Question about Xante CL30 HSE Laser Printer
Xante CL30 Fatal Error 127 Code
We have had our printer for 5 years and have printed without too may problems. However this error code is now popping up after we attempt to print a few sheets and it freezes the printer up. We have to shut down and re-start, but then the same thing happens again. Do you have any solutions to this problem?
Thanks,
Steve
  • jayneellen Oct 13, 2008
    I've been in touch with Xante, who say code 127 is to do with the fuser unit cooling fan, which can be found inside the lid of the printer and sits right above the fuser. A trained technician is needed to replace this; I'm trying to source one now, as many can't get Xante parts.
    Apparently if the fan is replaced and the problem reoccurs, then there may be a problem with the engine control PWB in the printer.
    Will let you know how much it costs to fix once I know!
Printer is now fixed - fan cost £47.00, engineer to fit it was £60.00 (but also gave the printer a service this price). I will attempt to find the exact part number for you.
Beware, our fuser unit was damaged after trying to print too much whilst this error was coming up, and hence we had to buy a new one at a cost of £190!
Posted on Dec 26, 2008
When to many consumable is low at the same time.
Posted on Dec 10, 2008
What is a Fatal Error: 140 on a Xante HSE?
That error is image yellow drum up/down senser. Shut down your printer and reseat the drum make sure it is loose and not tight when placing it into the unit.
Oct 02, 2014 | Xante CL30 HSE Laser Printer
Fatal error 20
this is a memory issue. remove the memories an dopen the printer if it open ok, close it and try putting one memoery at the time.
Dec 07, 2013 | Xante CL30 HSE Laser Printer
Fatal error 142 xante Cl30
it's a problem with cyan ID. clean the cyan drurum's contact and the cointacts inside the printer where cyan drum ''sits''. if not try with a used drum.
Aug 22, 2012 | Xante CL30 HSE Laser Printer
Fatal error 153
check with a different black drum
Jan 17, 2012 | Xante CL30 HSE Laser Printer
Fatal error 133 xante cl 21. Course for this
yellow led head. swap yellow with cyan and see if the error changes
Feb 14, 2011 | Xante CL30 HSE Laser Printer
177 Fatal Error
Error 177: Thermistor indicates Low Temperature (COLD) Error.
Usualy the fuser has overheated first (error 172/176) and tripped the thermal protection causing the fuser not to heat up anymore.
Normal procedure if a restart doesn't fix it is to replace the fuser unit.
Dec 29, 2010 | Xante CL30 HSE Laser Printer
What does error code 032 fatal error mean and how can I fix it
Here's the link to your 500 page Manual. I used the search function at the top of the Abobe Doc which it is formatted as and typed in your error.
It won't call up anything about 032 but Fatal Error recommends only "Call For Service".
Not very helpful is it?
Oh well, please don't thrash my rating with 2 blue thumbs or less. I tried. :(
Regards,
MArcus
Sep 16, 2010 | Xante CL30 HSE Laser Printer
Xante CL30 Fatal Error 177
I think that's a buffer overflow error, but if you get that error no matter what you print I would check to make sure your memory isn't bad.
Feb 13, 2009 | Xante CL30 HSE Laser Printer
Xante cl30
If the printer is still under warranty, and a new yellow drum doesn't fix the problem, or if you install a new drum and the problem returns, Xante should provide you with warranty support. This problem can be caused by a defective high voltage power supply, and that is not a user replaceable item.
May 02, 2008 | Xante CL30 HSE Laser Printer
Xante Cl30 laser printer error
Error 125 is indicating an error detected at MT home position, which means the transfer belt may not be returning to the proper start position. The normal solution to this, if it persists after a restart, is to replace the transfer belt.
Mar 26, 2008 | Xante CL30 HSE Laser Printer
Xante CL30 HSE Laser Printer Logo
481 people viewed this question
Top Xante Office Equipment & Supplies Experts
Ottoniel
rey francis basa
rey francis basa
Dudeman321
Are you a Xante Office Equipment and Supply Expert? Answer questions, earn points and help others
