Question about Zanussi Washing Machines
Zanussi washing machine.
How to fit a new rubber ring on the inside of the washing machine door.
    President:
  • 1,462 Answers
Switch off
remove plastic clamp that holds seal to cabinet and peel seal off cabinet.
the inside of the seal is held onto the tub with a circular spring. push seal down (needs a bit of force), pull outwards and seal will come away from tub.
lubricate the slot in the seal that fits onto the rim of the tub with washing up fluid.
starting at the top, push the first little bit of the slot in the seal onto the rim of the tub.#
working in both directions, push the slot onto the rim until completely on. this is a knack so be patient.
the circular spring fits into a slot on the outside of the seal. this is quite difficult to get into place and extra pair of hands will help.
fit seal onto cabinet - this is easy - and refit plastic clamp
test for leaks on wash cycle as water level is higher
Posted on Oct 09, 2008
Hi, I appreciate your offer of help but I needed to fix the problem immediately. Because of this I sought the help of a washing machine servicer, don't ask me how he did it, I haven't a clue! but thanks again anyway, if I need you in the future have no doubt I shall call you.
Regards,
Jean919
Zanussi fl 1084 washing machine door seal. How do I replace the rubber seal?
the seal comes in a shrunken size use a hair dryer to stretch it on to the door lip
Dec 03, 2013 | Washing Machines
How do I replace the metal retainer ring arond the rubber door seal of beko washing machine
This video will show you in detail how to replace the door seal gasket and fit the new one properly to Beko washing machine How to Replace Beko washing Machine Door Seal
Jan 25, 2013 | Beko Genuine Washing Machine Door Gasket...
The rubber seal came off of the inside during the spin cycle - behind door against the tub -- and a wire ring came out. I put the rubber seal back on but have no idea where the wire ring would go? Is this...
The wire ring is the seal retaining spring, it fits in a groove at the rear of the door seal.
Double the seal back in the drum, and fit the spring around the seal at the rear of same, it fits inside a groove, it is difficult, so persist and be patient.
Please rate my solution.
Thanks.
Nov 03, 2009 | Bosch WFMC 3200 Front Load Washer
Gunge is accumulating around rubber ring at door of machine
Clean with a mixture of baking soda and detergent in hot water, rinse and dry. Leave the door ajar after each wash so that the interior will dry. Front loaders have no venting.
Sep 30, 2009 | Zanussi IZ12 Front Load Washer
Bought new rubber seal for whirlpool but no instructions how to fit.has 2 wire rings front and back of seal so how do you fit them around the new seal. do you work from the back of rubber seal first ie...
this is why we are paid to do the tricky stuff. Ok, remove the lid then open the door. look for the front pring loaded wire then remove. Pull front of seal off ridge then bend it back into the tub so it allows you to work easier. you will now see a second large ring holding the other end of the seat to the tub. remove it then pull the faulty seal out. Follow same proceedure putting it back. careful not to tear boot as it is silicon.
Sep 15, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Zanussi fjr1454w door seal change.
with both clips,< locking rings > removed seal it is removable by just working it off the drum slowly,< there is overflow tube in front bottom side to disconnect also>. It is very important when installing new one that you put it in the same positiont as old one and lock rings go on same as well.
Apr 26, 2009 | Zanussi FJ1454W Front Load Washer
Replace rubber seal on my zanussi washing maching
the only way to fit door rubber to tub on a zanussi is to use washing up liquid it takes two mins
Sep 28, 2007 | Washing Machines
Fitting a new door seal
unplug machine. Pull off retainer clip from the front , with both hands inside push up the seal untill its free. Then with the new seal apply washing up liquid to the gap on the seal. And fit this is fiddly. Then pull the spring you removed to loosen abit and with a screw driver to keep it in place throught the door lock thats why youve unpluged it. strech the spring around. the ease on the front part of the seal and replace the clip. put on a wool wash to check for leaks. appliance doctor
Feb 05, 2007 | Zanussi IZ161S Front Load Washer
How do I fit a new door gasket?
after putting the seal on with the aid of washing up liquid put the spring on first by the door catch hold it on with one hand and isnert a screwdriver in the hole for the door catch this will enable you to hold the spring on if you put your knee against the screwdriver giving you two hands free to push the spring on
Aug 04, 2006 | Zanussi FJS1225W Front Load Washer
Washing Machines Logo
135 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
