Question about Canon PowerShot SD630 Digital ELPH / IXUS 65 Digital Camera
Card locked! I went to use my canon sd 630 powershot and it will not take a picture and at the top of the screen it says 'Card locked!' What is this message and how do I get my camera to work again?
  • 2 more comments
  • Anonymous Feb 28, 2009
    card locked on screen
  • Anonymous Apr 02, 2009
    card locked.
  • akme Apr 13, 2009
  • tallest2008 May 19, 2009
    memory card no. sdc-32m is in camera and when turn on displays card locked
My camera Canon PowerShot SD630 DIGITAL ELPH/DIGITAL IXUS 65 out off work the lenc dsnt work bcose the battry was lowa atar the my camera stop intel now no work please inser me thank you
Posted on Oct 21, 2008
2 Suggested Answers
  • 11967 Answers
SOURCE: My Canon PowerShot SD 630 digital camera is
Move the slide switch on the memory card.
Posted on Sep 17, 2009
Memory card error message on a canon powershot A700
On an SD card there is a switch at the side which can be moved to protect the card contents (locked) or permit writing to the card (unlocked). Just move this to the unlocked position.
Sep 04, 2016 | Canon PowerShot A700 Digital Camera
I cannot format the memory card using my Canon Powershot SX110 IS Digital Camera. The option is greyed out in the menu and an error message saying that the card is locked is on the screen. THE CARD IS NOT...
You don't give any details about the card that is not working in your camera. I suspect it is not an SD card but an SDHC (high capacity) card. "SD" cards larger than about 1GB are actually SDHC cards. SD and SDHC cards fit the same slots, but they are slightly different electrically. Many cameras won't work with SDHC (high capacity) cards. SDHC is not backwards compatible.
If this is the case, try a card of 1GB or less. This will hold plenty of pictures, 60 times as many as the 16MB card. If you really need more space then just carry a spare 1GB card and swap when you fill the first one.
Jan 04, 2011 | Canon PowerShot SX110 IS Digital Camera
My camera says my memory card is locked but the button on the side is not locked how do i retrieve my pictures i have a canon powershot a480
Issue: [Memory card locked] message appears on the screen.
Solution: Change the memory card lock switch to the normal setting
The SD card has a lock switch to prevent existing data from being erased. To record images or movies this switch must be in the normal (non lock) position. Different brands of SD memory cards may identify this switch differently. Regardless the procedure should be the same. Please remove the card from the camera and ensure that the switch is not in the locked position. sdcardlocked.jpg
sdcardunlocked.jpg ---
You should be able to retrieve photos, but not writing or erasing if the switch is switched to write protect.
If it's not functioning correctly, the camera may need service at Canonusa.com.
Jun 19, 2010 | Canon PowerShot SD500 / IXUS 700 Digital...
How do i get the card lock message off of my powershot a480?
SD and SDHC cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
Apr 30, 2010 | Canon PowerShot A480 Digital Camera
Canon PowerShot SD 630 Digital Elph "Memory Card Error"
I'm sorry to tell that PowerShot SD 630 does not support SDHC cards over 2 gig.
If you want the camera to take a card over 2 gig then you are stuck standard SD cards.
The other camera does support the card because it's a higher model.
Regards.
Sep 03, 2009 | Canon PowerShot SD630 Digital ELPH / IXUS...
Card locked
there is a little switch on the left side of SD cards; if it's down, your card is locked and you cannot copy anything on it or delete anyfile, also you cannot take any picture by it. so you have to change the switch postion. just this! I hope this helps...
Nov 04, 2008 | Canon PowerShot A520 Digital Camera
Format restoration
Hey seasea911,
I've read nothing but good things about Art Plus Digital Recovery software, but if it's not working I would keep trying different software until I find one that works. I would make sure your SD card is not set to the locked position before trying to recover your images.
Sincerely,
Allan
Go Ahead. Use Us.
May 28, 2008 | Canon PowerShot SD630 Digital ELPH / IXUS...
The memory card is locked
I have a canon powershot sd 630 digital elph camera and suddenly, after 3 years of perfection it is telling me that every memory card I put in it is locked, when they are obviously not... can anyone help me?
Apr 24, 2008 | Canon Cameras
Card locked canon powershot sd750
Check the switch on the side of your SD memory card. It is a small sliding switch which has a lock position. Sounds like the switch is in the "locked" position. Unlock, reload card, & you should be good to go. If not, the card is probably damaged.
Mar 01, 2008 | Canon PowerShot SD750 / IXUS 75 Digital...
Canon PowerShot SD630 Digital ELPH / IXUS 65 Digital Camera Logo
403 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
