Question about HP Office Equipment & Supplies
HP printer new printer HP 5300. no black when I try to print a letter. inital test gave color blocks, but no black
    Guru:
  • 558 Answers
Since when this problem arised, have you check the cartridge?
Is it all-in-one printer or simple, please provide the complete model no.
Try this: Reinstall the Cartridge, unplug it from PC and replug after 10 min. and restart PC first then Printer.
Try to check the cartridge ink flowing out from the nozzle, use a cotton and squeeze it little bit.
Also check the official website of HP printer for more info suing this link:
HP Printer 5300
Let me know if you need furthe rassistacne.
Posted on Oct 08, 2008
  • Puneet Jain
    Puneet Jain Oct 18, 2008
    Reply please if the soluton work for you.
    Give your rating to the solution either Helful or Fixya.
    If you dont fix the problem yet by the solution given then I would suggest you more options, let me know for it.
    Since your voting is precious to me in providing the help for others.
    Have a Nice day.
    Regards,
    Ellin
Kodak 5300 printing only left half of page after good first page
Try Using An HP Color Inkjet Printer With Only 2 Cartridges,
One Color One Black That Works! If You Don't Have One Buy One New or Used It Does not Matter HP Is The Best!
the one you have Is Defective Anyway And Needs To Be Replaced!
Jan 13, 2015 | Kodak EASYSHARE 5300 All-In-One InkJet...
Black ink will not print
Have you tried setting the color to black cartridge only. You may be printing the black with a combination of colored inks. I occasionally have a similar problem. Sometimes I can get the black to work by taking a paper towel dampened with distilled water and holding it against the cartridge print head until I see black ink coming out. Replace the cartridge and try printing again. If this doesn't work try a new cartridge and run through your Printer Settings, making sure they are all set properly.
Mar 17, 2014 | Hewlett Packard Printing & Imaging HP...
Why does my hp 1220c print letters double struck type red/black i
check you cartridge, is it new and genuine, if you have not troubles in cartridge, check the cleannig station
Mar 30, 2010 | HP DeskJet 1220c InkJet Printer
Normal color print ,black print cuts off top/bottom of letters
Suggest using the printer software utility to clean the print heads, then print a test page.
Nov 29, 2009 | HP DeskJet F4280 All In One Printer InkJet
Printer will not print black ink
Seems to be a common fault with Kodak EasyShare 5100/5300
Contact Kodak Support and go though the following tests:
Remove and re-seat Printer Cartridge(s) - Done
Clean Printhead - Done
Calibrate Printer - Test Sheet Not Complete!
Run Computer Colour Test - Done
They will then send you a new Print Head.
Mar 25, 2009 | Kodak EASYSHARE 5100 All-In-One Printer
Kodak 5300 wont print right
Have you tried the printer set up menu?
Run the "clear nozzel" test.
Run the "test page" test.
If these tests fail to solve your issue, then it is probably the cartridges.
Hope this helps
G
Jan 28, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
Changed ink cartridges Kodak 5300 print blurry/missing letters
I called Kodak and they are sending me a new printer head at no charge! Can't get any better then that. Man I talked to was very nice, knowledgeable and polite.
Dec 15, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
Black blocked by magenta
One ovbious option would be to have a friend print it out.
I assume that is not an option.
Some printers just won't let you print if a single color is out. Yes, stupid. Try printing a blank page. If it fails, there is no other option but to replace the cartridge or print elsewhere.
If the blank page test works, this next option/test is worth a try...
Depending on the app you are using, you can specify the color breakdown of the colors you are using. In your case, it is possible that the text is set to a rich black (4-color) rather than just black.
If that is the case, to test this most quickly, make a new file, and create a new black (black2), set to 100 black, 0% other colors.
Type a wor and set it to print in that color and try to print it.
If that works, apply the same technique to your real document.
Hope it works. I've been stuck in the same situation, and some printers will just not let you print if a single color is out.
Good luck.
DigiChick
Jun 09, 2008 | HP Color LaserJet 2600n Printer
HP 1610 prints color blocks all over a black and white page.
You are lucky you can print ANYTHING! My unit has NEVER worked (3 years) due to a hardware defect of HP. I downloaded patches, cleaned/replaced cartridges, etc.
Spoke to HP last nite-Was told printer was junk-they don't carry it or any parts to fix it anymore!! I was told to replace it!
Apr 20, 2008 | HP PSC 1610 All-In-One InkJet Printer
1,846 people viewed this question
Seeker5211
Seeker5211
