Printer won't print form command
My printer won't when it's commanded from my computer.
  • 781 Answers
Wow.. your problem has way too many possible causes... you need to give more details for me or someone else to provide you detailed assistance to solve your issue..
start by checking the obvios..
1. has it ever worked? if no it may be broken
2. check your printer is connected to the computer and that your printer power cable is connected.
3. is your printer properly installed? make sure if you are connecting the printer to your computer for the first time you need to install drivers for the pc to know what to do with the printer when you send documents to it to be printed.
4. if 1, 2, 3 had been checked.. try to go into the services applet (start>control pannel>computer management>services if your are using xp) and restart the print spooler service (that should kick your computer electronically and should get the printer to work again possibly)
post more details like what printer you are using, wheter is the first time you're using it, what operating system you have...
give as many details as possible and will try to provide some solutions.
good luck.
Posted on Oct 08, 2008
Iogear GUB231 won't pass printing command
Make sure you are selecting the printer after you hit print button. Sometimes there are other printers listed that are not installed and you end up sending spool to them. Also make sure you set the printer
Dec 28, 2012 | IOGEAR TECHNOLOGY IOGEAR GUB231 - USB...
After giving the print to immage runner 400s copier the print sends to the copier. The data button blinks once. but print out automatically cancels. why?
Windows Server 2003/Thin N Computing thin client L300 Printer Epson FX2175 installed with thin client when dos base print command is given 1st page is printed but when 2nd print command is given printer gets offline either switch off printer before giving comman or print from printer properties. Again third page print command is taken by printer (For alternate pages print command printer gets offline automatically)
Aug 29, 2012 | Canon imageRUNNER 400S Copier
MY DELL V515W PRINT JOBS JUST SIT IN QUE AND NEVER PRINT FORM MY LAPTOP. I HAVE DONE ALL THE DIAGNOSTICS, HAVE RESTATRED EVERYTHING, RE-INSTALLED THE SOFTWARE AS A CORRECTION. IT WILL WORK FOR A DAY, THEN...
Are you printing directly to your printer or printer in a network?
If you are printing directly, the problem is the Print spooler maybe stop.
To restart this, follow this procedure
Go to START MENU
Choose Commamd prompt, right click mouse and run as administrator (You should be in this command C:\WINDOWS\SYSTEM32- If not type this command when you in the dos command prompt "CHDIR C:\WINDOWS\SYSTEMS32 and press enter")
Type the letter "cmd"
Type the word "net stop spooler"
Exit
Go to C: drive
Choose to Windows Folder
Click show content
Choose system32 folder
Choose spool folder
Choose printer
And delete all printing jobs pending
Again go back to CMD window and type the word "net start spooler"
Restart your computer and must also turn off your printer and then switch it on.
It will work fine right now
I hope it helps you
Please let me know it you need more help. Regards
Mar 22, 2011 | Dell AllinOne Multifunctional (v515w)...
Printing labels from SAP ECC 6.0 using smarforms, label prints however the printer commands themselves are showing on the label, not just the information the print commands are to control. Is there...
Hi there
Does this printer connected with your computer? If yes, there is a problem on printer driver. You need to add new printer with same name and if this successfully installed, you can delete the old printer icon.
When there is errors message or wrong command of printing, the usual problem is corrupted driver.
Another way to correct this is to uninstall and reinstall the printer driver if the first solution does not work.
If still not working, try this download and install the print diagnostics software. It will helps you to find and fix errors in the windows registry. Here is the link http://www.out-of-warranty.com/print-diagnostic-utility-for-hp-lexmark-canon-dell-xerox-and-everything-else/. Click on the blue text PRINT DIAGNOSTIC UTILITY and it will download automatically. Unzip it to install to your computer.
I hope these solutions solve your problem. Regards.
Feb 09, 2011 | Zebra RW 420 Thermal Printer
It won't print anything, the command would be
you have lost your printer driver .
delete the original one in add and remove section and re install it and it should be printing after that
Sep 28, 2009 | Office Equipment & Supplies
Hp 1400 does not print from print command by computer
sir reinstall your printer software and drivers or follow my commands go in your start>printers and faxes>and right click on your printer>properties>ports and select your port and apply
Jun 03, 2009 | HP PSC 1410 All-In-One InkJet Printer
Printer dont print 2 command
i experience it before but i just restart the pc and printer or the printer itself and after a while its ok..^_^..
May 17, 2009 | Lexmark X5470 All-In-One InkJet Printer
My printer won't print from the computer command; it will print fax or copy a paper.
MY PRINTER WONT PRINT FROM THE COMPUTER. IT WILL COPY A PAPER, BUT NOTHING FROM THE COMPUTER COMMAND.
Nov 04, 2008 | HP Officejet 5510 All-In-One Thermal...
Printing 'Form information: No form stored' non stop
rchamorro,
Sometimes, resetting the printer to the factory defaults solves some of the problems. For troublehooting and to overwrite all stored parameters, send the ^default command.
Mar 14, 2008 | Zebra LP 2844 Thermal Printer
k24674
jasbo
jasbo
