctv but when I started using my internet .... how do i find out myuser and password i search my ip and it says ...
6 Ways to Understand Security Camera Systems - wikiHow
Dec 15, 2015 | Home Security
SAMSUNG SMO-211QN SECURITY SYSTEM
1. Connect LAN cable of Cable/ADSL modem or Direct Fixed/Static IP LAN Line to WAN port of IP Router.or hub/sw with cable/lan terminal
2. Connect LAN ports of IP Router/switch/hub(1~4 or 1~8) to Ethernet port SMO-211QN/SMO-150QN to be set up and to
Ethernet port of Local PC to use during setup.
3. Connect Video cable of Camera to MONITOR.
4. Turn on the MONITOR power.
This a basic setup local no internet static ip you will have to
follow directions for setup in the software program you install
on the computer the uset the computer. The computer connected to the lan terminal
I am just giving you the basics you are goilng to have to read
and understand the rest as far as the rest of the setup on the
computer This is from page 107 of your manual
Link to manual if you dont have it
http://www.retrevo.com/s/SAMSUNG+SMO-211QN+users+manual+?sub.x=75&sub.y=14
Dec 07, 2007 | Samsung Color Indoor Security Camera with...
I cant seems to be able forward ports on my TP-Link WR841N Router to view my cameras remotely. Pls can somebody help me with a solution. what should i do?
First, you need to know what's IP of Router and your Camera (or DVR). Then browse to IP of Router and setting up NAT port (or port redirect. If cannot you can give me your Skype, I will help you more then here.
Jun 06, 2015 | TP-Link Technologies TP-Link TL-WR841N...
How do i view my security system on line using my apple laptop system is sde 4001
You won't be able to access the system from a different network without changing some settings in the router. You will need to find out what ports the security system uses. If you bring up a web page to monitor/configure the system, then you'll most likely use port 80 (HTTP) or port 443 (HTTPS). If you see "www.something.com:3948", the port is the number after the colon.
You will need to go into the router and enable port forwarding to the IP address of the security system.
Oct 22, 2012 | Samsung SDE-4001 8 Ch DVR Security System,...
I have a H.264 DVR with system V2.00.R05. What app or system can I use to view on a iPhone 4S?
IP CAM VIEW found in the Itunes Market: http://itunes.apple.com/us/app/ip-cam-view/id471794610?mt=8# should work as long as you have the network settings properly configured in both your DVR and Home Network. I recommend setting a Static IP for the DVR on your Home Router. After you have assigned the IP goto the network settings on your DVR and input the IP Address you assigned, the SubnetMask of your Home Router(usually 255.255.255.0 or 255.255.252.0), and the Gateway of yourHome Router.(i.e. 192.168.0.1/192.168.1.1/192.168.1.254). While you are on your Network screen I recommend changing your default TCP Port andHTTP Port to something that is not commonly allocated. As with most Routers you must Create a pinhole in the firewall to allow the outside traffic in. Select your DVR's IP on your Router and Create Definitions for both Ports that you set on your DVR's Network Menu. If your DVR and Router didn't reboot after saving these changes reboot.On the phone ap I found the following two cameras to work with the H.264 DVR System V2.00.R05:
  • Make: Unknown Brand Model: DVR-9008HV
  • Make:A.V.Sistemi Model:A.V.Sistemi 61xx DVR
For the Host/IP field, You use your Home Routers Internet IP. TCP port is the number you set on the network menu of your DVR. Ch.# is the Channel Cam (1-8, and 9 being a single feed of all 8 channels)user names and passwords are case sensitive.
I hope this helps
Jul 07, 2012 | Apple iPhone 3G
I have just installed my Uniden UDW20553 Video Surveillance System. I was under the impression that I would have remote access to view my cameras from anywhere in the world on my laptop. Have looked high...
The only solution I have found is using Remote Desktop Connection and running the Uniden application. On my Iphone I found that using Pocket Cloud Remote Desktop (RDP Itunes download application) works best. You must also download a free application named "Pocket Cloud Companion" on the PC your Uniden software is running. Pocket Cloud Companion must be running for connection to made through 3G, Edge or Wifi networks. Also, you have to configure your remote connections by using your PC's IP address rather then the name of your pc, particularly if making connection on 3G network.
Feb 12, 2011 | Uniden Wireless Security Surveillance...
Can't view IP cam externally
Follow The Process:-
1.Visit https://www.yougetsignal.com/tools/open-ports
input the port 5000 and check is it open or not, if it is not open it means you need to check port forwarding in your main internet router/modem.
2. By Default Routers/Modems Http port it 80. so you need to change ip camera http port 80 to 81 and do port forwarding and to view on android devices check another ports in ip camera network settings. so same port forwarding and check in yougetsignal website.
Visit Here for next level help:-
CCTV Networking Technical Support
Jun 10, 2017 | D-Link Securicam Network DCS-950G Wireless...
How do i install ip cameras so that i can see them over the internet? I have a dvr connected to my 2wire modem and I do have static ips
You need to find out what ports your ip cameras use, and then setup port forwarding on your router. If you have 1 box that controls all the cameras, you just need to forward port 80 traffic to that box. If you have multiple cameras with NO main junction box, you will need to go into the setup on each camera, and specify a port to use.
Then in the router, set up port forwarding to forward each different port, to the camera it goes with. Then when you want to see the camera from home you would type the ip address in the browser, then a colon, then the port number --> IPADDRESS:81
Sep 12, 2009 | 2wire HomePortal 1100 Router...
Off site access to view security camara dvr
access the router look for portforwarding and enable port forwarding assign a name to your camera
type in the port your camera use. ex 593
then type the assign IP for your camera ex 192.168.1.6
to access it type in your browser the your public IP ex. 209.45.0.0:593
read your ip cam manual for accesing it.
Nov 12, 2008 | Computers & Internet
DVR camera system help
First, check what ports the DVR system uses, in GeoVision for example is:
80, 3550, 4550, 5550, 6550
So...
You DVR must be with Manual IP
And then, open the router management page and configure NAT settings, so that when someone in the outside network "calls" you ip+port, the router knows to which machine the "call" is...
Also... use some kind of dynamic dns service like DynDns or NO-IP so that people use an regular URL and not a IP address.
Aug 16, 2008 | Computers & Internet
Samsung SSC DVR Digital Video Recorder with 80 Gb Removable Hard Drive Logo
551 people viewed this question
Top Samsung Home Security Experts
Heilcode
Level 1 Expert
Are you a Samsung Home Security Expert? Answer questions, earn points and help others
