Question about HP Officejet J5780 All-In-One InkJet Printer
Mirror image turn off switch
Under settings I have to go and turn off the mirror image switch---after I make a good print and want to make more, the switch automatically changes back from off to on again----is there a way to make it stay in the off position?
  • Anonymous Oct 10, 2008
    I've got the same problem. I downloaded service pack 3 and bam! I go under settings and I have to go and turn off the mirror image switch---after I make a good print and want to make more, the switch automatically changes back from off to on again---- How can I make it stay in the off position?
  • Anonymous Mar 20, 2014
    how do I change settings
It's letseatok again----I went and uninstalled the printer from the control panel and re-installed the printer using the cd-rom that came with the printer and that solved my problem. I guess for all programs, it's a good plan to reinstall them if they don't work the first time---it could be a small glitch that causes the problem, so start over-----for me everything turned out fine and I hope it works for you as well.
Posted on Oct 15, 2008
Does my HP Deskjet D2660 mirror image print
HI,
I had this same issue until i went to Control Panel>Printers> right click on printer in question>Properties>under General tab click Printing Preferences>under Advanced Tab click Mirror Image off>just in case that wasn't going to cure my mirror image turning right back on I went to the Printing Shortcut Tab and re-saved my shortcuts, checking back to Advanced Tab to make sure that the Mirror Image still showed off. I've had no re-occurrence of that issue since.
Thanks,
HP Printer Support
May 29, 2014 | HP Deskjet D2660 All-In-One InkJet Color...
HOW DO I DO MIRROR IMAGE PRINTING
go to start, printers and devices, double click on your default printer (the one with the check mark) click on adjust print options, click ok on the popup window, click on the advance tab and there you will see different options for your printing preferences. click on the plus next to printer features, you will see mirror image and it will say off next to it. Click on it and change it to on. click apply, ok and you'll be set! To turn it back off just use the same process but select off under mirror image printing.
hope that helps!
Oct 10, 2010 | ASUS Computers & Internet
HOW TO PRINT MIRROR IMAGE ON HP 7590
When you are ready to print do this:
1) Select Print from the file menu, on the page you want to print.
2) When the HP Officejet Pro L75XX Document Properties Box opens select advanced from the tabs at the top.
3) Open the tree under "Printer Functions" or if its already open select "Mirror image" and toggle the on/off selector to turn on the Mirror image function. You are done!
4) Return to the Printing Shortcuts tab to complete your selections for this print project.
Note: Remember to reset this function to Off so you don't waste a lot of paper printing something you can't use...
I hope this helps you.
Sep 30, 2010 | Office Equipment & Supplies
Print mirror image gel printer GX700
The mirror image setting is in the printer properties/ printing preferences. You can either go to control panel/printers/properties, or when you press print, and the window pops up, in printing preferences you can choose the mirror image setting.
Oct 13, 2009 | HP Officejet Pro L7680 All-In-One Printer
Changing a Printing Shortcut turns mirror setting ON and OFF.
The paper was tightened(delayed). I have not switched off the printer and with effort have extended a paper. Despite of it on the screen it is constantly offered to clear the printer
Jul 03, 2009 | HP Officejet Pro L7680 All-In-One Printer
I WANT TO PRINT MIRROR IMAGE ONTO MEDIA FOR A T-SHIRT
Hi I am Vortash if you want a mirror image of anything you print all you have to do is reverse it in the picture or the writings you are printing .. most good graphic/ paint programs will allow you to do this Paint shop pro to name but just one and Coral ?
So If you want the picture on your t-shirt the right way round after transfer just select mirror image before you start your print run .. Regards Vortash
May 16, 2009 | Epson Stylus Photo RX620 All-In-One InkJet...
My printer prints mirrored images. how do i fix it?
Believe it or not, many printer drivers have a setting that allows you to print mirror images. Try to go through the tabs of your printer settings, especially under "advanced", and you'll probably find it. I know you probably already checked, but these strange settings are often on a tab with some "advanced" button or something that can be missed. Good luck! tell me the exact model and make if you're still stuck.
Feb 01, 2009 | Office Equipment & Supplies
I have an HP L7680 all-in-one. It just started printing in a mirror image. What can I do to correct this?
thats becoz the mirror image as be enabled on the printing preferances of the printer settings. go to the printer icon under printer and faxes, turn off the mirror image,,,,,,,,,,,
Regards,  raj_p5983
Jan 11, 2009 | HP Officejet Pro L7680 All-In-One Printer
Printing mirror image/print
Go to control panel and go to printers or printers and faxes. If you see the printer icon right click on the printer icon and select printing preferences. Under printing preferences click on advance and look for mirror image. Click on mirror image and chage it to off
Oct 29, 2008 | HP Officejet Pro L7680 All-In-One Printer
Hp officejet pro l7680
To solve this problem, you need to set the mirror image to 'off' under the advanced tab of the printing defaults and under the advanced tab of the printing preferences buttons. We had this problem for some time and since doing the above this has stopped.
Steve
Oct 23, 2008 | HP Officejet Pro L7680 All-In-One Printer
HP Officejet J5780 All-In-One InkJet Printer Logo
616 people viewed this question
Seeker5211
Seeker5211
