Question about Brother ULT2001
Machine skips stitches when sewing thru several layers of fabrics
  • 4 Answers
Is your needle new? The needle needs to be replaced every 8 hours on a regular sewing machine, and the ULT benefits from even more frequent changes. Also try a bigger needle, if you're using a 75/11 move to a 90/14, make sure your needle matches what you're doing, you might not think those little needle tips differ much but they really do.
The manual also mentions if there is to much lint under the needle plate. Keep in mind all sewing machines need the bobbin area cleaned out every time you change the bobbin, but the ULT likes cleaning up down there about twice as often.
Posted on Nov 23, 2008
I have a CS 6000i which I have really appreciated. But now it is skipping stitches - mostly skipping. I have been sewing the same project and it had been sewing fine. What will fix it?
try increasing/decreasing the needle thread tension for the added material thickness
use scrap material until you get it right
Feb 14, 2017 | Sewing Machines
Thread doesn't catch when sewing heavy fabrics with White ESP sewing machine.
make sure the needle , thread, fabric are compatable with each other
the tension must be adjusted also
Mar 29, 2012 | Sewing Machines
My machine is skipping stitches
Lower the pressure on the feed dogs, use a stretch stitch, and longer stitch length. Be sure to use a good quality thread, and maybe go lighter weight thread.
Oct 25, 2017 | Janome Memory Craft 9000 Computerized...
I get skipped stitches when I use my decorative stitch #27 and ZigZag stitch sewing heavy layers of fabric. I have changed my needle, cleaned out the machine and sew very slowly; basically I have done...
Did you use a larger sized needle for the think fabric? It sounds like the needle isn't penitrating deep enough. You will need a larger needle size for the thick fabric and you might try slightly adjusting the tension tho a larger needle may be all you need. Make sure it is a sharp not a ballpt needle too (assuming you're not using polyester knits which isn't something one usually makes oven mitts with :) )
Mar 21, 2011 | Brother InnovIs QC1000 Electronic Sewing...
Sewing machine not stitching
Sounds like you need to retime the machine, if you email me I can attach instructions drivewithken@blueyonder.co.uk
Jun 26, 2010 | Kenmore 15212 Mechanical Sewing Machine
Skipping stitches and upper thread breaking on JCPenney 6600
Here are a few things to try.
* Raise your feed dogs if your machine has this feature.
* When you start to sew a seam, hold the upper and bobbin thread tails. Hold them back and out of the way as you sew your first couple of stitches. This will keep them from getting caught in your machine.
* Your fabric may require a different needle. Generally, heavier fabrics require larger needles and thinner fabrics, smaller needles. You may also need a larger needle if you're sewing through many layers of fabric. And make sure to use a ballpoint needle for knit fabrics and a sharp needle for woven (or a universal needle for either). And make sure your needle is appropriate for the type of thread you're using.
* Adjust the pressure of your pressure foot, it may be too light for your fabric.
* If your upper thread and bobbin threads are different types, try using the same thread for both. And use a good quality, brand name thread.
* Change your needle plate. Try switching to a needle plate with a smaller hole (a straight stitch needle plate).
Important Note: If you change your needle plate, check to make sure your needle aligns perfectly with this smaller hole before starting to sew. A misaligned needle could hit the plate and break, which could be dangerous. And make sure to change your needle plate back for zigzag and other wide stitches.
I hope this helps.
Mar 14, 2010 | Singer 5062 Mechanical Sewing Machine
Sewing Machines Logo
93 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
