Question about Philips PET702 Portable DVD Player
READING NO DISK
I HAVE A PHILIPS PET702P DVD PLAYER. IT PLAYS EVERYTHING EXCEPT DVD'S OR DVD-R. I'VE SEEN ONE FIX WHICH SAYS MAKE SURE THE AUDIO BUTTON ON TOP WAS OF , BUT THIS MODEL DOES NOT HAVE THAT SWITCH. PLEASE HELP
  • Anonymous Jan 03, 2009
    I do have the same problem , it plays audio cds but not playing videos from DVD disc .. the screen stays black
The disk will not spin at all. the screen says no disk. this device is knew . what will cause this
Posted on Jan 15, 2009
  • 24 Answers
A weak laser is probably the cause. What do you mean it plays everything except dvds do you mean it plays cds. Just remember it is a dvd player it should play them first and foremost.
Posted on Oct 08, 2008
I have a Philips Model PET702/37 DVD player. It has constant static in the speakers, even if I have the DVD player on pause. I can't hear the person speaking on the DVD and it is VERY annoying. Can you...
It sounds like that you might have a high voltage arch or a bad connection on the audio amp board. You can take the back off and with the lights off, or in a dark room you can look for something arching.
Nov 11, 2010 | Philips PET702P/37 Portable DVD Player
Disk not loading; I can hear disk spinning then a faint grinding to a halt noise
clean the laser lens (which is VERY small ) with 90% of better ispropyl
use a qtip to apply and the other end to wipe away excess
If you can see the chrome plated rail that the laser runs on..Clean that with Q-tip and a drop of oil or WD40
Jul 30, 2009 | Philips PET702P/37 Portable DVD Player
My dvd will stop playing after it plays for about 90 seconds
You can try to reset the dvd player to factory specification with the default function in the preference section of the set-up. Use your remote control and push the set-up button. Use the up and down arrows to highlight the preference section and press enter . Youwill now have entered in to the sub-menu, use the up and down arrows to highlight default and press enter.This will set the dvd player back to factory settings. This should restore the dvd player to normal operation. If it does not restore the dvd player to normal operation, you may have a problem with the drive motor circuits. This could be a failure of components in the power supply circuit for the motor or the the motor itself. For these type of problems it is best to consult with Phillips, they will have all the proper service information to service the problem.You can call their customer support at this telephone number. 1-888-744-5477. Give them the model number of the dvd player and the problem with the intermittent drive operation. They will be able to how to get the unit serviced and repaired. I hope this information helps you with your problem.
May 31, 2009 | Philips PET702 Portable DVD Player
Disc error when reading dvd
try to clean dvd plaer lens with a lens cleaner...
Jan 14, 2009 | Philips Magnavox DVD/VCR Dual Player
AudioVox VE 1020 BAD DISK
I was able to find a junk unit (screen no good) on eBay -- swaped out the dvd player - everything has worked fine since (except 6 months later I had to swap out the audio card from the same junk unit - and now all OK ever since.)
Nov 10, 2008 | Audiovox VE1020 10.2 in. TV/DVD Combo
PET702 Portable DVD player 'No Disk'
try this:
Press setup on the remote
Use the arrows to navigate to Prefreneces (pref)
type 9 6 5 3
Select Region code (press down arrow to set to 0, open for all codes)
Press setup again to exit
is working :D
Mar 16, 2008 | Philips PET702 Portable DVD Player
Samsung Player will not recongnize DVD
I had the same problem and after reading and trying allot of disks I found the following to work.
Used Maxell - RW disk. Did a complete format on my computer (takes a while). Burned a DVD using Vista DVD burner with only a Jpg as per one of the other posts. Once the disk plays. Stop and goto disk management and format using DVD-V (VR did not work).
I know its not pretty but at least its better than throwing it in the garbage bin.
Sep 19, 2007 | Samsung DVD-R130 DVD Recorder
Philips PET702 Portable DVD Player Logo
424 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
