Question about Canon CLC 1120 Color Copier
Paper Jammed don paper jammed in printer CLC canon 1150 I cleaning some parts but problem persis I see graphic localizate el problem in sensor traslate drum
  • 67 Answers
Your sensor is detach or bad where it says paper jam
Posted on Nov 19, 2008
sometimes invisible paper jams are cause of teared piece of paper that was left over inside the paper path please check again if there are piece of paper left inside and paper detection switches are ok.
Dec 19, 2009 | Canon CLC 1150 Color Copier
The paper keeps getting jammed. what does it need? does it need a cleaning or is it normal for it to get stuck often?
Short answer, No.
It shouldn't be getting jammed. Sometimes it's caused form damp apaper and also the paper trays guides are not quite set up correctly.
Aug 17, 2009 | Canon CLC-700 Copier
My hp laserjet 1150 series stops printing after a paper jam
you probably have a piece of paper inside printer or you have damage a paper sensor path while removing jammed paper.
Jun 22, 2009 | HP LaserJet 1150 Printer
In CLC 1150 When power on the paper jam error show who to solve the problem in copier jam the error code shows 00-0360 0-367596
There are rollers that cling on to the paper and move it through the machine. When the rollers are worn down they do not grip the paper. For a short fix you can get something rough like sandpaper, brillo pad, etc, and gently scratch the rollers to give them some traction. This will temporarily solve your problem until you can get the rollers replaced.
Jan 06, 2009 | Canon CLC 1150 Color Copier
Canon clc 1180 error code 073-0003
this is an error for the transfer unit or its cleaning section not in proper place slide out the unit as far as it will go.. look inside to the lower left rear frame. there are 2 halfmoon gears sticking out reach in and turn both of those clockwise till they stop . slide unit back in close doors see if it resets good luck
Dec 28, 2008 | Canon CLC 1150 Color Copier
CLC 1110 E71?0007, E071?0002, E072 error codes.
On my CLC 1150 copier machine, I have an error code E071 – 0002.
Sir plz send soluation this error
Dec 12, 2008 | Canon CLC 1110 Copier
Will not copy
a sensor is dislodge check where it jams and reseat the sensor be sure to take the copier off before reseating the sensor if that do work replace the sensor
Nov 14, 2008 | Canon CLC 1150 Color Copier
Victor enriquez
there maybe a piece of paper or some dust in one of the transfer drum drawer connectors, also in the transfer drum home position sensors there may be toner or paper dust
May 15, 2008 | Canon CLC 1120 Color Copier
you more than likely need the oil blade replaced. others things can be that you have paper jammed up at the top of the fuser which means youll need to open up the fuser.
May 07, 2008 | Canon CLC 1150 Color Copier
E072 - 0002
most of the time if you replace the transport cleaning unit it fixes the fault. on one machine i had a break in the wire lume that caused the problem. also make sure you don't have a piece of paper jammed in the unit.
Apr 09, 2008 | Canon CLC 1120 Color Copier
Canon CLC 1120 Color Copier Logo
118 people viewed this question
old marine
old marine
