Acer 17 inch LCD Monitor when turned on fades in & out & doesn't light up
    Champion:
  • 293 Answers
Hi...there,
Well, that tell you that you got a busted inverter. Need replaced a new backlight inverter or repaired it... Have a nice day!
Posted on Oct 10, 2008
My Hp notebook screen is black,sometimes it fades in and out black to grey then to black.how can i fix it
Connect your laptop to an external monitor and switch to monitor. If the external monitor shows the desktop, then the complaint is in the lcd/led display unit means the screen. Replace the screen. If the external monitor also shows the complaint, then it is normally due the mch(media controller hub) . It comes as separate card unit in some models and onboard for some other models.Only an experienced technician can solve that issue. In some rare cases it is due to a corrupted BIOS. Reply if this helped you.
Sep 15, 2014 | HP G70-467cl Notebook Pc Lcd Back Cover -...
I have an acer al1716 monitor and since 2 weeks ago on the screen apears a box with the " input not suppported" message, then the pc shuts down. i may have changed the resolution settings and now...
the video settings on your computer has changed to a setting that the monitor doesn't like! try entering your computer in safe mod and change the setting to a max of 1024x768. however, if your video card has a dual output and you have 2 monitors connected at the same time then this is your problem. make sure that the 17" lcd is monitor 1 and the other monitor #2. one of the monitors is set higher the the 17" lcd and when it is not connected the computer may think this the setting for the 17" lcd and not the other monitor which may be hdmi or 1900x1080 which the 17" cannot read this it is out of range!
Aug 24, 2011 | Acer AL1716 17" LCD Monitor
Sir/Madam im shiva from chennai , i have acer AL1713B lcd monitor , but my prob is when i connect the power cable the led light is working , but display is not working. how can my solve this prob?
Dear Sivakumar,
please try to remove and plug VGA cable back again to the monitor. and press the menu button in front of monitor if it doesn't giving any message in monitor it means that the control card inside the monitor is faulty.for fixing that you have to contact your local service center.
Thanks
Jun 18, 2011 | Acer AL1713 17" LCD Monitor
Hello i have a acer lcd model AL 1715 SM it doesn t have a vga input and cable is damaged how do i chenge it
Apr 07, 2010 | Acer AL1715 17" LCD Monitor
Screen fades to white
Most probably failure in the LCD controller IC in the lcd controller board. that no signal was sent out to the lcd driver IC thus you could only see white display. A replacement of LCD panel is the best solution. best regards
May 25, 2009 | Chi Mei Corporation 736A (Silver Black) 17...
Acer 1716 17 inch LCD monitor, screen fuzzy w/white lines at rt
Common problem.
There are 8 small VRAM BGA chips.
1 or 2 of them needs REFLOW.
Basically board service.
Dec 16, 2008 | Acer AL1716 17" LCD Monitor
LCD Monitor wount turn on Black screen
my Acer AL1716 monitor will not come on after pressing the on button and no green light.
Aug 25, 2008 | Acer AL1716B 17" LCD Monitor
Snowy Raster on display
Hi mcuyg,
Hope this will give you hint in solving this problem. Try configuring monitor settings in OSD mode; contrast; brightness; etc.. other special settings can be accessed using combination of buttons to minimize the raster intensity. On hardware side try resoldering cold soldered points and check the SMPS side.
Best regards,
Rosener Guyano
Jan 27, 2008 | Acer AL1716 17" LCD Monitor
Benq LCD monitor
I had same problem. No Power at the monitor. what can I do?
Jan 03, 2008 | BenQ T705 17" LCD Monitor
Monitor repeatedly flashes Acer logo and computer display in cycles
We had the same problem with the 17" we bought in Aug. Sent it back for repair. Acer sent it back without fixing the problem. Started doing it again in Nov. This time I called a supervisor and they sent me a new monitor. Well yesterday it started doing the same thing. You can fix it temp buy unplugging it and holding down the on-off switch for 30 seconds. Please let me know if you have a better fix.
Dec 13, 2007 | Acer AL1715 (Black, Silver) 17" LCD...
Computers & Internet Logo
551 people viewed this question
David Payne
David Payne
