Question about HP OfficeJet J4580 All-In-One Laser Printer
Copier/Fax not printing
We have new ink cartridges, and the print prints mechanically, but the image is not transferred to the paper
  • Puneet Jain
    Puneet Jain May 11, 2010
    Since when this problem arised. have you check and tried printing with one or more application?
    What is operating system used? Check out the printer window, if the preference and setting are manipulated earlier.
    Guru:
  • 558 Answers
You have to change the setting from the control panel, go to Printer & Fax .. then properties.. open .. the settings and check if the background is selected or not then apply and then take a print.
Let me know if the problem persists we will investigate further.
Dont vote till you get the exact solution.
Posted on Oct 10, 2008
  • Puneet Jain
    Puneet Jain Oct 18, 2008
    Reply please if the soluton work for you.
    Give your rating to the solution either Helful or Fixya.
    If you dont fix the problem yet by the solution given then I would suggest you more options, let me know for it.
    Since your voting is precious to me in providing the help for others.
    Have a Nice day.
    Regards,
    Ellin
Printhead Loose or missing. Install printhead or ink cartridges.
THE PRINT HEAD is the LASER that puts the image on the drum which puts the image on the transfer belt then paper or the drum puts on the paper. Missing the Print Head !!!!!!!!!!!!!!!!!!!! did you get it second hand? Not something you can get at a store. Contact the company and see about it being repaired.
Nov 15, 2015 | Kodak Esp 2150se Wireless Office...
The thermal transfer paper tore during process how do I fix it? I removed the cartridge but now the fax paper just sit in tray while the rollers rolls.
Cartridge? There is no print cartridge in a thermal fax. Maybe you removed the thermal print head. Put it back! You simply need to "thread" the fax paper back through the slot that leads to the cutter mechanism. When you close the lid the rollers will pick up the paper and cut off a fresh strip. Locate the long slot for the paper.
Jul 22, 2009 | Brother Office Equipment & Supplies
DOES NOT PRINT INCOMING FAX- PAPER COMES OUT BLANK
Have you tried a new toner cartridge?
Did you pull the plastic tape on the cartridge?
Mar 21, 2008 | Panasonic KX-FPG376 Plain Paper Thermal...
Sharp ux b700 will not print
it sounds like either you didn't peel off the plastic cover the ink cartridge or it is a defective cartridge.
Thank You,
Mikey
Mar 18, 2008 | Sharp UX B700 Plain Paper Inkjet Fax
Solid Blank Line
If it's blank, is this on what you send/recieve?
Also if you print something like a status sheet, is it missing on those too? If so, your print head needs replacing.
If its on copies/sents you need to clean the scanner head.
Feb 15, 2008 | Brother IntelliFAX 885MC Plain Paper...
UX B700
wipe off the contacts on back ink cartridge with a microfiber towel moistened with alcohol also wipe of the printhead (area where ink cartridge contacts the paper) then reinstall and try printing.
Jan 22, 2008 | Sharp UX B700 Plain Paper Inkjet Fax
Installed a brand new cartridge in hp 1040 fax but prints very poorly(light )
remove the new cartridge
TAKE A MICROFIBER CLOTH MOISTENED WITH RUBBING ALCOHOL AND WIPE THE PRINT HEAD ( THE PART OF THE CARTRIDGE THAT CONTACTS PAPER)
REINSTALL THE CARTRIDGE THEN TEST
ALSO YOU MAY WANT TO WIPE OFF THE CONTACTS ON THE BACK OF THE INK CARTRIDE WITH THE MICROFIBER CLOTH MAKING SURE THERE ARE NO FINGERPRINTS ON THE CONTACTS
Dec 03, 2007 | HP 1040 Plain Paper Inkjet Fax
Fax in memory
Either load paper or ink cartridge. If it is paper I think you will need to either press the start button or the stop button then it should start printing automatically.
If it is the ink cartridge after you have installed a new one then it should start printing.
Hope this is of some help to you
Thanks J
Nov 06, 2007 | Brother IntelliFAX 560 Plain Paper Fax
HP OfficeJet J4580 All-In-One Laser Printer Logo
44 people viewed this question
Ben Johnson
