Question about Asko Dryers
Very little heat - Asko Dryers
  • 750 Answers
Hello srg14846
Welcome to fixya.
You said,very little heat
You must elaborate??????
What is your brand, model number and year or age of your dryer???
waiting to assist you!!!!
Huuum
Posted on Oct 08, 2008
Nutone 9091 - coils heat up and light works but no heat dispersed.
Open the back, check each little part that has wires going to them for continuity. Theres prob about 6 or 7 of these little fuses and parts. When you find the one that has no continuity, replace it with a new one and you will have heat again.
Jan 24, 2015 | Dryers
Blows little heat
Check the filter & indoor coil...could be plugged up.
Dec 13, 2013 | Goodman Manufacturing Goodman GPH1360M41 5...
Maytag mod. #med5700tq0 elec. dryer runs, inconsistent heat, high heat two days ago, little heat a few hours ago, some heat an hour ago, no heat now. Where is the best place to start?
It sounds clogged up to me. Take the exhaust hose off the wall and try it first. Another thing that happens with Maytags is that the motor shaft will **** out the center of the plastic blower and even though the motor is turning, little or no air is moving through the machine, so the high limit thermo turns the heat off
Oct 18, 2011 | Maytag MED5700TQ Electric Dryer
My husband just replaced the thermastat due to very little heat, still no more heat, theres very little heat & none if I turn the fan up, the fan seams to cool the heat what little there is.
there maybe air in the vswystem or you may need a new heatercore try fulsh the air out take the hoses off the heatercore and run water threw it with a garden hose.goodluck
Jan 17, 2011 | GMC Jimmy Cars & Trucks
2004 Dodge 1500 Rear sliding window latch broke. Latch is fused to the glass. how do you get off the old one?
with a little heat, use a heat gun use someting like a small saw to cut in half then use a ravor and keep diging to release the glue holding it to glass, this takes time, but can be done,try to remove peices of the latch little by little, some times just heating and a blade does the trick,
Jun 14, 2010 | Dodge Ram 1500 Cars & Trucks
Very little heat from heater truck can be running for long time very little heat comes out
You HVAC unit is not getting the heat from your engine coolant. A valve is stuck or there is blockage in the heat exchanger core. I'm assuming you fan and vent divertors/Controls are working correctly. Does AC work?
Jun 13, 2010 | 2000 GMC Sierra
2000 Pontiac Grand AM little heat being produced.
1st thing to do is change the thermostat. It is either missing, or stuck open (you provide good info). This is why the car is not running at operating temp and why you have little heat. The no blower for settings 1-4 probably means a bad switch.
Dec 17, 2009 | Pontiac Grand Am Cars & Trucks
Very Little Heat.
HAVE THE BLOWER MOTOR WIRING CHECK
Jan 22, 2009 | 1994 Dodge Caravan
Gas dryer not heating up if any heat at all very little
so long as its heating a little, try removin g the venting, and see if there an improvement. a clogged vent will greatly reduce if not stop all heat . dont forget to check where venting exits the home outside also becomes clogged
Mar 05, 2008 | Dryers
Dryers Logo
41 people viewed this question
Top Asko Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Are you an Asko Dryer Expert? Answer questions, earn points and help others
