Question about Emerson EWF2704 TV
No vertical drive?? Quarter inch wide bar of light from side to side.
Is tv worth repair. Set is 4yrs.6mo. old.
sound ok, changes ch. ok. bar of light has color and changing picture,but
won't open up all the way top to bottom.
At nearly 5 years old its probably better getting a new TV, not only will you be getting much better new technology but paying for repairs on a tv that could breakdown again in 3 months and cost even more.
Posted on Oct 08, 2008
Panasonic TC-P50VT20 blank screen with vertical lines
If you wish to get some details; visit the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts
Apr 05, 2017 | Panasonic Televison & Video
42 inch philips plasma HDTV vertical bar on screen
does the vertical lines appear like solid vertical bard infront of the pictire??
Jul 08, 2008 | Televison & Video
All printouts have a 3/8 inch wide light vertical line -
Try an old toner cartridge if you have one. Does it do it when you use the copier function. Steven 805-520-3003
May 12, 2010 | Brother MFC 9700 All-In-One Laser Printer
26 inch TV turns off 3-15 times when 1st turning it on - it has a slightly narrowed and shortened picture that over 5 minutes becomes normal and the TV runs normally until turned off - is it a major...
sounds like power supply maybe going depending on how old unit is may not be worth fixing goto pawn shop or thrift store or yard sale i got 26 inch from yard sale for 5 bucks works awesome!!!! Use it it it pukes,but in mean time l would look for replacement!!!!!
Jul 05, 2009 | Televison & Video
Vertical black bar down the middle of hitachi plasma tv
Ok if your hitachi TV dies with no power anywhere try this:
Some models have a kill switch under the bottom edge. It's like a gray switch like a small light switch press it back in and voila let there be LIGHT. Saves you at least a $200 trip to repair shop!!
Jan 05, 2009 | Televison & Video
Hi, I have a Panasonic XF Series 31" TV, manufactured in Nov. 1994, Model CT31XF4OR. The TV randomly goes from a full screen picture to a single line, about 1/2 inch wide in the center of the...
Sounds like the picture tube is starting to go, I don't believe it would be worth repair or even if you can get the parts for a tv that is almost 15 years old, time to buy a new one.
Oct 09, 2008 | Panasonic Televison & Video
Green translucient vertical bar on left side of screen
Cover green CRT lens with towel and see if red/blue video is normal......= bad CRT ?.............................T.
May 09, 2008 | Toshiba 57H82 57" Rear Projection...
No picture with Vertical bars across screen
It sounds like one of the flexes on the LCD cube has either become unplugged/ loose, (there is a gate that locks the flex in connector on the DMD board), or flex damaged. Has the TV recently been moved or strongly jarred?
Nov 13, 2007 | Zenith E44W46LCD 44" Rear Projection...
Wide black bar on bottom of screen
I you know how to repair electronics its not a hard fix. The worst case would be the vertical output IC but im thinking th its nothing more then a capacitor in the verticle sweep circuit The average cost to repair this should be around 75 to 125 bucks. Good Luck
Jun 01, 2006 | Toshiba 32A60 32" TV
Emerson EWF2704 TV Logo
78 people viewed this question
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
