I have a Minolta Dimage Scan Elite 5400 film scanner. I am getting white lines, running the long dimension of my 35mm negative scans. Never had this before. Turning scanner off & back on, shutting down PS CS2 & restarting, rebooting WinXP, unplugging & plugging-in USB cable (and combinations) all don't seem to help.
Comments:
Oct 09, 2008
- Thanks for your response. I'm wondering if it isn't a fixed hardware problem because from scan to scan the lines aren't in the same places and the number of lines varies from one or two to more "lines" than good pixels.
could be the component scanner inside of the minolta , it will need to be tested to determine if the scanners components or a wire strip is causing the problem or the component scanner its self , it sounds like a section of it is out so it will not see anything ------ ---------- in that section
Was this helpful?
Yes
No
Popular Solutions for Elite Minolta Dimage Scan 5400
when i open the software after a few seconds i get a message-
Unknown error.
confirm all...
(More)
Unknown error.
confirm all other DiMAGE Scan software is closed.
which i do and then it disappears. i am trying to run it on a mac leopard OX 10.5, and a tiger OX 10.4 both same effect, with either firewire or usb.
any ideas, apart from the window,
alan
last weekend my minolta 5400 ( not 5400 II) scanner failed to provide decent scans. by that i mean,...
(More)
last weekend my minolta 5400 ( not 5400 II) scanner failed to provide decent scans. by that i mean, after turning on, and during a batch process the first and second scans come out ok, but the third and fourth get to dark, next batch i get 4 extremely dark scans. any ideas ? thank you. antonio
