Question about Whirlpool 21.0 cu. ft. Top Freezer Refrigerator with IceMagic Plus Ice Maker
Whirlpool refrigerator Keeps tripping the breaker when i plug it in
  • mjones165 Feb 11, 2009
    refrigerator keeps trpping the breaker
    is the an easy fix?
  • 24 Answers
Check the defrost heater most likely cause and a very common problem.
Posted on Oct 08, 2008
Etowsrxmq03
may have issues with the ground in the plug itself or in the wall plug, or might need a new breaker, they do get weak with time..
Sep 27, 2013 | Whirlpool Refrigerators
My Whirlpool refrigerator trips the main breaker of 40 Amps
A refrig cannot pull 40 amps in defrost , unless there is a direct short in the defrost system ( timer , heater , bimetal ) . I would use an extention cord ( for test purposes only ) , and try a different plug . Sounds like the circuit breaker is weak . In defrost , the MOST you should get , is 6 amps . This will not throw a 40 amp breaker . If you have an amp meter , remove the back refrig panel behind the refrig , and connect to one of the power cord lines (just not the green ground ) , turn into defrost and check the amps . This will tell you if short is in refrig , or weak breaker .
Sep 06, 2009 | Whirlpool ES5FHAXS Side by Side...
Dryer keeps tripping breaker. slight burning
The heating element is shorted. This is an electric dryer, right? replace the heating element. Make damn sure it's un-plugged when you work on it!
Jul 14, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Fridge keeps tripping the circuit breaker
Unless there is a dedicated circuit of 20 amps to the refrigerator this will continue to happen When your refrigerator goes into defrost and other things like lights fans air conditioners are on the same circuit it will have no choice to not trip the breaker. Try this turn the breaker off and how may thing in your house stop working? You need a 20 AMP circuit or this will possibly damage the compressor or weaken the breaker because it has tripped so many time. Thanks, Please rate my solution, I have done this work for 30 years. Thanks, Sea Breeze
If you have more questions or need help feel free to let me know, Thanks, Sea Breeze
appliancepartsse@yahoo.com
http://servicepartstec.blogspot.com/
http://appliancepartsse.blogspot.com
Jul 10, 2009 | Whirlpool ES5FHAXS Side by Side...
My fridge keeps trip the electrical panel
Have a company come out to service it if it is under warranty. First make sure that it is not a weak breaker, plug it into an outlet on another circuit.
Jun 22, 2009 | Whirlpool ED5SHAXM Side by Side...
get an inexpensive clamp amp meter (Harbor Freight has them). Turn off power to the plug. Remove plug from wall but do not disconnet wires. turn fridge OFF. plug the unit in the recept. turn on the power. set the meter for the higest reading (amps) & clamp it around the black wire. turn the fridge ON & observe start up current & the "run" current. If the fridge is within limits on the data plate the problem is in the wiring circuit, maybe a loose connection either @ the plug or the breaker. if there are several plugs in the circuit, the problem could be in one of them. In addition, if there is a gfi plug in this circuit, it could be faulty also.
Mar 01, 2009 | Refrigerators
Your fridge should draw no more than 5amp. Presuming your breaker is at least 15amp there's a problem. Move to a different circuit first. If the condition persists check the start relay on the compressor. I have a suspicion the circuit may have another item you are not aware of.
Mar 01, 2009 | Whirlpool GS6NBEXR Side by Side...
Frig trips circuit breaker
Hello gonzomg69,
The two other comments posed at you from Blue Dog and 20YRSEXP are good ones and necessary to get to the root cause of the problem however I have a few ideas to share with you that may help.. First off, I am assuming that the circuit breaker you mention is the one that protects the outlet that feeds your fridge power. If thats correct, and you just started to have breaker trips, the obvious question is ..does that circuit breaker also supply power to other receptacles and do those have any additional appliances or 'loads' on them that are drawing current? The circuit breaker current rating is based on the wire size so that regardless of what you plug into a receptacle, that breaker limits current so you won't melt the insulation or have a fire. Also, you should be aware that circuit breakers do go bad and that may be your problem too..
I hope this information helps you...
Regards,
Rick
Nov 28, 2008 | Whirlpool ET1WTKX Top Freezer Refrigerator
Whirlpool 21.0 cu. ft. Top Freezer Refrigerator with IceMagic Plus Ice Maker Logo
59 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
