Question about Uniden Lands Phones
Handset is not showing any response, even though charge light is on. Unit only 1 month usage - have shecked instruction book.
I was able to correct the problem by taping down the loose connection on battery lead. Thank you for your follow up call.
Posted on Oct 09, 2008
Light stays on in the base unit and light flashes on handset. No messages--all have been retrieved.
If your charge light is flashing and you have no messages on your answering system, you may have voicemail. Voicemail is provided by your telephone company and they would be able to assist you with retrieving those messages.
May 15, 2015 | Uniden TRU9488 Corded/Cordless Telephone -...
Engenius handsets won't respond
Will likly cost more to repair that replace. Sorry, that is the way our society is today....throw away what dosen't work.
Jul 27, 2014 | EnGenius DuraFon 1X Handset DuraFon 1X-HC
VTech CS6409 register handset fails with no message
From what I read it seems you are trying to register and add a new handset to your system. I am also assuming that the handset is de-registered.
A common problem with registering a handset to this system is Owners Press and Hold the # sign before releasing it. This button is to Press and IMMEDIATELY release. DO NOT HOLD. If this does not solve your problem then
With a charged battery in the handset, the display should read "1.PRESS FIND HS ON BASE 4 SEC and 2.THEN PRESS # ON HANDSET" if it say so, then when you press and "IMMEDIATELY RELEASE " the # sign on the handset the information should change If the screen goes blank when you do so and return to "1.PRESS FIND HS ON BASE 4 SEC and 2.THEN PRESS # ON HANDSET" then you will have a bad battery or your base memory is full.
Replace the battery and try again. If no change then
The best way to go is to clear the system and re-register all the handsets. Begin by removing any handset from the main base cradle. Then
Press and hold /FIND HANDSET on the Main base until the IN USE light turns on and starts to flash. then release it, then without pause Press and Release it again. That will clear the system and de-register all your handsets.
All handsets will show 1.PRESS FIND HS ON BASE 4 SEC and 2.THEN PRESS # ON HANDSET. To re-register follow this instruction
Jun 02, 2017 | Vtech Lands Phones
System error #1 Panasonic kxtg2770
1)On handset, press MENU, 0, 0, 1.
Handset display shows as follows.
*Skip this step when handset already shows as above.
2) On base unit, press LOCATOR for 3 sec until CHARGE LED flashes.
3) On handset, press OK button. Then wait until the handset display changes as follows.
If you receive an error message indicating the maximum number of handsets have been registered, you will need to deregister the handset from the base unit, then try to register again.
*If this does not work, your unit is defective. Please send your unit for service.
Panasonic Services Company Customer Servicenter
Suite B 4900 George McVay Drive
McAllen, TX 7850
McAllen, TX 7850
1) Press FUNCTION on handset. Then, using the Navigator key, press Down (V) 4 times, Right (>) 1 time, Down (V) 7 times, Right (>) 2 times.
2) On base unit, press MUTE. (MUTE LED flashes.)
Dec 04, 2010 | Panasonic KX-TG2770 Phone System w/...
No led when handset on charge. no response. phone dead. Handset has not been used for few months.
1.The handset might have collected moisture , so you need to dry it out.
Remove back,sim and battery dry out by placing in a warm room NOT ON THE RADIATOR for 6 hours then connect back together then try.
2. Also take into account that no led`s will perhaps show until after 30 mins of charging i.e screen blank.3.
The phone may be dead due to the battery not having been charged for so long , go to your dealer and ask to check it with a new battery.
Hope some of that helps!
Nov 19, 2009 | Samsung SGH-i900 Omnia Unlocked Cellular...
GE Model 27911 DECT 6.0 Additional Cordless Handset not working
I took the post that mentioned removing the battery, waiting a few minutes and then reinserting it.  It worked.  Thanks to that person.
Apr 14, 2009 | Uniden Cordless Phone
Searching for base and battery loses power too soon
Have the batteries been changed since the system was purchased... 4 years is a fairly good usage for batteries in that type of use.
Good news you should have no trouble buying replacement batteries... even walmart has them. Open the back of one of the phones... the battery has a small plug.. pull that out and you will see the part number... about 25 dollars each battery pack... cheaper if you are in the states.
One note tho... when you replace the battery pack you need to charge it for at least 12 hours prior to the first usage 24 hours even better.
Robert
Dec 19, 2008 | Vtech 5.8GHz Cordless Phone with Digital...
Semi Dead Panasonic KX-TGA100N with ''C533'' displayed.
Panasonic KX-TG1050N Cordless Phone. Base handset (No. 1, KX-TGA100N) does not work, no keypad response or dial tone. Green indicator message light ON (should only work with the TG1000N base unit) all the time till battery runs down. Display shows message ?C533?. Can still send and receive calls on extension phones 2 and 3.
Nov 11, 2008 | Panasonic KX TG1000N Cordless Phone
Base does not charge handset
If all 3 handsets fail to charge on the base unit that leads one to the conclusion that the charger with-in the base unit has gone bad and I really don't know of any fix. Thank You. Jerry
Dec 28, 2007 | Uniden Cordless Phone
"searching" message even when handset on the base
Found the following in AT&Ts FAQs for your phone, I'll leave only what might be relevant: # Charge the handset for 12 hours. After the first charge, the battery will quick charge in only 8 hours. Re-cradle the handset nightly for recharging. The battery will not overcharge. # Connect telephone line from base to unit to modular telephone jack. If cord is already plugged in, unplug and reconnect at both ends. Also, you may want to try another cord from a working telephone. See the owner's manual under "Connecting to Phone Line." (you can get the manual here on the product page in case you lost it) # Try a working phone at the jack. If another phone has the same problem in that jack, the phone jack is defective. Good luck, hope you work it out
Jun 03, 2006 | AT&T 2256 Cordless Phone
Lands Phones Logo
26 people viewed this question
Top Uniden Lands Phones Experts
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
