Question about Bose 151 Main / Stereo Speaker
Do all speakers have fuses? I may have blown one of my Bose 151 outdoor speakers, but can't find a fuse inside.
I get no sound from one of my Bose 151 outdoor speakers. I was hoping it might be as simple as a blown fuse, but I can't find a fuse inside. The speaker cone appears to be in perfect condition, but no sound is being produced. Yes, I hooked up the other speaker to the same channel, and the other speaker works find. Many thanks.
  • 1 more comment
  • Bill Oct 08, 2008
    They're 4-ohm speakers. My multimeter reads infinity on the bad
    speaker, and about 1 ohm on the good one. I don't know anything about
    reconing, so I will look for a replacement driver, as you suggested, or
    more likely, just replace the speakers altogether. Just wanted to make
    sure there wasn't a simple solution that I was overlooking, before I
    discard these.
    Thanks so much.
  • Anonymous Mar 18, 2014
    how can I get a toy out of my bose 701 speaker?
  • Anonymous Mar 22, 2014
    Melted inside
  • 4,234 Answers
Unfortunately many speakers do not have fuses. Most likely the voice coil has opened up inside the speaker itself. You can either get a replacement driver (speaker) or re-cone the one you have. In any case, the driver needs to be replaced.
You can verify this if you use an ohmmeter. With an 8 ohm impedence speaker, the reading should be about 6 ohms. If you read a higher number or infinity, the coil is bad.
Dan
Posted on Oct 08, 2008
Blown Fuse and Need to replace
For technical help Call Bose.:
1-800-380-4831
Mon. - Fri., 8:30 AM - 9 PM ET
Sat., 9 AM - 6 PM
If you're not in North America see this site:
http://worldwide.bose.com/productsupport/en_us/web/home/page.html
Jun 14, 2015 | Bose Companion 3 Series II Multimedia...
Bose 321 power woofer buzzes but produces no audio sound
I assume the other two speakers are working fine. Contact Bose and ask them. Could be a simple fuse. Sounds like a fried speaker driver, but do this first. Take the back off and check the power amplifier for a blown fuse. If none, disconnect the power amplifier. Reconnect the speaker cabinet w/o the built-in power amplifier to a known good amplifier to see if the speaker works. If it works then you know its the built-in power amp that's fried. Contact Bose for a replacement or better yet buy a another one with a higher RMS watt capacity. Wattage ratings in other than RMS are worthless. JBL and Cerwin Vega produce high wattage units. You need to keep the volume lower to avoid the problem in the future.
Aug 27, 2012 | Bose Audio Players & Recorders
Radio and navi won't turn on. Tried looking for blown fuse but unable to locate one. Help.
It helps to state what radio you have.....So did you find the fuse and its good?and getting power or just tried to find it? Try fuse 11 and 13 for the Nav. Fuse 8 and 9 inside and fuse 4 under hood for BOSE SYSTEM. Fuse 8, 9 under dash and 48 under hood for non BOSE
Dec 01, 2010 | 2003 Acura MDX
My left side speaker is not working i suspect fuse blown but where is the fusebox situated on my BOSE 901series III.
There is no fuse in a 901. Have you swapped channels, speakers, bypassed the EQ to ensure it or its pathing has no part in the failure?
Oct 28, 2010 | Bose 901 VI Main / Stereo Speaker
Is it possible to change a fuse
the 1.0 A is the amps .
bose are very secretif when it comes to the the Head deck .
if you are keen on opening the head deck and try to look for a fuse , go ahead but i would suggest to doe the following , place a set of hear phone in the jack output and turn the music on .
if it does work , you may have blowned the main speaker output .
if it does not work at all , you may have fuses may have gone but check inside the system as next to the speakers output you may have a fuse in line hidden .
Please make sure all power is diconnected prior to opening the device .
best of lack and let me know how you go
Sep 29, 2009 | Audio Players & Recorders
No sound from speakers ( lifestyle 20 )
remove the screws that hold the amplifier block to the speaker.the fuses are in the amplifier inside
Jun 14, 2009 | Bose Lifestyle 20 System
Quiet Speakers
Check inside the amp you might have blown a fuse in one of the channels
May 23, 2009 | Bose 3·2·1 II System
Hi, I Have a Warfedale pro BX1780sd unit, last night during a performance the mains fuse (8Amp) on the back of the pannel blown. I looked in saide today and found that both the 15 Amp fuses inside the...
check shorted rectifier diode in main power supply,check shorted power transistors,if it is power IC amplifier unsold it put fuse if doesn't blown up the problem is solve.
Sep 07, 2008 | Audio Players & Recorders
Bose 151 Main / Stereo Speaker Logo
2,276 people viewed this question
Top Bose Audio Players & Recorders Experts
Electro Med Services...
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
