Question about Bosch Axxis WTA 4107 Electric Dryer
Drum doesnt turn... motor fine.
Heard a lot of noise and flapping around inside before turning stopped
  • 3 Answers
From your description I would suspect a broken belt although I am unfamiliar with your model. Once the belt [which transfers drive from the motor to the drum] breaks, it would'nt matter how well the motor runs, it can't turn the drum.
Hope this helps!
Posted on Oct 14, 2008
Dryer drum moves about quarter turn/cycle then stops. please let me know the potential problem.
Your motor is probably going bad and it will run short time until overheated then after setting a little bit and cooling down it will run again for short time.
Aug 04, 2015 | Dryers
Machine is filling with water but the drum wont turn or spin
MOST LIKELY THE MOTOR IS SHOT OR THE BELT AROUND THE DRUM CAME OFF THE DRUM
Feb 06, 2013 | Washing Machines
The machine stopped spinning and started making strange noise. The motor seems to be working, but as if something is stuck. Any ideas what it could be?
It sounds like the belt around the drum of the washer is broken. The noise you hear is probably the belt flapping
Hope this helps.
Mar 07, 2011 | Washing Machines
Candy washing machine smoke coming from inside
it is rubbing on spin cycle due to being out of balance.Rubbing wont occur when turning by hand.
Stop by your local hardware store for a packet of drum balancers.
Aug 16, 2009 | Washburn Electric Guitars Modelno. X10-B
Whirlpool dryer WED5530SQ0, heats but does not run
So,. basically your drum doesnt turn. SO your getting heat still even though the drum isnt turning. Is this right? Sounds strange??? Do you hear any humming noise when you push the start button? I need to know a little more about the problem because im kinda confused as how you decribed the problem. Iv never seen a dryer heat but the drum not spinning. especially your model dryer. Its electric heat right? because if the drum doesnt spin, maybe your motor is bad. and if your motor is bad, then your heating element wont heat up because the centrifical switch in the motor is not switching to complete the circuit to the heating element. So this is why im confused when you said" Dryer heats when knob turned but when "push button" pressed, drum doesnt run." Because your belt wraps around the motor pully and the motor is what makes the drum turn. Like i said, i never seen this model dryer heat with out the motor operating. So if you can give me some more info, ill do my best to help you out....Thanks!!!!
Jul 30, 2009 | Whirlpool WED5500S Electric Dryer
Diverter Fan broke affecting air and heat
it is not you fan ticking. there is a big door in your heaterbox that switches from heat to a/c. alot of times the motor that turns this door gets jammed. if the motor is removed and the door turned manually, turning the car on with the motor {flap motor} removed still , turn the heat to cold, wait for the motor to stop turning, then bolt it back onto flap and you should be fine.mercedes is not perfect, sometimes you have to remove the dash to access this flap motor
May 27, 2009 | 2001 Mercedes-Benz C-Class
Kenmore Dryer Mod.76990100...shreiking noise when drum turns??
hi,
Dryer Is Noisy
1) Some noises are caused by objects bouncing around inside the drum. Scour the interior of the drum for loose objects.
2) If you cannot find any loose objects inside the drum, the noise may be caused by a defective part, such as a worn or defective drum belt, idler pulley, support rollers, glides, or worn motor bearings. It’s best to call an appliance repair service to replace these parts.
Thanks for using FixYa
Jan 03, 2009 | Kenmore 63942 Dryer
Have a "finshing" noise even when drum stops a turn
I had a similar problem and found a screw had backed out on one of the turning paddles inside the drum but the screw was on the under side , and could reach it through the access door , just had to turn the drum by hand till the screw was in sight.
just turn the drum inside by the paddles and shake them to make sure they are tight , thats how i found my problem and noise
good luck hope this helps , wayne t
Jul 14, 2008 | Dryers
Loud clattering noise
-Open the Front Cover. -Remove the Toner Cartridge -Remove the Drum Cartridge -Next locate the black gear attached to the end of the Drum and turn it with your fingers. -Check to see if the gear is locked, or difficult to turn. The gear will only turn in one direction. -If the gear won't turn at all, or if it catches while you are turning it, or if you hear the same noise when you turn the gear that you heard when the machine was on, the Drum Cartridge is the cause and will need to be replaced.
Jun 22, 2007 | Xerox WorkCentre XE88 Laser Printer
Bosch Axxis WTA 4107 Electric Dryer Logo
107 people viewed this question
Top Bosch Dryers Experts
Lawrence Oravetz
MightyMikeJr
Are you a Bosch Dryer Expert? Answer questions, earn points and help others
