Refer to the drawing below and I will explain the connections. You have the nine wires as you described. First, you will not be connecting the SHIELD to anything, so set it aside. Now, the remaining 8 wires are split into 2 groups of four. You have +5V1, -D1, +D1, +GROUND1 on the first group. These wires will attach to the ODD pins 1,3,5,7 respectively (see the chart next to the drawing). Use the missing pin location to orient yourself to the EVEN and ODD pins. The remaining wires +5V2, -D2, +D2, and GROUND2 will go on the EVEN pins 2,4,6,8 respectively.
Hope this helps!
SOURCE: Sytem restarts frequently
hey
have you tryed to update with the newest firmware and drivers?
also i would try to replace memory. Maybee remove one blok at the time
/michael
Repair and DIY 'why pay when you can play'
SOURCE: need driver for my Iwill P4S motherboard for
Here is a link to the drivers on your motherboard.
It requires a sign up (its free).
Watch that you only get the XP drivers.
Hope this helps.
http://members.driverguide.com/driver_search.php?q=Iwill+P4SE&si=1317010c1a18c502721f0ed125fed974&st=1257472499&gqm0=Iwill+P4SE
SOURCE: led d1 and led d2 lights are off
i had same problem and i turned the power led around and it fixed mine and made sure the connectors are on the right post sounds like you may have missed it by one
Stock
1- Shield (Ground)
2- Yellow (Audio)
3- Red (Transmit)
4- White (Receive)
This is the stock mic wiring but why bother just order a RoadKing 56 it is already wired for your radio. I suggest Copper.com dont even consider a Skythumper it is cheaper but the quality is not there.
